Bell'O Real Wood TV Stand in Espresso Finish
#77
4.2
based on 22 reviews
from $249.99 - $500.00
Ratings Distribution
5 star
9
4 star
11
3 star
1
2 star
0
1 star
1
Category Average
3.9
More Images
Pros
  • Attractive design (18)
  • Supports weight (15)
  • Holds all components (13)
  • Smooth edges (10)
  • Easy assembly (7)
  • Easy to wire (6)
  • Easy to move (4)
  • Finish (1)
  • Not easy to assemble (1)
  • Quality appearance (1)
See less See more
Cons
  • Difficult to assemble (6)
  • Difficult to set up (1)
  • Doors don't fit properly (1)
  • Flimsy (1)
  • Heavy / bulky (1)
  • Poor cam lock system (1)
  • Poor quality hinge screws (1)
  • Quality of hardware (1)
  • Screws and connecting cam (1)
Best Uses
  • Space saver (9)
  • Convenience (8)
  • Decoration (7)
  • Home (2)
  • Tv furniture for bedroom (1)
Provided by Racks and Stands
This classic cabinet is solidly constructed of real wood with a dark mocha finish. It accommodates up to most 42" Flat Panel Plasma or LCD TVs, most DLP or LCD Projection TVs up to 44", or most Direct View TVs, plus up to 4 or more audio video components and a center channel speaker. Shown with solid wood panel doors, the cabinet also includes a set of interchangeable tempered safety glass panels and speaker cloth framed panels. The Back Panel includes a CMS Cable Management System to hide wires and provide proper air circulation.
Features:
  • Real wood construction in dark mocha finish
  • Accommodates up to most 42" Flat Panel Plasma or LCD TVs, most DLP or LCD Projection TVs up to 44", or most Direct View TVs
  • Shelves hold up to 4 components, plus a center channel speaker (center lower shelves is fixed)
  • Tempered safety glass panel doors
  • Interchangeable solid wood panels and speaker cloth framed panels
  • Center shelf in interior compartment
  • Added heavy duty metal bar is included in the underside of the cabinet-top for extra strength
  • Built-in vertical support divider to improve stability
  • Improved base support with center leg added, will be at the bottom of cabinet
  • Additional vertical support divider is built-in to improve stability
  • Cable management system
  • Ships Ready-to-Assemble
Specifications:
  • Overall dimensions: 44" W x 25" H x 23" D
  • Top drawers usable space: 37" W x 6.5" H x 21.375" D
  • Interior compartment usable space: 35.5" W x 13" H x 19.75" D
  • Top shelf holds up to 200 lbs; bottom shelf holds up to 50 lbs
TV Stand Assembly Instructions
About Bell'O:
When it comes to home theater furniture, Bell'O provides a distinct flair of Italian contemporary design. Bell'O offers a full line of audio/video furniture, audio furniture, home theater furniture, and entertainment centers, including plasma TV stands, DLP stands, LCD, projection TV stands, speaker stands, and TV stands. Home theater furniture ensembles accommodate plasma, DLP, projection and standard TV monitors as well as additional audio/video components.
Since 2001, Bell'O has been making headlines with its award winning designs. Every year, ELECTRONIC HOUSE magazine selects products for its highly regarded Product Of The Year Award. And for five years straight, Bell'O International has topped the list with the innovative styling of its Audio/Video Systems. Bell'O even has designs that hold the prestigious Innovations In Design & Engineering Showcase Award presented every year at the prominent Consumer Electronics Show in Las Vegas, Nevada.
Once again, we have continued this tradition of excellence into 2005 with such unique designs as the AVS-2752HG, the recipient of this year's award. The AVS-2752HG features uniquely elegant styling with a beautiful high gloss black finish to match the latest and greatest LCD and DLP televisions on the market today.
Bell'O is proud of its history of recognition, and is proud to be the leader of innovative and stylish home theater furniture.
Specification Description
Model WAVS-325, WAVS325
UPC 748249903255
Assembly Assembly Required
Brand All Other Brands
Depth (in.) 23
Depth (Inches) 22
Dimensions 44W x 23D x 24.25H inches
Dimensions 44W x 23D x 24.625H inches
Entertainment Centers TV Stands
Finish Code Dark Wood
Flat Panel Width 38 - 56 inches
Height (in.) 24.25
Height (Inches) 24.75
Material Wood
Material Wood Solids/Veneers
Plasma/LCD Width Up to 27 inches
Recommended for Large widescreen televisions
Recommended for Plasma/LCD TVs Up to 50 inches
Recommended for Traditional TVs Up to 50 inches
Traditional TV Width Up to 27 inches
Type Closed Shelving
Weight (lbs) 105
Width (in.) 44
Width (Inches) 44
Bell'O Real Wood TV Stand in Espresso Finish Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Apr 18, 2009
Bell'O Real Wood TV Stand in Espresso Finish Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
4.0
Great solution for Home Theater Equip.!!
"The screws and conncting cams were rather weak aluminum, as a screw head broke off and three cams broke during assembly. I was able to get better ones at [...]...." Read Full Review »
Jan 28, 2008 by John
See more positive Bell'O Real Wood TV Stand in Espresso Finish reviews
1.0
Disappointed with product
"The quality of wood and finish is good. The quality of the fit and assembly hardware is very poor. Expect to spend at least 2 hours assembling this unit. If the parts fit correctly and they used real hardware this would be a good product. I expected higher quality for the price...." Read Full Review »
Jan 23, 2009 by Disappointed customer
See more negative Bell'O Real Wood TV Stand in Espresso Finish reviews
Displaying 1 - 5 of 22 Reviews
Show
Sort by
4.0
    Pros
  • Attractive Design
  • Easy to Wire
  • Holds All Components
  • Smooth Edges
  • Supports Weight
    Cons
  • Difficult To Assemble/Wire
    Best Uses
  • Convenience
  • Space Saver
"The screws and conncting cams were rather weak aluminum, as a screw head broke off and three cams broke during assembly. I was able to get better ones at [...]. "
Assembled cabinet
Assembled cabinet
  • Picture of Product
Was this TV Accessory review on the Bell'O Real Wood TV Stand in Espresso Finish helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jan 28 2008
John
Milwaukee, WI
I am:
  • Practical
  • Stylish
Reviewed at:
Price: $395.00
Nice piece of furniture
4.0
    Pros
  • Attractive Design
  • Easy to Assemble/Wire
  • Smooth Edges
  • Supports Weight
    Cons
    Best Uses
  • Convenience
  • Decoration
"Most TV cabinets are made of pressed particle board and look cheap. This is looks like real furniture. It's substantial, and very attractive. We are using this for a 41" flat panel TV and components, and everything fits perfectly. The cabinet is very heavy, something I consider to be a 'pro' rather …"  Read Full Review »
Dec 22 2007
Patti
Pittsburgh, PA
I am:
  • Practical
  • Stylish
Reviewed at:
Price: $395.00
Attractive and Easy to Assemble
4.0
    Pros
  • Attractive Design
  • Easy To Assemble
  • Easy to Wire
  • Smooth Edges
  • Supports Weight
    Cons
  • None
    Best Uses
  • Decoration
  • Space Saver
"[...] Assemply easy and fairly straightfoward, took me about 3 hours by myself even after attaching the sides backwards the first time. Doors aligned perfectly the first time. I would agree with other reveiws that the cam attachments were a little substandard in quality. The finish was a little li …"  Read Full Review »
Feb 22 2009
KCTom
Kansas City, MO
I am:
  • Bargain Hunter
  • High-End Shopper
  • Stylish
Reviewed at:
Price: $470.00
adequate description
4.0
    Pros
  • Attractive Design
  • Easy to Wire
  • Smooth Edges
  • More »
    Cons
    Best Uses
  • Convenience
  • Decoration
  • Space Saver
"I mentioned that the cam lock system was poor. I have seen better in lower quality furniture. Also, the screws used in the hinge assembly did not appear to be of the best quality. Otherwise, assembly was easy. Directions were adequate and packing was good. There was some minor damage, which appe …"  Read Full Review »
Aug 2 2007
Jon
Spartanburg, SC
I am:
  • Practical
  • Quality at a price
  • Skilled at assembly
  • Stylish
Reviewed at:
Price: $395.00
Bell'O WAVS-325 TV Stand
4.0
    Pros
  • Attractive Design
  • Supports Weight
    Cons
    Best Uses
  • None
"Nicely finished, well-built and sturdy, but the quality of the hardware (particularly the cam locks/pins) isn't the greatest. I managed to shear a cam lock in half when hand-tightening it; fortunately, the part that stayed in the hole held the pin in place. Other than the hardware, this is an exce …"  Read Full Review »
May 4 2008
Q
Richmond, VA
I am:
  • High-End Shopper
  • Stylish
Reviewed at:
Price: $395.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
