Behringer B215A 15In 400W 2-Way Powered Speaker +
#953
4.1
based on 9 reviews
from $299.99 - $329.99
Ratings Distribution
5 star
4
4 star
3
3 star
1
2 star
1
1 star
0
Category Average
4.4
Pros
  • Great sound quality (12)
  • Easy to connect (7)
  • Powerful (6)
  • Attractive design (5)
  • Compact (1)
  • Easy to use (1)
  • Great price point (1)
See less See more
Cons
  • Heavy / bulky (1)
  • Lack of power (1)
  • The tweeters keep blowin (1)
Best Uses
  • Basic systems (3)
  • Outdoors (2)
  • Smaller rooms / apartments (2)
  • Amateurs (1)
  • Home (1)
  • Home theater (1)
  • Monitors (1)
  • Performing arts center (1)
  • Professional (1)
  • Small to medium venues (1)
Provided by PSSL.com - ProSound and Stage Lighting
BEHRINGER B215A 15IN 400W 2-WAY POWERED SPEAKER Building on the solid success of Behringer's EUROLIVE Series, the all-new EUROLIVE B215A is a high-power 400-Watt, 2-way lightweight active PA speaker solution that delivers excellent sound even at extreme sound pressure levels. The B215A boasts an integrated sound processor that gives you the ultimate system control and offers reliable speaker protection. At its heart is an extremely powerful 15" long-excursion driver matched to a 1.25" titanium-diaphragm compression driver for incredibly deep bass and tremendous acoustic power. In addition, you get ULN Mic/Line input with volume control and peak LED plus a dedicated 2-band EQ. A Line Out connector allows you to connect additional speaker systems. Versatile trapezoidal enclosure design allows different positioning: stand mounting with 35-mm pole socket or side tilt positioning for use as a floor monitor. Ergonomically shaped handles for easy carrying and setup round out this incredible feature set.Features:High-power 400-Watt 2-Way PA sound reinforcement speaker system for live and playback applicationsUltra-compact lightweight system delivers excellent sound even at extreme sound pressure levelsIntegrated sound processor for ultimate system control and speaker protectionExtremely powerful 15' long-excursion driver provides incredible deep bass and acoustic powerState-of-the-art 1.25' titanium diaphragm compression driver for exceptional high-frequency reproductionUltra-wide dispersion, large-format exponential/conical hornUltra low-noise Mic/Line Input with Volume control and Peak LEDDedicated 2-band EQ for perfect sound adjustmentAdditional Line Out connector allows linking of additional speaker systemsVersatile trapezoidal enclosure design allows different positioning:Stand mounting with 35-mm pole socket Tilts on its side for use as a floor monitorErgonomically shaped handles for easy carrying and setupHigh-quality components and exceptionally rugged construction ensure long life
Behringer B215A 15In 400W 2-Way Powered Speaker + Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 29, 2009
Behringer B215A 15In 400W 2-Way Powered Speaker + Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
[5 of 5 customers found this review helpful]
For Price vs Performance, two thumbs up!
4.0
    Pros
  • Clear Sound
  • Easy To Use
  • Great Price Point
  • Powerful
    Cons
  • None
    Best Uses
  • Amateurs
  • Home
  • Professionals
"Having used exclusively Mackie products with my Karaoke Production company, I didn't expect miracles when I picked up a pair of these to use as low-cost monitors...Boy was I surprised! While the cost may be low, the build quality, sound quality, and overall performance of these speakers is competiti …"  Read Full Review »
Was this Speaker & Subwoofer review on the Behringer B215A 15In 400W 2-Way Powered Speaker + helpful to you?
 Report Abuse  (5)  (0)  0 comments
Feb 23 2007
BrewCityMusic
Lake Geneva, WI
Fantastic Product!
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Great Sound Quality
    Cons
  • None
    Best Uses
  • Basic Systems
  • Home Theater
  • Smaller Rooms
"I'm a small time mobile dj and i do primarily fraternity and house parties with a couple of middle size rooms with my brother. I have to say - Thia product surprised the heck out of me. It sounds great, and gives a nice boom. Great value for the price ive gotten two and havn't looked back.
Keep i …"  Read Full Review »
Aug 25 2009
Arty V
Chicago, IL
I am:
  • Movie Enthusiast
  • Practical
  • Professional
  • Tech Savvy
  • Technically Challenged
Reviewed at:
Price: $329.99
These speakers are no bueno.
2.0
"I am a professional DJ and have been for years. I used these speakers and figured out they are no good at all. Stick with the wood enclosed 1220A Eurolive series if you want quality. They are comparable to the Yorkville NX55P powered speaker.
Don't call yourselves DJs if you use these. You obviousl …"  Read Full Review »
Oct 29 2009
SOUNDTECH1
TEXAS
I am:
  • Professional
[2 of 2 customers found this review helpful]
Simply The Best and Affordable!
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Outdoors
"I have two of these and bought them 6 months ago and let me tell you, they blew me away...the sound quality is very very good and are comparable to Mackie active speakers which cost more. Don't think twice if you're planning on getting one. You won't regret it. And also it has the controls that you …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Feb 3 2009
crazyberns
Miami, FL
I am:
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Price: $329.99
[2 of 5 customers found this review helpful]
You get more than what you pay for
4.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Monitors
  • Small to Medium Venues
"Bought two pairs to use as monitors and small gigs. I was surprised at the sound quality. They were great. I have used them as monitors at clubs and medium to large venues. I have used them as mains for small venues. In all cases they have performed superbly. I'm impressed and so are my fellow …"  Read Full Review »
 Report Abuse  (2)  (3)  0 comments
Mar 13 2008
Chill TPRB
Inland Empire, CA
I am:
  • DJ
  • Musically Inclined
  • Professional
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
