#6
based on 15 reviews
Ratings Distribution
| 5 star |
11 |
| 4 star |
4 |
| 3 star |
0 |
| 2 star |
0 |
| 1 star |
0 |
Category Average
$58.99
from 1 storeWhere to Buy
Product Reviews
Displaying 1 - 5 of 15 Reviews
B-Tech BT77 UltraGrip Pro Speaker Wall Mounts Review
Pros
Cons
Best Uses
"Used these to mount my Polk Audio Bookshelf Speakers as my rear surrounds, the mount was very easy to put together, I mounted it to studs and just clamped the mount to the speaker. I applied the extra grip that comes with the mount onto the bracket and didn't even need to screw the mount to the spea …" Read Full Review »
Pros
Cons
Best Uses
"I'm pushing to weight limit on these mounts with 53lbs main speakers as surrounds. So when I intalled them I hung on them to see if they would support my full weight and they did. First rate product. "
Pros
Cons
Best Uses
"These are the best most versatile mounts I've ever seen. Simple to mount, fully adjustable up (+7 deg) and down (-7 deg) from level with 360 rotation (once speaker is attached it probably won't be able to rotate a full 360, but you never need 360 rotation post-install anyway). Start to finish we got …" Read Full Review »
Pros
Cons
Best Uses
"I installed these babies on the back wall in my basement to hang the Klipsch RB-61 speakers on. They are currently my "Surround-Back" speakers. I have to say I'm extremely impressed with these wall mounts. I was able to hang on them, with my feet off the ground, and they didn't budge. I weigh abo …" Read Full Review »
Pros
Cons
Best Uses
"These are great brackets. I was looking to spend less, but brackets in the $30 range were too flimsy and designed for smaller surround speakers. I'm using these to wall mount my Klipsch 1.5's and they're extremely solid. Although it's recommended to install in a wall stud, one of mine is not due …" Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
