Belkin 7-Port High Speed USB 2.0 Hub
#318
4.0
based on 23 reviews
Ratings Distribution
5 star
15
4 star
3
3 star
0
2 star
1
1 star
4
Category Average
4.1
$29.24 - $38.99
from 16 stores
More Images
Pros
  • Easily expanded (5)
  • Easy setup (4)
  • Fast (4)
  • Small (4)
  • Reliable (3)
  • Durable (2)
  • Classic look (1)
  • Easy to use (1)
  • Highly compatible (1)
  • Improves performance (1)
See less See more
Cons
  • Unreliable (3)
  • Doesn't do my homework (1)
  • Flimsy (1)
  • Incompatible (1)
  • Not energy efficient (1)
  • Not stackable vertically (1)
  • Weak connection points (1)
Best Uses
  • Desktop (4)
  • Home (4)
  • 2 light for a paperweight (1)
  • Computer equipment (1)
  • High-end equipment (1)
  • Larger networks (1)
  • Midi equipment (1)
  • Rack mounted (1)
  • Small networks (1)
Provided by Beach Audio
The latest innovation from USB leader Belkin lets you connect up to
seven devices quickly and easily. Our Hi-Speed USB 2.0 7-Port Hub
features two, top-loading downstream USB ports. Now you can enjoy
fast access for temporary device connections such as USB thumb
drives, media readers, and for USB lights, fans, and other
accessories. Monitoring your device activity is simpler than ever
with LEDs for master power status and all port activity. The
stackable, slim-line design saves valuable desk space, and the Hub
works seamlessly with all your USB 1.1 and USB 2.0 devices.
Includes Hi-Speed USB 2.0 7-Port Hub, Power Adapter, 5-Pin Mini B USB
Cable and User Manual.
* Offers 2 easy-access, top-loading 480Mbps ports-perfect for your thumb
drives, USB lights, or fans.
* Features 5 horizontally mounted 480Mbps ports
* Transfers your data at up to 480Mbps
* Installs easily with Plug-and-Play convenience
* Works seamlessly with all your USB 1.1 and USB 2.0 devices
* Saves desk space with stackable, slim-line design
* Supports "hot swapping" of all your USB devices
* Lowers power consumption for longer battery life
* Makes power supply optional in laptop applications
* Lets you monitor port and power status with LEDs
* Features over-current detection and safety
-- SPECIFICATIONs -----------------------------------
CONNECTORS - (7) USB 2.0/1.1 ports
TRANSFER RATE- up to 480 Mbps
REQUIREMENTS - PC : Pentium processor-based computer
USB 2.0 port
Windows 98 SE, 2000, Me, or XP
Mac: Supports low- (1.5Mbps), full- (12Mbps), and high-speed
(480Mbps) modes on PowerMac computers equipped with a
USB 2.0 upgrade card and OS 10.2.7 and above.
www.belkin.com
Specification Description
Model 10273676, 881A3923, F5U237-APL-S, F5U237V1
UPC 722868546437
Color Dark Gray
Color Silver
Connectivity Type USB - Hub
Form Factor External
Number of Ports 7
Select USB
Belkin 7-Port High Speed USB 2.0 Hub Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 6, 2009
Belkin 7-Port High Speed USB 2.0 Hub Reviews
Most helpful positive review
[7 of 7 customers found this review helpful]
Most helpful negative review
5.0
Belkin 7-port usb hubs
"Pros my family and I have several of these. These beat those 4-port hubs, hands down. The rear ports are really nice, putting the cables out of the way, and the top 2 ports are really handy for plugging in flash drives or portable hard drives. Cons Belkin doesn't make a 12-port hub, if that's a con for anyone. It would be great for my use. Additional Thoughts quality and reliability are top drawer...." Read Full Review »
Apr 13, 2008 by SSSS
See more positive Belkin 7-Port High Speed USB 2.0 Hub reviews
1.0
Don't buy this.
"This is the same conditions I am having. EXACTLY except with the Mac version and Ipods not being recognized. Try and contact Belkin? Good luck. NEVER BUY this!!!!!..." Read Full Review »
Nov 17, 2008 by gg
See more negative Belkin 7-Port High Speed USB 2.0 Hub reviews
Displaying 1 - 5 of 23 Reviews
Show
Sort by
5.0
"Pros
Cons
Belkin doesn't make a 12-port hub, if that's a c …"  Read Full Review »
Was this Networking Hub & Switch review on the Belkin 7-Port High Speed USB 2.0 Hub helpful to you?
 Report Abuse  (7)  (0)  0 comments
Apr 13 2008
SSSS
Shreveport, LA
Reviewed at:
Price: $29.99
Great Hub
5.0
    Pros
  • Durable
  • Easy to Use
  • Fast
    Cons
    Best Uses
  • Home
"I already had one of these USB hubs and the box said they were stackable - great, save space and double the ports!!
But what the box didn't say is that they were only stackable horizontally - with the hub laying on a table. There is no way to "click" them together so they stay together.
Besid …"  Read Full Review »
Jun 18 2008
KimInNB
Atlantic Canada
I am:
  • Quality Oriented
Reviewed at:
Price: $38.99
Easy to set up - worked well
4.0
    Pros
  • Easily Expanded
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • None
    Best Uses
  • Desktop
"The external power kept things moving quickly.
We had to load 450 flash drives with files for a conference. We had only one problem and that was the size of our flash drives didn't allow us to load all 7 ports at once, solved that by using extensions. Without the 2 hubs the loading would have been …"  Read Full Review »
Aug 6 2008
EDUFO
Brandon, FL
I am:
  • High bandwidth user
Bad Investment
1.0
    Pros
  • None
    Cons
  • Energy Inefficient
  • Incompatible
  • Unreliable
    Best Uses
  • None
"Does not work with external Hard drives or even a wireless mouse "
Nov 6 2009
TheReefManiac
North Lauderdale, Fl
I am:
  • Low bandwidth user
Reviewed at:
Price: $38.99
This unit's main feature ...
5.0
"This unit's main feature is the fact that five of the seven ports are on the rear, so the cables are not in your way. This is for devices that are always connected. (external drives, floppies, printers, etc.) Then .... there are two ports that are vertically on the top that are easily accessed for …"  Read Full Review »
Sep 29 2008
Phillip
Undisclosed
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
