BEACONS LLC BEDSIDE LED COASTER
4.3
based on 138 reviews
from $24.95
Ratings Distribution
5 star
69
4 star
53
3 star
7
2 star
2
1 star
7
Category Average
0.0
$24.95 at Brookstone
Find it at Amazon
Find it at Ebay
Pros
  • Neat features (85)
  • Reliable (73)
  • Easy to set (55)
  • Easy to use (4)
  • Convenient (3)
  • Good volume (3)
  • Dependable (2)
  • Nothing to set (2)
  • Unique (2)
  • A nessasary device (1)
See less See more
Cons
  • Unreliable (9)
  • Unattractive design (5)
  • Not bright enough (2)
  • Cheap looking (1)
  • Difficult to set (1)
  • Flimsy (1)
  • Hard to install (1)
  • Need to buy batteries sep (1)
  • No adjustments (1)
Best Uses
  • Anywhere (98)
  • Travel (32)
  • Bedroom (6)
  • Home (4)
  • Bedside (2)
  • An unlit office (1)
  • As coaster for water (1)
  • Bed side partner (1)
  • Bedroom bathroom (1)
  • Bedside table (1)
Provided by Brookstone
Night light coaster turns on with just a wave of your hand--then turns off automatically after 30 seconds. The soft, ambient LED light makes it easy to find what you're looking for and navigate safely in the dark without disturbing others, while the 30-second auto shutoff makes it easy to fall back asleep again. Use the water-resistant, rimmed unit as a coaster and watch the light shine gently through your glass of water, or use it to hold other personal items like glasses. The cordless design can be moved anywhere you need extra light at night. Uses 4 AAA batteries (not included). 6 1/2" w x 4 1/2" d x 1 1/4" h.
It's a motion-sensitive night light...
No fumbling for a switch--just wave your hand to turn it on. Gives a soft ambient light that makes it easy to find objects or move around the room, yet won't disturb other sleepers. Turns off automatically after 30 seconds, so you can fall back to sleep effortlessly.
...and a coaster, too
Water-resistant and sized to hold a water glass, it's the perfect way to keep a nighttime drink in easy reach.
BEACONS LLC BEDSIDE LED COASTER Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jul 10, 2009
BEACONS LLC BEDSIDE LED COASTER Reviews
Most helpful positive review
Most helpful negative review
5.0
I would buy this again and again
"I have certain illnesses that often require me either to wake up and look for medications or other things on my night stand or get up and come in or out of the bedroom this exudes a light that is just enough to let me find my way in the dark but isn't so bright as to wake myself or others by needing to move about so much or stimulate the mind with bright light. It has a motion detector that reaches across the ro..." Read Full Review »
Nov 15, 2008 by bunny
See more positive BEACONS LLC BEDSIDE LED COASTER reviews
1.0
Disappointed in Night Light Coaster
"I was dissapointed in the Night Light Coaster, as it would not light up with the wave of the hand. I had to tap it on the table, which obviously defeated the purpose. I took it back to the local store and they just happened to have one that had been accidentally sent to the store. The clerk tried to make it work and didn't have any better success. The quality control seemed to be lacking on the release of th..." Read Full Review »
Jan 16, 2009 by Ty the Bicker
See more negative BEACONS LLC BEDSIDE LED COASTER reviews
Displaying 1 - 5 of 138 Reviews
Show
Sort by
5.0
    Pros
  • Easy To Set
  • Neat Features
  • Reliable
    Cons
  • None
    Best Uses
  • at home
  • Travel
"I have certain illnesses that often require me either to wake up and look for medications or other things on my night stand or get up and come in or out of the bedroom this exudes a light that is just enough to let me find my way in the dark but isn't so bright as to wake myself or others by needing …"  Read Full Review »
Was this review on the BEACONS LLC BEDSIDE LED COASTER helpful to you?
Nov 15 2008
bunny
Tennessee
I am:
  • Enthusiast
Reviewed at:
Price: $24.95
Useful night light for thirsty sleepers
4.0
    Pros
  • Neat Features
  • Reliable
    Cons
  • No adjustments
    Best Uses
  • Anywhere
"My girlfriend likes to drink water during the night, so this little night light really fit the bill for her needs. It is very simple to set up--just pop in the four AAA batteries and it is ON. The subdued blue light is perfect for all glass cups, and just bright enough for her to find the glass and …"  Read Full Review »
Feb 13 2009
The Gift Giver
San Mateo, CA
I am:
  • Enthusiast
Reviewed at:
Price: $24.95
Bought it and got it
5.0
    Pros
  • Neat Features
  • Reliable
    Cons
  • None
    Best Uses
  • Anywhere
"I bought three of these to give as Christmas gifts and when they came I was wishing I had gotten myself one. Well, my boss overheard me telling a co-worker about them and he included one in my Christmas gift. I LOVE it. I have it on my nightstand and it works great. I keep my eye glasses on it a …"  Read Full Review »
Jan 10 2009
LuLu
Pennsylvania
I am:
  • Enthusiast
Reviewed at:
Price: $24.95
I would recommend this product!
5.0
    Pros
  • Easy To Set
  • Reliable
    Cons
  • None
    Best Uses
  • Anywhere
  • Travel
"I bought several of these for gifts as I just love mine! I always go to bed with a drink and when the room is dark it is harder to find your drink without knocking it over, the light on this lights up immediately, when you move fairly close to the unit it lights up so it also has a motion senser wh …"  Read Full Review »
Jan 4 2009
Cheryl the Shopper
Ft. Worth, TX
I am:
  • Casual User
Reviewed at:
Price: $24.95
1.0
    Pros
  • None
    Cons
  • Difficult To Set
  • Unattractive Design
  • Unreliable
    Best Uses
  • Anywhere
"I was dissapointed in the Night Light Coaster, as it would not light up with the wave of the hand. I had to tap it on the table, which obviously defeated the purpose. I took it back to the local store and they just happened to have one that had been accidentally sent to the store. The clerk tried …"  Read Full Review »
Jan 16 2009
Ty the Bicker
Houston, TX
I am:
  • Casual User
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
