Audiovox Virtual Surround Sound Speaker
4.2
based on 6 reviews
Ratings Distribution
5 star
1
4 star
5
3 star
0
2 star
0
1 star
0
Category Average
4.1
$117.13 - $132.68
from 6 stores
More Images
Pros
  • Easy setup (4)
  • Great sound quality (4)
  • Interfaces well with tv (4)
  • Confusing / difficult controls (3)
  • Decent bass for the size (1)
  • Extra auxiliary plugs (1)
  • Unbeatable price (1)
See less See more
Best Uses
  • Living room (4)
  • Movies (4)
  • Television shows (3)
  • Smaller rooms / apartments (1)
  • Surround sound solution (1)
Provided by Overstock.com
*Acoustic Research All-In-One virtual surround speaker system *Stereo component system features three 2.5-inch full range speakers *Speaker set has 5.2-inch built-in powered subwoofer *Remote control included *Patented virtual surround technology *Simple to use, easy set up *3 audio inputs, subwoofer output *Digital clock, piano gloss finish, soft touch front panel controls *This advanced proprietary circuitry processes the audio signal and creates a surround sound field through specially designed and angled speaker elements *The technology uses reflections from the wall surfaces to produce a spatial effect that surrounds the listener with sound, putting them in the middle of the action *37.6 inches wide x 9.8 inches deep x 7.3 inches high
Audiovox Virtual Surround Sound Speaker Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Feb 17, 2009
Audiovox Virtual Surround Sound Speaker Reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
Dynamite in a small package
4.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Interfaces Well With TV
  • Intuitive Controls
    Cons
  • None
    Best Uses
  • Living Room
  • Movies
  • Television Shows
"This product is recommended for flat screen TVs, but also works well for older TVs. I have a Sony Trinitron 27" TV that I bought in 1996. The picture is better than less expensive flat screens and even some higher priced flat screens, so I want to use this TV as long as possible. When I saw this …"  Read Full Review »
Was this Home Theater review on the Audiovox Virtual Surround Sound Speaker helpful to you?
Feb 17 2009
Durty Harry
Laramie, Wyoming
I am:
  • Practical
  • Tech Savvy
Reviewed at:
[1 of 1 customers found this review helpful]
Acoustic Research does it again
5.0
    Pros
  • Clear Sound
  • Decent Bass for the size
  • Easy To Setup
  • Extra Auxiliary Plugs
  • More »
    Cons
  • None
    Best Uses
  • Living Room
  • Movies
  • Television Shows
"This is an extremely easy product to set up. It literally is plug and play and will take you two minutes to get it going. The price is great for what you get, and it does a solid job at producing surround sound in small to medium sized rooms. It has two additional auxiliary plugs for adding a powere …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jun 11 2008
Rick
Raleigh, NC
I am:
  • Musically Inclined
  • Tech Savvy
Reviewed at:
Perfect for me
4.0
    Pros
  • Clear Sound
  • Easy To Setup
    Cons
  • None
    Best Uses
  • Living Room
  • Movies
  • Smaller Rooms
  • Surround Sound Solution
"A simple solution to poor flat-screen TV sound, without all of the mess and expense of a surround system. Great for bassy movies, self powered so you don't need to run it through a separate stereo system, and has a subwoofer output if the built-in subwoofer isn't deep enough for your taste (it is fi …"  Read Full Review »
Feb 29 2008
Sunslip
Durham, NC
I am:
  • Tech Savvy
Reviewed at:
Perfect for my needs
4.0
"It's a pretty simple system with rich, dynamic sound--way better than my built-in flatscreen HDTV speakers (which blew the first week!)--and affordable and cool looking. And it's got it's own amp so you don't need to run it through your stereo system, which is perfect for me because I prefer stereo …"  Read Full Review »
Feb 21 2008
sunslip
Durham, NC
Reviewed at:
Good Product
4.0
    Pros
  • Clear Sound
  • Easy To Setup
    Cons
  • None
    Best Uses
  • Living Room
  • Movies
  • Television Shows
"I use the product in conjunction with my LCD television. Mainly for movies and some cable TV shows. The product performs as advertised and for the price priduces acceptable sounds. "
May 16 2008
Smeeky
Wilderness, VA
I am:
  • Tech Savvy
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
