Belkin F5D8236-4 N Wireless Router
#4
4.1
based on 110 reviews
Ratings Distribution
5 star
137
4 star
62
3 star
12
2 star
6
1 star
30
Category Average
3.8
Low Price:
$59.99 at B&H Photo Video
 Trusted:
$59.99 at TigerDirect
Find it at Amazon
$59.99 - $79.99
from 12 stores
More Images
Pros
  • Easy setup (123)
  • Fast (101)
  • Highly compatible (90)
  • Secure (86)
  • Small (85)
  • Looks great (2)
  • Easy to reboot (1)
  • Excellent range (1)
  • Good price (1)
  • Good range (1)
See less See more
Cons
  • Unreliable (9)
  • Slow (5)
  • Bulky (4)
  • 24 7 electricity draw (1)
  • Can't think of any cons (1)
  • Compatibility issues (1)
  • Doesn't work (1)
  • Had to be config to comp (1)
  • Had to call support (1)
  • Hard to set up (1)
Best Uses
  • Home (122)
  • Small office (38)
  • Secure networks (26)
  • Large office (4)
  • Home office (2)
  • Home networks (1)
  • Small offices (1)
Provided by Dell
The F5D8236-4 N Wireless Router from Belkin is the ideal solution for your networks in home or office. Connecting the N Wireless Router to your cable or ADSL modem, you can share your broadband Internet account with all your networked computers and quickly and efficiently exchange documents, share resources, and stream the digital music. Furthermore for simple wireless security setup it supports Wi-Fi Protected Setup Push button. The F5D8236-4 N Wireless Router has the bandwidth and speed for handling media intensive applications that take up large amounts of your bandwidth.
Specification Description
Model F5D8236-4, F5D82364
UPC 722868680636
Interface 4 x RJ-45 10/100Base-TX Auto-negotiating LAN
Network Type Wireless 802.11b / 802.11g / 802.11n
Transmission Speed 300Mbps
Wireless Technology Wi-Fi IEEE 802.11n (draft)
Belkin F5D8236-4 N Wireless Router Questions
Questions and Answers
Where to Buy
$59.99
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$59.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$59.99
Show all 12 stores
Product Reviews
Last update: Nov 12, 2009
Belkin F5D8236-4 N Wireless Router Reviews
Most helpful positive review
[11 of 11 customers found this review helpful]
Most helpful negative review
[8 of 8 customers found this review helpful]
5.0
Flawless in a rather complex environment
"I bought this router about one month ago here at Staples.com but wanted to use it for a while before writing a review. This is my first Belkin router and I must say that I am very impressed with this product. It has excellent strength and has been rock-steady. On the wired side, I have my ATT VOIP phone box connected, as well as a cable to a switch which connects a desktop computer. Wireless, I have up to five l..." Read Full Review »
Feb 07, 2009 by Tech Dad
See more positive Belkin F5D8236-4 N Wireless Router reviews
1.0
Horrible!
"I decided to buy this router after reading many great reviews about it and doing lots of research. I was extremely happy when the router arrived since I thought I was getting one of the best routers and it worked perfectly when I set it up. This router is blazing fast and has a decent range. The huge problem with this router is that I would have to keep resetting it every hour or so and it kept rebooting my la..." Read Full Review »
Mar 14, 2009 by k1
See more negative Belkin F5D8236-4 N Wireless Router reviews
Displaying 1 - 5 of 110 Reviews
Show
Sort by
[3 of 3 customers found this review helpful]
Great Router
5.0
    Pros
  • Easy To Set Up
  • Fast
  • Highly Compatible
  • Secure
    Cons
  • none
    Best Uses
  • None
"I previously bought a linksys WRT-160N and had so many problems with it. There were problems connecting to my main desktop(XP) as well as connecting to laptops through the wireless. I exchanged the wrt160 and got the Belkin F5D8236-4 N Wireless Router. This router was super easy to set up w/the CD. …"  Read Full Review »
Was this Network Router & Bridge review on the Belkin F5D8236-4 N Wireless Router helpful to you?
 Report Abuse  (3)  (0)  0 comments
Jun 29 2009
John
NYC
I am:
  • High bandwidth user
Reviewed at:
Price: $59.99
Excellent
5.0
    Pros
  • Easy To Set Up
  • Highly Compatible
  • Secure
    Cons
  • Bulky
    Best Uses
  • Home Networks
  • Small Offices
"I use this product on a daily basis and it's been way more reliable than my previous ones.
I'll need to upgrade again at some point, but this router is just fine for exactly what I need. It's a little bulky, but has a nice design to combat that. "
Mar 20 2009
Eldarwen Half-Elven
Scottsboro, AL
I am:
Reviewed at:
Price: $59.99
Works great
5.0
"I chose this router to replace my existing setup of a Linksys wireless G, and a Linksys wireless extender. The router is over my garage on one end of the house, with most of our computer area in the opposite side where the signal has to go through two brick walls, a floor, and several walls. I wante …"  Read Full Review »
Aug 30 2009
Mike4107
Lake Charles, LA
Reviewed at:
Price: $79.99
[1 of 1 customers found this review helpful]
I have read the pros and ...
4.0
"I have read the pros and cons of this router in this space and was aware of the installation difficulties people had encountered from the comments I read. But I couldn't resist the good price at $59.99 (with no shipping and handling charge), so I plunged in to get one to replace my old Netgear wirel …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jul 18 2009
islandhoppers2001
Riverview
Reviewed at:
Price: $79.99
Works Very Well
5.0
    Pros
  • Easy To Set Up
  • Fast
  • Highly Compatible
  • Looks Cool
  • Secure
  • More »
    Cons
  • none
    Best Uses
  • Home
  • Home Office
  • Small Office
"This Belkin wireless router works very well. No matter where I am in my home, I get 4 or 5 bars (has 5 bars to show signal strength). My connection never cuts out and my speeds are always fast. You can go to the Belkin website to find your wireless router's setup (connects to your router)....and you …"  Read Full Review »
Aug 28 2009
RadianChalant
Northwest of Pittsburgh, PA
I am:
Reviewed at:
Price: $59.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
