Belkin 5-Port Network USB 2.0 Hub
#339
3.5
based on 39 reviews
Ratings Distribution
5 star
15
4 star
7
3 star
7
2 star
4
1 star
6
Category Average
4.1
$74.95 - $119.00
from 9 stores
More Images
Pros
  • Easy setup (3)
  • Fast (2)
  • Reliable (2)
  • Highly compatible (1)
  • Small (1)
See less See more
Best Uses
  • External hard drives (1)
  • Home (1)
  • Home network (1)
  • Inkjet printers (1)
  • Laser printers (1)
  • Scanners (1)
  • Small office (1)
Provided by Staples
Wireless access to multi-function printers, digital cameras, external hard drives and other USB devices Share up to 5 devices: multi-function printers, media readers, digital cameras and scanner on your network Back up and access data from networked attached storage (NAS) devices Play music from an MP3 player connected to a USB dock (using USB speakers) The industry's first reliable print server: Network USB Hub makes your computer think that printers and other devices on the network are directly attached to the computer. Works with existing wireless network— wireless router NOT included Share printers and access media—wirelessly
Specification Description
Model BKNF5L009, F5L009
UPC 722868629666
Accessory Indicator Yes
Auto Sensing Yes
Benefits Access to multifunction printers, digital cameras, external hard drives and other USB devicesDock an MP3 Player and play music throug
Body Material ABS plastic
Cables Included RJ45 Ethernet cable
Capacity UOM mAh
Country Of Origin Japan
Data Link Protocol TCP/IP
Description Header Be nice and share.
Display Catalog Number 55027379
Enclosure Color Black
Included in the Box Network USB hubPower supplyRJ45 Ethernet cableSetup installation CDQuick installation guide, setup install
Inputs 1 x RJ45(Ethernet), 6 x USB(USB 2.0), 1 x Barrel(DC)
Manufacturer Labor Warranty 3
Manufacturer Part Number F5L009
Manufacturer Parts Warranty 3
MAP Price 0.0
Model F5L009
Networking 10/100Base-T
Networking Compliant Standards 10/100Base-T
Operating Temperature UOM ° F
Outputs 1 x RJ45(Ethernet), 6 x USB(USB 2.0)
PC Interface Supported 10/100Base-TX auto-sensing, auto-uplink RJ45
Power Device Power supply included
Product Type USB
Required to function PC-compatible computer with one available 32-bit slot, Windows XP or Vista (32-bit)Microsoft Windows Vista® and XP (32bit), Mac O
Supported Languages English
Belkin 5-Port Network USB 2.0 Hub Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 7, 2009
Belkin 5-Port Network USB 2.0 Hub Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[2 of 3 customers found this review helpful]
5.0
Belkin Review
"Initially my purpose was to have a wireless printer so that I didn't have wires hanging out all over my laptop. I had purchased TWO other printservers and neither of them were what I had expected, I either had a ton of trouble setting them up or installing them or there were still USB adapters coming out of my USB ports from my laptop (even though it was wireless, I wasn't particularly happy with it occupying my..." Read Full Review »
Apr 08, 2008 by Hightech32
See more positive Belkin 5-Port Network USB 2.0 Hub reviews
1.0
It's not all it claims to be
"Out of the box, the product looked great and once connected to my router found itself quickly and automatically. It also found a laser printer, multifunction printer and flash drive without effort. The problem was that the device could not find the scanner or memory readers on the multifunction printer. The offshore tech support was as useless as the user manual. At first tech support told me that the hub did no..." Read Full Review »
Nov 16, 2007 by Nirosep
See more negative Belkin 5-Port Network USB 2.0 Hub reviews
Displaying 1 - 5 of 39 Reviews
Show
Sort by
Belkin Review
5.0
"Initially my purpose was to have a wireless printer so that I didn't have wires hanging out all over my laptop. I had purchased TWO other printservers and neither of them were what I had expected, I either had a ton of trouble setting them up or installing them or there were still USB adapters comin …"  Read Full Review »
Was this Networking Hub & Switch review on the Belkin 5-Port Network USB 2.0 Hub helpful to you?
 Report Abuse  (2)  (0)  0 comments
Apr 8 2008
Hightech32
Queens, NY
Excellent Product
5.0
    Pros
  • Easy To Set Up
  • Fast
  • Reliable
    Cons
  • None
    Best Uses
  • Home
"I work for rainbow appliance but frequently work out of my house.
I have a laptop that my wife uses, a computer for the kids and one for myself.
Purchased this product so that my wife can print from the lap top and kids can print.
I didnt want to get the kids a printer for themselves.
W …"  Read Full Review »
Jun 26 2009
Jake
Staten Island NY
I am:
  • High bandwidth user
Reviewed at:
Price: $119.00
1.0
"Out of the box, the product looked great and once connected to my router found itself quickly and automatically. It also found a laser printer, multifunction printer and flash drive without effort. The problem was that the device could not find the scanner or memory readers on the multifunction prin …"  Read Full Review »
 Report Abuse  (2)  (1)  0 comments
Nov 16 2007
Nirosep
Washington, DC
Good Option
4.0
    Pros
  • Easy To Setup
    Cons
  • None
    Best Uses
  • Home network
"I've been considering getting a network drive for a long time and found many options too complicated and expensive and were not compatible with my system. So instead we got a good simple external drive. We have used 4 of our 5 ports; printer/scanner/external lacie drive/ card reader. The only compla …"  Read Full Review »
Jul 19 2008
kat
NY
I am:
  • high bandwidth user
Reviewed at:
Price: $75.99
i'd been looking at and ...
2.0
"i'd been looking at and weighing my options on this item for at least a month, trying to decide if and when to get this network hub. i finally picked it up last week, and was impressed with the ease of setup; it was up and running (including software install) in a matter of minutes. once i restarted …"  Read Full Review »
Aug 10 2009
photoguy81
Philadelphia area
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
