Belkin Belkin® F5D7230-4 Wireless G Router
#130
3.5
based on 239 reviews
Ratings Distribution
5 star
110
4 star
84
3 star
18
2 star
33
1 star
64
Category Average
3.8
 Trusted:
$33.50 at B&H Photo Video
$29.99 at ClubMac
Find it at Amazon
$29.99 - $39.98
from 15 stores
More Images
Pros
  • Easy setup (70)
  • Reliable connection (44)
  • Fast (40)
  • Fast connection speed (37)
  • Secure connection (35)
  • Small (18)
  • Highly compatible (7)
  • Secure (6)
  • Easy to install (5)
  • Reliable (3)
See less See more
Cons
  • Unreliable (14)
  • Difficult to set up (13)
  • Slow (10)
  • Unreliable connection (8)
  • Insecure (6)
  • Slow connection speed (6)
  • Not secure (3)
  • Bulky (2)
  • Hard to install (2)
Best Uses
  • Home network (57)
  • Home (16)
  • Small networks (12)
  • Small office (5)
  • Secure networks (4)
  • Indoor (3)
  • Large networks (2)
  • Paper weight (2)
  • 1st wireless setup used (1)
  • Best to connect (1)
Provided by Beach Audio
MODEL- F5D723-04 VENDOR- BELKIN COMPONENTS
FEATURES- 802.11g Wireless DSL/Cable Gateway Router
The Belkin 802.11g Wireless Cable/DSL Gateway Router lets users
share files and a broadband Internet connection among their
computers-without using networking cables. It features 802.11g
technology that makes accessing files and networked peripherals-
such as hard drives, printers, CD-ROMs, and DVDs-easier than ever.
802.11g technology provides you with networking speeds nearly five
times faster than the current Wi-Fi (802.11b) standard. An
integrated, 4-port 10/100Base-T Ethernet switch also allows you to
connect wired computers to the network. 802.11g technology is the
easiest wireless network to implement. The Gateway Router uses the
wireless 802.11g 2.4GHz standard to offer you the widest working
range-up to 1800 feet-and greater interoperability in mixed
networking environments. 802.11g technology is backward compatible
with the 802.11b Wi-Fi networking standard, so it allows you to
implement faster wireless technologies in combination with existing
802.11b Wi-Fi networks. An added Turbo Mode will isolate your
network from 802.11b wireless clients and allow your network to
transmit data at the highest 802.11g data rate.
* Creates a network in your home or office without cables.
* 6 months of free Parental Control web content filtering-secure your home
or office from harmful Internet sites.
* Offers backward-compatibility with all 802.11b devices.
* Sets up easily with Belkin Easy Install Wizard-automatically detects
Internet settings and self-adjusts Router to get you online in under 3
minutes.
* Ensures data and network security with wireless 64- and 128-bit WEP
encryption.
* Uses NAT firewall to protect network from outside intrusions by hackers.
* Works with Macintosh and PC computers.
* Also supports computers running Linux or Unix OS.
* Comes with a Belkin Lifetime Warranty and free, 24-hour technical
support.
OPTIONS- F5D7130 802.11g Wireless Access Point
F5D7000 802.11g Wireless Desktop Network Card
F5D7010 802.11g Wireless Notebook Network Card
MANUFACTURER WARRANTY:  LIFETIME
Specification Description
Model 10273676, 74E5B86A, BKNF5D72304, F5D7230-4
UPC 722868455654
Accessory Indicator Yes
Benefits Creates a network in your home or office without cablesDetects Internet settings and self-adjusts to get you online in under 3 minute
Cables Included RJ45 Networking Cable
Capacity UOM mAh
Country Of Origin Taiwan
Description Header Simple connectivity.
Display Catalog Number 55007343
Features Uses NAT and SPI firewall to protect network from outside intrusions by hackersBacked by Belkin lifetime warranty; free 24-hour techn
Included in the Box Wireless G RouterPower SupplyUser ManualQuick Installation GuideRJ45 Networking CableSoftware CD<
Manufacturer Labor Warranty 1
Manufacturer Part Number F5D7230-4
Manufacturer Parts Warranty 1
MAP Price 0.0
Model F5D7230-4
Operating Temperature UOM ° F
Product Type Wireless
Required to function Compatible with Macintosh® and PC computers
Supported Languages English
Belkin Belkin® F5D7230-4 Wireless G Router Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 2, 2009
Belkin Belkin® F5D7230-4 Wireless G Router Reviews
Most helpful positive review
[7 of 7 customers found this review helpful]
Most helpful negative review
[5 of 5 customers found this review helpful]
5.0
Great Router
"Pros This router is very easy to setup and easy to administer. It uses a really easy to use interface. There are too many good features to list here, and for the money you can't go wrong. I've had this router for over 3 years and one day it stopped working, called Belkin and they sent me a new one. It turns out this router has a Lifetime warranty! Not a lot of items have that these days. I am very pleased with ..." Read Full Review »
Jul 16, 2008 by absancen
See more positive Belkin Belkin® F5D7230-4 Wireless G Router reviews
1.0
Bad decision
"I am an IT Professional, and when I needed a router for my home, I was going to purchase a Linksys, however I was in the store and say the inexpensive price on this Belkin and decided to try it. Well, here we are four or five months later and I am shopping for a Linksys or DLink to replace this Belkin unit. There are several reasons for this: 1) I have to restart this router one to three times daily, either by p..." Read Full Review »
Dec 29, 2007 by UncleDaddy
See more negative Belkin Belkin® F5D7230-4 Wireless G Router reviews
Displaying 1 - 5 of 239 Reviews
Show
Sort by
Bad decision
1.0
Well, here we are four or five months later and I am shopping for a Linksys or DLink to replace this Belk …"  Read Full Review »
Was this Network Router & Bridge review on the Belkin Belkin® F5D7230-4 Wireless G Router helpful to you?
 Report Abuse  (5)  (0)  0 comments
Dec 29 2007
UncleDaddy
Baltimore, MD
Great Router
5.0
"Pros
This router is very easy to setup and easy to administer. It uses a really easy to use interface. There are too many good features to list here, and for the money you can't go wrong. I've had this router for over 3 years and one day it stopped working, called Belkin and they sent me a new one. …"  Read Full Review »
 Report Abuse  (7)  (0)  0 comments
Jul 16 2008
absancen
Florida
Reviewed at:
Price: $35.99
Buy it!
5.0
"Pros
Inexpensive.
Good performance
Easy install
Cons
None
Additional Thoughts
About the time I bought this, a friend bought a much more expensive Linksys. They asked my wife to help them install it. There was difficulty installing the Linksys (their help-line was little help - even if you could …"  Read Full Review »
Aug 4 2007
JoeBama
Alabama
Reviewed at:
Price: $35.99
Fair and Afforadble
3.0
"Pros
Compact size, affordable
Cons
Wireless range is poor, had to call customer service to set up the wireless
Additional Thoughts
instruction are not that clear and it required calling customer service, they were really efficient in answering my questions and helping me set up the wireless. Ra …"  Read Full Review »
Feb 2 2007
SmartOne
Des Moines, IA
Reviewed at:
Price: $35.99
Wireless router suites our lifestyle!
5.0
    Pros
  • Easy To Set Up
  • Fast
  • Highly Compatible
  • Secure
  • Small
    Cons
  • None
    Best Uses
  • Home
  • Secure Networks
  • Small Office
"It was a great surprise to me that I could get it working without assistance! Many thanks to the team that put this together. My wife can now stay connected to the internet by wireless connection in the living room while I work in the office. No one else can piggyback on our bandwidth without the pa …"  Read Full Review »
Nov 2 2009
KeithHB
Grand Rapids MI
I am:
  • High bandwidth user
Reviewed at:
Price: $34.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
