B52 MATRIX-2000 3-Piece Powered Speaker System *
#193
4.7
based on 10 reviews
Ratings Distribution
5 star
7
4 star
3
3 star
0
2 star
0
1 star
0
Category Average
4.4
$1,499.99
from 1 store
More Images
Pros
  • Great sound quality (12)
  • Attractive design (6)
  • Powerful (6)
  • Easy to connect (5)
  • Easy setup (2)
  • Accurate controls (1)
  • Bass kicks major *behind (1)
  • Durable (1)
  • Ear plugs please (1)
  • Good power output (1)
See less See more
Cons
  • Heavy / bulky (6)
  • Difficult to set up (2)
  • 2nd floor nightmare (1)
  • No cables (1)
  • No stands (1)
  • Subwoofer heavy for one (1)
  • The sub (1)
Best Uses
  • Large rooms (6)
  • Basic systems (4)
  • Smaller rooms / apartments (4)
  • Outdoors (2)
  • 200 or less crowd (1)
  • Banquet halls (1)
  • Best for any size room (1)
  • Entertainment (1)
  • Everything (1)
  • Holiday parties (1)
Provided by PSSL.com - ProSound and Stage Lighting
B-52 MATRIX-2000 Powered Speaker SystemThe B-52 Matrix 2000 is a complete sound reinforcement solution consisting of a pair of 12" 2-way speakers and an 18" subwoofer, equipped with a built-in 1200 watt 3-channel amplifier. The 3-channel amplifier houses all the electronics required to run the system including electronic crossovers, equalization and compressors. The electronic circuity is fine tuned to match all of the components for the best possible sound. The MATRIX 2000 is designed for easy operation, as you do not need to tweak frequencies or finesse levels. To set-up the system's components, simply connect the XLR right and left signal cables, speaker cables and power cord and you?re ready to go!The 18" subwoofer enclosure is divided into two separate compartments. The front chamber serves as the cabinet for the cast-framed, 4" voice coil, 18" subwoofer. The rear chamber houses all of the system's electronic circuitry, which includes the amplification for all three components, power supply, compressor and preamps. The 18" subwoofer has a power handling capability of 600 watts and a nominal impedance of 8 ohms.The 12" 2-way speakers are loaded with B-52 custom designed 12" loudspeakers and 1" titanium diaphragm compression drivers, mounted to 900 x 400 constant directivity horns. The speakers are designed to be pole mounted, sit as stage monitors and have built-in (3/8" ? 16 TPI) flying hardware for permanent installations. The front panel of the 2-way speakers are convex so as to fit perfectly on to the subwoofer's front grill. Each 2-way speaker has the power handling capability of 300 watts and a nominal impedance of 4 ohms.To transport, simply move the subwoofer onto its casters and place the included cover over the subwoofer. Next, pull the included covers over the satellite speakers and close the zippers. It is recommended that you transport the subwoofer and satellites separately. You may transport all the components at the same time by placing the satellite speakers onto the subwoofer's front panel facing down. Secure the satellite speakers to the subwoofer with the included locking strap by fastening it to the bar handles on the side of the subwoofer cabinet.Features:Complete system with speakers, subwoofer, amp and more1200 watt 3-channel ampSubwoofer power output: 600 watts @ 8 ohms12" 2-way power output: 2 x 300 watts at 4 ohmsSubwoofer: 18" cast framed with 4" voice coilSub frequency response: 30-120HzTwo 12" 2-way speakers with 1" titanium compression drivers2-way frequency response: 120Hz-20kHzAmp line in and parallel out: XLRSpeaker out: SpeakonPure titanium diaphragmConstant directivity hornSatellite speakers are pole mountable or flyableCan also be used as floor wedgesFlying hardwareBaltic birch constructionBuilt-in castersStraps together for easy transportThree dust covers included2-ways speaker size (each): 23" x 14" x 13". Wt. 40 lbs.Subwoofer size: 35" x 28" x 23". Wt. 160 lbs.System size: 47" x 24" x 28". Wt. 245 lbs.
B52 MATRIX-2000 3-Piece Powered Speaker System * Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 1, 2009
B52 MATRIX-2000 3-Piece Powered Speaker System * Reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
Great System For a Working DJ
4.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • Difficult To Set Up
  • Heavy
  • No Cables
  • No Stands
    Best Uses
  • 200 or less crowd
  • Banquet Halls
  • Larger Rooms
  • SmallMedium Clubs
"I have used this system for the past year and have not found a room that it could not fill with sound. The X-over point for the satellites is a little high but the growl of the subwoofer more than makes up for it.
The system is easy enough to set up 5 distict cables and can really stand up to the …"  Read Full Review »
  • Picture of Product
Was this Speaker & Subwoofer review on the B52 MATRIX-2000 3-Piece Powered Speaker System * helpful to you?
May 23 2007
Dj Chi-ill
Chicago, IL
I am:
  • Live Sound Engineer
  • Mobile DJ
  • Musically Inclined
  • Professional
  • Tech Savvy
BRING THA NOIZE!!!
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Large rooms
  • Outdoors
  • Smaller Rooms
"I am a local DJ in the middle Georgia area( The Dirty South). We are known for getting crunk and basically rattling the walls of clubs. I first ordered this system about a year ago and I have gotten rave reviews from everyone that hears it! Now I am the proud owner of 2 Matrix 2000s and the sky is …"  Read Full Review »
Mar 24 2009
DJ RAHEEM
Fort Valley, Georgia
I am:
  • Professional
Pays for itself B52 can't go wrong...
5.0
    Pros
  • Attractive Design
  • Clear sound
  • Easy To Set Up
  • Great Sound
    Cons
  • Bulky
    Best Uses
  • Entertainment
  • Everything
  • Larger Rooms
"I bought an open box system at a good discount back in January. Three gigs later and its paid for itself. Do yourself a favor..buy this system. I'm booked up all thru the summer. :)
Subwoofer is a little on the bulky and heavy side. But it still fits inside a Yukon/Expedition with the seats down. …"  Read Full Review »
Mar 7 2007
Joe Matador
Garden Grove, CA
Great Sound
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Powerful
    Cons
  • NONE
    Best Uses
  • Basic Systems
  • Holiday Parties
  • Larger Rooms
  • Mobile DJ
  • Smaller Rooms
"I bought these about two years ago. I use the Matrix system for all my parties. A DJ friend of mine recommended another brand. I am glad that I got these instead. It has the best sound and will rock the walls of most buildings. B-52's rock. I will purchase another set to add on for larger part …"  Read Full Review »
Jan 30 2008
DJ J2Smooth
Pensacola, FL
I am:
  • Mobile DJ
  • Practical
  • Professional
  • Tech Savvy
Great Sound and giving you the bass!!!
5.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Home Theater
  • Outdoors
  • Smaller Rooms
"This product is very powerful man i know this because i live in an apartment and their was an dj that was in the back playin music from them and i live on the 5th floor and i could feel the bass from where i was and the vocals the are coming from it,man it was jus incredible "
Feb 7 2009
DJMixxfest
Landover Hills, MD
I am:
  • Professional
  • Technically Challenged
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
