Belkin Laptop Cooling Pad
#274
3.6
based on 178 reviews
from $19.98 - $25.99
Ratings Distribution
5 star
111
4 star
89
3 star
27
2 star
36
1 star
44
Category Average
3.8
More Images
Pros
  • Lightweight (118)
  • Durable (83)
  • Easy to configure (83)
  • Versatile (50)
  • Easy to use (4)
  • Quiet (2)
  • Appearance (1)
  • Better dc power connect (1)
  • Does keep it cool (1)
  • Does not fit in my cbag (1)
See less See more
Cons
  • Flimsy (14)
  • Noisy (4)
  • Incompatible (2)
  • Runs hot (2)
  • Unreliable (2)
  • A little small (1)
  • Cord to short (1)
  • Design - brace (1)
  • Doesn't last long (1)
  • Fan became noisy (1)
Best Uses
  • Travel (34)
  • Back-up (10)
  • Replacement (10)
  • All the time (2)
  • Laptop (2)
  • 1st cooling pad owned (1)
  • At home 4 laptop (1)
  • At my desk (1)
  • Computer stand (1)
  • Cool (1)
Provided by NothingButSoftware
General Information
The Laptop Cooling Pad's unique patented wave design prevents your laptop from overheating. It uses natural convection to enhance fan cooling, and ensures low power consumption via your laptop's USB port. It requires no bulky power adapters.
Physical Characteristics
Form Factor:Side Fan
Dimensions:1.1" x 11.6" x 12.6"
Miscellaneous
Additional Information:
  • Fits conveniently within laptop bag
  • Grips pads to prevent laptop from slipping
  • Raises screen height to help reduce neck strain
  • Patented wave design enhances cooling capabilities
  • Gentle slope improves typing comfort and reduces wrist strain
  • Convenient storage compartment for USB cable when not in use
  • Compatibility:
    Notebook
    Application/Usage:Case
    Specification Description
    Model 85BEDB04, BA911435, BKNF5L001, BLKF5L001
    UPC 722868608654
    Brand Name Secondary Belkin
    Can Ship in Original Container Yes
    Channel Availability Online Only
    color null
    Corp National Status A
    Corp National Status X
    Country Of Origin Malaysia
    Date 1st Available Online 12-MAR-09
    Date 1st Available Online 15-JAN-09
    Freight Class TRU_SHPG
    Hazmat Warning N
    Manufacturer Part Number F5L001
    Manufacturer Part Number F5L001BLK
    Notify Me When Available Yes
    Registerable Yes
    size null
    sku 135191
    sku 162593
    skuprice 37.9900
    skuprice 39.9900
    style BKNF5L001
    style F5L025
    taxable Y
    TRU SKN 372784
    TRU SKN 820372
    Belkin Laptop Cooling Pad Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 17, 2009
    Belkin Laptop Cooling Pad Reviews
    Most helpful positive review
    [23 of 25 customers found this review helpful]
    Most helpful negative review
    [3 of 3 customers found this review helpful]
    4.0
    Very Effective
    "The unit is very effective in keeping my laptop cool as well as at nice height for using whether setting on my lap or on a table. Easily fits into my laptop bag. The only problem is the storage compartment for the USB power cable is a little difficult to get in and out of...." Read Full Review »
    Aug 22, 2008 by Berkley
    See more positive Belkin Laptop Cooling Pad reviews
    3.0
    Okay, but expect problems if in sandy environment
    "I bought this cooling unit with the intent of using while in Iraq. It does help keep the laptop cooler than if you were relying on just the fans for the PC unit but I have encountered some problems. The first one is that the fan blades build up static and thus collect a lot of dust, something we have an abundance of in Iraq. So if you detach the unit and then reattach it, you have to clean it really well with co..." Read Full Review »
    Apr 27, 2008 by Medic4
    See more negative Belkin Laptop Cooling Pad reviews
    Displaying 1 - 5 of 178 Reviews
    Show
    Sort by
    [6 of 6 customers found this review helpful]
    Very effective
    4.0
      Pros
    • Easy To Configure
    • Lightweight
    • Versatile
      Cons
    • None
      Best Uses
    • None
    "I was a bit sceptical when I bought it for my wife's laptop, but it does what it claims to and is more effective than expected. It can cool a Dell E1505 that is almost too hot to touch within minutes. It works great on a flat surface with the fold out support and works equally well on your lap. T …"  Read Full Review »
    Was this Laptop Computer Accessory review on the Belkin Laptop Cooling Pad helpful to you?
     Report Abuse  (6)  (0)  0 comments
    Apr 13 2008
    RT
    London, UK
    I am:
    • Tech Savvy
    Reviewed at:
    Price: $22.95
    3.0
    "I bought this cooling unit with the intent of using while in Iraq. It does help keep the laptop cooler than if you were relying on just the fans for the PC unit but I have encountered some problems. The first one is that the fan blades build up static and thus collect a lot of dust, something we hav …"  Read Full Review »
     Report Abuse  (3)  (0)  0 comments
    Apr 27 2008
    Medic4
    Baghdad, Iraq
    Reviewed at:
    Price: $19.99
    [2 of 2 customers found this review helpful]
    Slightly Disappointing
    3.0
    "Even after reading the mixed reviews, I went ahead and bought this primarily because of price. I've had it for about two weeks and initially it worked fine. My laptop was no longer running hot after staying on for eight hours at a time. I usually use it either on the bed or on my lap. During week on …"  Read Full Review »
     Report Abuse  (2)  (0)  0 comments
    Feb 11 2008
    Chippers
    Ames, IA
    Reviewed at:
    Price: $19.99
    Delivers
    5.0
      Pros
    • Easy To Configure
    • Lightweight
    • Versatile
      Cons
    • Ties up a USB port
      Best Uses
    • Use it all the time
    "I have a Dell Inspiron 5100 which are legendary for overheating. I considered this laptop useless until I got the cooling stand as it would overheat in about 20 minutes and shut down. Since I started using this product it has not overheated once. The cooling stand is lightweight, self contained (com …"  Read Full Review »
    Feb 8 2008
    Adam
    Ellington, CT
    I am:
    • Tech Savvy
    Reviewed at:
    Price: $25.00
    not a great buy
    2.0
    "the laptop fan is great when it works. its easy to hook up with just a simple USB connection and keeps your laptop cool while operating quietly. But that's while it IS working... A couple weeks after purchasing i noticed a loud noise coming from the fan when i turned on my computer, i unplugged it a …"  Read Full Review »
    Nov 4 2009
    zw240
    New York
    Reviewed at:
    Price: $19.99
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
