Belkin F5D8235-4 N+ Wireless Router
#261
3.7
based on 73 reviews
Ratings Distribution
5 star
37
4 star
20
3 star
9
2 star
6
1 star
13
Category Average
3.9
$79.79 - $99.99
from 12 stores
More Images
Pros
  • Easy setup (21)
  • Reliable connection (21)
  • Fast connection speed (20)
  • Secure connection (20)
  • Fast (19)
  • Adequate (1)
  • Belkin customer support (1)
  • Cheap price (1)
  • Wps one touch connect (1)
See less See more
Cons
  • Difficult to set up (5)
  • Unreliable connection (3)
  • Slow connection speed (2)
  • Bandwidth allocation (1)
  • Might be underpowered (1)
  • Support useless (1)
  • Tech contact in india (1)
Best Uses
  • Home network (25)
  • Small networks (3)
  • Home or business (1)
  • Large networks (1)
Provided by Overstock.com
Belkin's F5D8235-4 N+ Wireless Router features a USB Storage port on the back of the router for connecting USB storage devices such as an external hard drive or thumb drive to the network. Now you can centrally store and share media content and files from the USB hard drive to every computer on the network.*Manufacturer: Belkin International, Inc *Manufacturer Part Number: F5D8235-4 *Manufacturer Website Address: www.belkin.com *Product Name: F5D8235-4 N+ Wireless Router *Product Type: Wireless Router *Antenna Range: Up to 1200 ft Indoor , 100 ft 200 ft Indoor *Frequency Band/Bandwidth: 2.4 GHz IEEE 802.11b/g ISM Band *Transmission Speed: 300Mbps *Transmission Speed Details: 6Mbps IEEE 802.11g, 11Mbps Auto-fallback IEEE 802.11b, 54Mbps Auto-fallback IEEE 802.11g, 300Mbps IEEE 802.11n (draft), 1Mbps IEEE 802.11b *Interfaces/Ports: 1 x Type A USB *Form Factor: External *Dimensions: 11.75" Height x 7" Width x 3.25" Depth - With antennas extended, 11.75" Height x 7" Width x 3.25" Depth - With antennas extended *Green Compliance: Yes *Green Compliance Certificate/Authority: RoHS
Specification Description
Model BKNF5D82354, F5D8235-4, F5D82354
UPC 722868673799
Interface 1 x RJ-45 10/100/1000Base-TX WAN
Network Type Wireless 802.11b / 802.11g / 802.11n
Transmission Speed 300Mbps
Wireless Technology Wi-Fi IEEE 802.11n (draft)
Belkin F5D8235-4 N+ Wireless Router Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 17, 2009
Belkin F5D8235-4 N+ Wireless Router Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
Nice and solid, a router for geeks.
"I bought this as a replacement for an old cheapie that I was not expecting to keep this long. It started to croak on me and that was just fine. This router is reviewed with the highest ranking by USERs on c|net and the reviews were quite correct. It is solid, low latency (the problem with the previous router) sleek looking (tho for me it is hidden away) and has a LOT of features. This is, as I stated, an N r..." Read Full Review »
Jul 02, 2009 by Ben the Technophilic Nurse
See more positive Belkin F5D8235-4 N+ Wireless Router reviews
3.0
Good Product But!
"My intended purpose for purchasing this router was to expand the range of my wireless network. I wanted to upgrade from and older model Belkin 802.11g. While there is no doubt this would have succeeded, the prospect of losing the ability to stream music wirelessly to my stereo is not something I want to give up. Or spend more money to restore. I use a MacBook running Snow Leopard and a Dell desktop running Vi..." Read Full Review »
Nov 03, 2009 by Principale
See more negative Belkin F5D8235-4 N+ Wireless Router reviews
Displaying 1 - 5 of 73 Reviews
Show
Sort by
Wasting monies on commercialized Routers
1.0
    Pros
  • Easy To Setup
    Cons
  • Slow Connection Speed
  • Tech Contact in India
    Best Uses
  • None of the Above
"I am on a T3 100Mb connection, and none of these wireless routers work as advertised!
I now own (4)routers, bought within the last year, all promising "secure and fast" connections, and it appears none of their "overseas" technicians can solve problem of: paying for 100Mbs--getting 2Mbs thru thei …"  Read Full Review »
Was this Wireless Networking review on the Belkin F5D8235-4 N+ Wireless Router helpful to you?
Nov 16 2009
Spike From NYC
New York City, NY
I am:
  • High bandwidth user
Reviewed at:
Price: $79.99
5.0
    Pros
  • Easy To Setup
  • Fast
  • Fast Connection Speed
  • Secure Connection
    Cons
    Best Uses
  • Home network
  • Small Networks
"I bought this as a replacement for an old cheapie that I was not expecting to keep this long. It started to croak on me and that was just fine. This router is reviewed with the highest ranking by USERs on c|net and the reviews were quite correct. It is solid, low latency (the problem with the pre …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jul 2 2009
PNW
I am:
Reviewed at:
Price: $79.79
[4 of 4 customers found this review helpful]
Rapid Router installs easily
5.0
    Pros
  • Easy To Setup
  • Fast
  • Secure Connection
    Cons
  • None
    Best Uses
  • Home network
"This long-range rapid router was installed easily in my four computer home network using the included installation cd. First try, no mistakes, no hair-pulling. Great system, great performance. "
 Report Abuse  (4)  (0)  0 comments
May 29 2009
A1dentist
Cape Cod, MA
I am:
Reviewed at:
Price: $79.79
Great router overall...fast & reliable
4.0
    Pros
  • Fast
  • Secure Connection
    Cons
  • Difficult To Setup
    Best Uses
  • Home network
"Using it for about 2 weeks now.I set it up manually via browser..did not use the setup CD.Great router overall as far as speed, reception and reliability.Looks a little funky with the 2 antennas sticking up but that's probably what gives it great reception & coverage. I bought it because I read tha …"  Read Full Review »
Oct 6 2009
Ankur
Readington Township, NJ
I am:
Reviewed at:
Price: $79.99
Excellent Router
5.0
    Pros
  • Easy To Setup
  • Fast
  • Secure Connection
    Cons
  • None
    Best Uses
  • None
"Best router I have owned! It replaced a Linksys WRT-150N that constantly dropped connection and died after a year, just a few days after warranty expired! Belkins N can be setup in 10 minutes, automatically configures with security and no dropped connections unless I am out of range, which is grea …"  Read Full Review »
Sep 30 2009
TK
Baltimore, MD
I am:
Reviewed at:
Price: $79.79
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
