AVF Group Nexus Studio Range Single Arm, Cantilever, Swivel and Tilt LCD Mount
#449
4.4
based on 9 reviews
Ratings Distribution
5 star
4
4 star
5
3 star
0
2 star
0
1 star
0
Category Average
4.4
$74.30 at Mounts and More
Find it at Amazon
Find it at Ebay
$74.30
from 1 store
Pros
  • Sturdy (8)
  • Adjustable (6)
  • Easy to install (6)
  • Interfaces well with tv (6)
  • Multiple viewing angles (6)
  • Worked out well. (1)
See less See more
Cons
  • Hard to install (1)
  • Metric fastener defective (1)
  • Metric screws defective (1)
  • Needs better instructions (1)
  • Upgraded hardware needed (1)
Best Uses
  • Bedroom (3)
  • Changing viewing angle (3)
  • Garage (3)
  • Home (3)
  • Family room (1)
Provided by Mounts and More
The Studio Range Series by AVF is an LCD Mount line that showcases a compact and practical design for mid sized LCD TV's. Featuring a Screen Mounting Plate Design which provides full VESA compatibility up to 200mm. The patented Cam Box mechanism allows for easy screen tilting. The LCD503 can extend up to 17" for ideal corner mounting.
Features:
  • Fits most 12-32" LCD screens
  • Weight Capacity: 66 lbs
  • VESA 75/100/200mm compatible
  • 180ยบ swivel at the screen and wall for viewing flexibility
  • Tilt and swivel design
  • Reaches up to 17" for angled viewing
  • Can be folded flat against the wall
  • Cable management from the screen through the wall plate cover
  • Lifetime warranty
LCD503 Studio Range Single Arm, Cantilever, Swivel and Tilt LCD Mount Technical Data
Need professional installation? Use the or the ! Give us a call with any questions!
AVF Group Nexus Studio Range Single Arm, Cantilever, Swivel and Tilt LCD Mount Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jan 12, 2009
AVF Group Nexus Studio Range Single Arm, Cantilever, Swivel and Tilt LCD Mount Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
Good LCD Mount
4.0
    Pros
  • Easy To Adjust
  • Interfaces Well With TV
  • Multiple Viewing Angles
  • Sturdy
    Cons
  • None
    Best Uses
  • Changing Viewing Angle
  • Home
"The mount has been quite good. It strong enough for my 32 inch LCD TV. I like that I can have it in one position when I am at my desk using my TV as my computer monitor. Then pull the TV away from the wall (closer to the couch) for watching TV. Then put the TV back to the wall on the other side …"  Read Full Review »
Was this TV Wall Mount review on the AVF Group Nexus Studio Range Single Arm, Cantilever, Swivel and Tilt LCD Mount helpful to you?
Mar 14 2008
leftear
Moab, UT
I am:
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Price: $74.30
Installed 3 of these & they are great.
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • none
    Best Uses
  • Bedroom
  • Garage
"Now that I have installed 3 of these, it does get easier. The hardest part was finding that silly 2x4 but also dealing with metal bracing that is required for homes on the south coast region for protection against hurricanes. Another reason I purchased this model is the weight capacity which is li …"  Read Full Review »
Apr 20 2008
Sarge
Texas
I am:
  • Gearhead
Reviewed at:
Price: $74.30
LCD 503 Review
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
    Best Uses
  • Garage
"Overall it went well. Spent more time finding the silly stud to mount the LCD 503 to. I hung a Sylvania 20 inch that weighs only 11 lbs. I like the 4 screws to attach the 503 to the wall. More support even with this low weight. I may buy another to use in another room. Had issue with the defec …"  Read Full Review »
Mar 30 2008
The Sarge
Santa Fe, Tx.
I am:
  • Tech Savvy
Reviewed at:
Price: $74.30
Item works fine for me
4.0
    Pros
  • Sturdy
    Cons
    Best Uses
  • Bedroom
"Plate mounted to swing arm from factory was upsidedown - got that corrected and all went well - could ahve a little better mounting instructions especially all the plastic inserts - doesn't fold against the wall as tight as I would like - however it does the job for me - veiwing angls is great for m …"  Read Full Review »
Jun 18 2008
Sparky
Upstate NY - way north of Albany
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Price: $74.30
LCD 503 Review
4.0
    Pros
  • Easy To Install
  • Sturdy
  • Worked out well.
    Cons
    Best Uses
  • Garage
"Overall it worked out well. I liked the 4 large screws to mount it to the stud. The 20 inch LCD tv weighs only 11 lbs. I had a issue with a couple of metric fasteners being not meeting up with ASTM Standards. I worked out that problem and the system looks good in my garage. "
Mar 30 2008
The Sarge
Santa Fe, Tx.
I am:
  • Gearhead
Reviewed at:
Price: $74.30
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
