Audiovox VE727 7" Drop Down LCD TV / DVD Player
#386
3.0
based on 6 reviews
Ratings Distribution
5 star
1
4 star
2
3 star
1
2 star
0
1 star
2
Category Average
4.4
$169.99 - $230.73
from 13 stores
More Images
Pros
  • Attractive design (5)
  • Fast setup (2)
  • Great picture quality (2)
  • Good connection options (1)
  • Great sound quality (1)
  • High resolution (1)
  • It's digital (1)
  • No wasted counter space (1)
  • Simple / intuitive controls (1)
  • Simple controls (1)
See less See more
Cons
  • Bad interface (2)
  • Poor connection options (2)
  • Difficult to use (1)
  • Dvd quit (1)
  • Narrow viewing angle (1)
  • Poor reliability (1)
  • Poor sound quality (1)
Best Uses
  • Kitchen (4)
  • Home (1)
  • Movies (1)
  • Soaps (1)
  • Undercounter mounting (1)
Provided by Meijer.com
The Audiovox VE727 7" LCD drop-down TV with built-in slot-load DVD player is the perfect addition to your kitchen, garage, boat, or RV, enabling you to catch your favorite movies or TV shows no matter where you are. Then, when you've had enough TV for one day - turn on the radio. The VE727 includes a built-in AM/FM radio tuner, so you can listen to your favorite tunes and radio programs. It simply mounts under a cabinet to keep counter space clear, while the swivel screen makes it easy to get a great view from anywhere in the room. Featuring a 16:9 widescreen aspect ratio, built-in ATSC digital TV tuner, front panel operation, built-in speakers, A/V output, and a wireless remote control, it's a whole lot of pizzazz in a tiny little space.
Specification Description
Model AUDVE727, AVXVE727, VE-727, VE727
UPC 044476040016
Aspect Ratio 16:9
color null
Combo Unit Built-in DVD Player and Radio
Disc Capacity 1
HDTV Capable HD Tuner is included
Screen Format 16:9 Widescreen TV Imaging
Screen Size 7"
Screen Size 7" Diagonal
Screen Size (Inches/Diagonal) 7
size null
sku 62399
skuprice 219.9900
style AUDVE727
taxable Y
TV Type TV/DVD Combo
Type of DVD Unit Portable DVD Player
Audiovox VE727 7" Drop Down LCD TV / DVD Player Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jan 23, 2009
Audiovox VE727 7" Drop Down LCD TV / DVD Player Reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
A Great Digital Purchase!!!!!
5.0
    Pros
  • Attractive Design
  • Bright Image
  • Fast Setup
  • Good Connection Options
  • Good Resolution
  • More »
    Cons
  • None
    Best Uses
  • Home
  • Kitchen
  • Movies
  • Soaps
"I didn't realize when I purchased it, that this was a digital tv. I wanted an under-the-counter tv with a dvd player for watching while at the kitchen table, cooking, canning, baking, etc. The screen can be viewed from and direction because it swivels and it has a magnetic remote that sticks to the …"  Read Full Review »
Was this LCD TV review on the Audiovox VE727 7" Drop Down LCD TV / DVD Player helpful to you?
 Report Abuse  (2)  (0)  0 comments
May 12 2008
sdmtscgamma
Mishawaka, IN
I am:
  • Practical
Reviewed at:
[1 of 1 customers found this review helpful]
Buyer Beware
1.0
    Pros
  • Attractive Design
  • Undercounter Mounting
    Cons
  • Bad Interface
  • Poor Connection Options
  • Poor Reliability
  • Poor Sound
    Best Uses
"This is the worst investment in a kitchen TV. I bought the unit because it saves space with its mounting option. As these units become less available from manufacturers in favor of LCD Flat screens,the quality of them is alot worse. There are no aux RCA inputs to hook up an external tuner (cable or …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jan 23 2009
Stratoblaster
New York
I am:
  • Enthusiast
Reviewed at:
Price: $169.99
Nice picture but....
3.0
    Pros
  • None
    Cons
  • DVD Quit
    Best Uses
  • Kitchen
"The TV works great, but the DVD quit working after a year of owning it. Not covered under warrenty, so all we use it for now is the TV. Great picture. Everyone who comes into our kitchen loves this feature in it. Looking to replace it with something else for the sake of a useable DVD player. "
Dec 8 2007
ranger
Michigan
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Terrible do not buy
1.0
    Pros
  • Attractive Design
    Cons
  • Bad Interface
  • Difficult to Use
    Best Uses
  • Kitchen
"installed fine and worked - then went bad
Started cycling between the memorex logo and the TV guard setup menu. Couldn't get it past the looping. Called Memorex support - told me to take back to store - Dont have receipt anymore so no luck - bought a second one and hooked it up - and guess what s …"  Read Full Review »
Oct 14 2008
magicman
pitt pa
I am:
  • Power User
Reviewed at:
This is working great!
4.0
    Pros
  • Attractive Design
  • Fast Setup
    Cons
  • Narrow display view angle
    Best Uses
  • None
"Got the system installed easily and the tuner is working well with a simple UHF antenna to pull in the digital channels off-air. The remote/menus were simple to pick and choose stations. The screen is a little small and the contrast could be a bit better (narrow viewing angles), but it is serving it …"  Read Full Review »
Jan 23 2009
hotspur1
Newton, MA
I am:
  • Enthusiast
Reviewed at:
Price: $169.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
