Close Login Module
Join
Belkin 10' Pro Series High-Integrity VGA/SVGA Monitor Replacement Cable
#1091
3.4
based on 11 reviews
Ratings Distribution
5 star
7
4 star
1
3 star
0
2 star
0
1 star
5
Category Average
4.1
$11.00 - $22.99
from 16 stores
More Images
Pros
  • Durable (2)
  • Reliable (2)
  • Highly compatible (1)
  • Improves performance (1)
  • Strong connection points (1)
See less See more
Cons
  • Limited compatibility (1)
  • No performance gain (1)
  • Unreliable (1)
  • Weak connection points (1)
Best Uses
  • Computer equipment (2)
  • Networking (1)
Where to Buy
Show all 16 stores
Product Reviews
Last update: Oct 20, 2009
Belkin 10' Pro Series High-Integrity VGA/SVGA Monitor Replacement Cable Reviews
Most helpful positive review
[7 of 7 customers found this review helpful]
Most helpful negative review
[1 of 2 customers found this review helpful]
5.0
Great Cable for big Monitors
"If you need a replacement cable for your monitor don't just buy the same [price] type that came with it. If you have a high quality monitor you will see the difference using this cable. If you have a cheap monitor you may not see the difference, but the cable will outlast your monitor. It's money well spent. It's a very high quality product. Cleared up a 'flicker' problem for me that was caused by an old cable a..." Read Full Review »
Mar 11, 2002 by Anonymous
See more positive Belkin 10' Pro Series High-Integrity VGA/SVGA Monitor Replacement Cable reviews
1.0
Abousolutly Useless
"I was using this to plug my laptop monitor into my 1080 Flat screen TV and it didnt work it all it would ever show is my background not even my icons. I was planning to have everything i did on my computer but it didnt work. This product is not what I wanted and also I called Staples and they didnt even know how to fix there own product to make it work right. I am very upset and dissapointed!..." Read Full Review »
Aug 04, 2009 by W
See more negative Belkin 10' Pro Series High-Integrity VGA/SVGA Monitor Replacement Cable reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
5.0
"If you need a replacement cable for your monitor don't just buy the same [price] type that came with it. If you have a high quality monitor you will see the difference using this cable. If you have a cheap monitor you may not see the difference, but the cable will outlast your monitor. It's money we …"  Read Full Review »
Mar 11 2002
Toronto, Ont, Canada
[3 of 3 customers found this review helpful]
Worth the extra cost.
5.0
"I was looking for a monitor cable to use with my new Avocent KVM switch and hoped that a more expensive cable would offer better signal quality. I bought this Belkin cable and a 6 ft Tripp Lite (that was a tenth of the cost) and there was a huge difference in image quality. I'm buying another one …"  Read Full Review »
Mar 5 2004
Amazon
Good Cable
5.0
"VGA is a great way to connect your LCD T.V. or monitor to your computer, and in some cases, the only way. If you want the best image possible, you must buy a good cable, and this is one of the best. It is heavy duty, long enough for just about any job, and gives a clear and crisp image. I personally …"  Read Full Review »
Jan 3 2007
Adam Hedrick
Philadelphia, PA United States
good basic monitor cable
4.0
    Pros
  • Durable construction
  • Reliable
    Cons
  • None
    Best Uses
  • Computer Equipment
  • Networking
"Good basic monitor cable. "
Oct 20 2009
spain
chicago, IL
I am:
  • Quality Oriented
[2 of 5 customers found this review helpful]
Expensive Cable that when all was said and done Failed
1.0
"I purchased this cable for my 17" flat screen monitor so that I could have a couple of extra feet to move my monitor further from the computer. Almost all monitor cables come in 6 foot lengths. At first, it worked just great. But after about 5 months of use, my monitor was very streaky, with line …"  Read Full Review »
May 20 2003
bigdaddy@winfirst.com
Sacramento, CA United States
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$11.00
$11.99
$11.99
$11.99
BizRate Rating Outstanding 9.4
$13.42
Shop CameraWorld with FREE Shipping/No Sales Tax!
$13.42
Shop WolfCamera with FREE Shipping & No Sales Tax!
$13.42
Shop RitzCamera with FREE Shipping & No Sales Tax!
$13.42
$15.26
$15.99
$17.99
$18.99
$20.00
BizRate Rating Outstanding 9.0
$20.67
$22.26
$22.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
