Audioengine AW1 Wireless Adapter
#974
3.9
based on 13 reviews
Ratings Distribution
5 star
8
4 star
2
3 star
0
2 star
0
1 star
3
Category Average
4.4
$149.00
from 4 stores
Pros
  • Easy to connect (11)
  • Great sound quality (9)
  • Attractive design (4)
  • Compact (4)
  • Crisp sound (3)
  • Powerful (2)
  • Configures as usb audio (1)
See less See more
Cons
  • Poor sound quality (3)
  • Flexible dongle - why (1)
  • Not very powerful (1)
Best Uses
  • Basic systems (3)
  • Home theater (2)
  • Connected laptop to pa (1)
  • Outdoors (1)
  • Smaller rooms (1)
Provided by OneCall
Unwire your music
Hear all your music - no dropouts, static, or noise. Some pretty clever engineering means your music remains free from interference from wireless routers, cordless and mobile phones, microwave ovens, Bluetooth and WiFi devices.
Easy setup
Most wireless audio products are difficult to use because they require you to download and install software, set up a network, and often require you to manually try to find a clear audio channel. The AW1 is plug-and-play so no software installation is needed - just connect both dongles to USB power (or to a USB battery pack), connect the audio cables, and wait 2 to 3 seconds for the status lights to go solid. Two stereo mini cables and an RCA adapter cable are included for easy connection to all your gear.
  • Audioengine products are now 100% lead-free and meet the EU's RoHS initiative
  • All speaker cabinet materials use environmentally-friendly binders and resins
  • Formaldehyde-free adhesives are used in our cabinet assembly
  • All Audioengine products meet ENERGY STAR requirements in standby
  • Limited use of plastics in our products
  • Easy-to-recycle packaging
  • Specification Description
    Model AW1
    UPC 819955130010
    Connectivity Type Audio / Video
    Audioengine AW1 Wireless Adapter Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 9, 2009
    Audioengine AW1 Wireless Adapter Reviews
    Most helpful positive review
    Most helpful negative review
    5.0
    As advertised and then some
    "After researching this product, I wasn't necessarily surprised at its ease of use or great performance. What was surprising though was that it configures as a USB Sound Card, which either I missed in the descriptions or isn't stated. This means that you don't need to patch the input of the transmitter to the headphone jack if you use it on a computer. (Patch cord is still required if using a standalone music ..." Read Full Review »
    Jan 06, 2009 by KenBob
    See more positive Audioengine AW1 Wireless Adapter reviews
    1.0
    DOESN'T WORK
    "Unit does not work as advertised. It is subject to drop-offs and interference from neighbors WIFI transmissions. As such the unit is unusable to send Internet Music from my PC to my Audio Receiver not more than 30 feet away in another room. I will instead purchase RF-Link AVS-5808 5.8GHz Wireless 8-Channel Indoor Audio/Video Transmitter/Receiver System...." Read Full Review »
    Dec 17, 2008 by woody
    See more negative Audioengine AW1 Wireless Adapter reviews
    Displaying 1 - 5 of 13 Reviews
    Show
    Sort by
    Great Product!
    5.0
      Pros
    • Easy To Connect
    • Great Sound Quality
      Cons
    • None
      Best Uses
    • None
    "This product does exactly what is says it will and does it exceptionally well. The wireless transmission of sound to the speakers was flawless and you couldn't tell that the speakers weren't wired. "
    Was this Speaker & Subwoofer review on the Audioengine AW1 Wireless Adapter helpful to you?
    Nov 9 2009
    Don
    Dayton, Oh
    I am:
    • Audiophile
    • Practical
    • Tech Savvy
    Reviewed at:
    Price: $149.00
    5.0
      Pros
    • Attractive Design
    • Compact
    • Configures as USB Audio
    • Easy To Connect
      Cons
      Best Uses
    • None
    "After researching this product, I wasn't necessarily surprised at its ease of use or great performance. What was surprising though was that it configures as a USB Sound Card, which either I missed in the descriptions or isn't stated. This means that you don't need to patch the input of the transmi …"  Read Full Review »
    Jan 6 2009
    KenBob
    El Paso TX
    I am:
    • Musically Inclined
    • Professional
    • Tech Savvy
    Reviewed at:
    Price: $149.00
    [3 of 3 customers found this review helpful]
    Great device
    5.0
      Pros
    • Compact
    • Easy To Connect
      Cons
    • None
      Best Uses
    • None
    "Works perfectly. Easy set-up. This replaces an Apple Airport Express which was difficult to configure with a PC. Great sound quality. I added a Y adapter to listen through the PC speakers and the stereo. "
     Report Abuse  (3)  (0)  0 comments
    Oct 12 2008
    R
    Boston, MA
    I am:
    • Practical
    • Professional
    • Tech Savvy
    Reviewed at:
    Price: $149.00
    Great product!
    5.0
      Pros
    • Attractive Design
    • Crisp Sound
    • Easy To Connect
    • Powerful
      Cons
    • None
      Best Uses
    • Basic Systems
    "I was looking for a way to get my iTunes collection to play on my home stereo system since my two 400-CD Mega-Changers couldn't hold my collection anymore. The sound quality is just as good as the CD's. Plug-n-Play. So simple to use. This was just what I was looking for. Thanks Audioengine! "
    Sep 16 2009
    Gdhog79
    Asheville, NC
    I am:
    • Tech Savvy
    Reviewed at:
    Price: $149.00
    DOESN'T WORK
    1.0
      Pros
    • None
      Cons
    • Distorted Sound
    • Not Very Powerful
      Best Uses
    • Smaller Rooms
    5.8GHz Wirele …"  Read Full Review »
    Dec 17 2008
    woody
    mooresville,nc
    I am:
    • Audiophile
    • Tech Savvy
    Reviewed at:
    Price: $149.00
    pages: 1 2 3 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
