based on 12 reviews
Ratings Distribution
| 5 star |
10 |
| 4 star |
2 |
| 3 star |
0 |
| 2 star |
0 |
| 1 star |
0 |
Category Average
$19.42
from 1 storePros
Cons
Best Uses
Where to Buy
| No Tax Outside NY ends 09/09/15 |
BizRate Rating
Outstanding 9.7
Product Reviews
Displaying 1 - 5 of 12 Reviews
[2 of 2 customers found this review helpful]
B+W 62mm to 77mm Step-Up Ring (Lens to Filter) #1b Review
Pros
Cons
Best Uses
"DO NOT skimp on step rings! If you use a generic ring, you will be extremely frustrated when your filter or close up lens gets stuck on! It can take an hour to separate them after sitting in your vehicle with the heater cranked and sweat running off your face. If you buy junk you will buy twice. "
Pros
Cons
Best Uses
"I bought sizes from 52 to 72mm to step up to 77mm. All are very nicely made, sturdier and smoother than the cheaper ones I had. "
[2 of 3 customers found this review helpful]
Pros
Cons
Best Uses
"use this on 62mm 20mm lens- to step up from 62 to 77mm - it widens the edge of the lens and no worry about any edge glare wide open at 2.8 - got the idea from ken rockwell on his website - works great - thanks B&H [...]- norm "
[1 of 2 customers found this review helpful]
Pros
Cons
Best Uses
"To begin with, I was impressed with by the hard plastic case that comes with the B+W step-up rings. The 62mm to 72mm ring I purchased is a nicely machined unit. I hope to get years of use out of it. "
[1 of 1 customers found this review helpful]
"I use this on my Nikon 20mm 2.8 lens. I have all professional 77mm filters and this lens uses the awkward size 62mm filters.
This B&W step up ring is not plastic and seems to get the job done. One complaint is that if I screw a filter just slightly too tight, I have to remove the step up ring from
Read Full Review »
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.7
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
