Atlantic Satellite Speaker Stands (Model #77305018)
4.5
based on 57 reviews
from $24.42 - $44.99
Ratings Distribution
5 star
33
4 star
20
3 star
3
2 star
1
1 star
0
Category Average
4.1
Low Price:
$24.42 at CameraWorld.com
 Trusted:
$24.42 at WolfCamera.com
Find it at Amazon
More Images
Pros
  • Attractive design (35)
  • Easy setup (28)
  • Sturdy (22)
  • Quality mounting hardware (20)
  • Easy to move (11)
  • Easy assembly (10)
  • Supports weight (9)
  • Holds all components (6)
  • Smooth edges (6)
  • Easy to wire (3)
See less See more
Cons
  • Difficult to assemble (2)
  • Adjustable ring (1)
  • Cheap plastic height lock (1)
  • Shows cables (1)
  • Tubes a little large (1)
  • Unstable (1)
Best Uses
  • Surround sound speakers (24)
  • Saving space (13)
  • Convenience (10)
  • Improving sound (6)
  • Space saver (6)
  • Decoration (3)
  • For my 4 rear speakers (1)
  • Living room (1)
  • Satellite speaker stand (1)
  • Surround sound solution (1)
Provided by CSN Stores
  • Black finish
  • Adjustable height for ensure perfect and customized sound
  • Durable heavy duty iron cast construction
  • Two sizes of mounting brackets and double-tape ensure correct installation
  • Concealed wire path for ultimate wire management solution
  • Easy assembly and installation of speakers
  • Cannot Ship to Puerto Rico
  • Any orders placed before 1:00pm EST on Monday- Thursday and before 11:00 am EST on Fridays will ship out SAME DAY!
  • Assembly Instructions
    Specification Description
    Model 77305018, ATL77305018
    UPC 031742050183
    color Black
    sku 52724 Black
    skuprice 39.9900
    style 77305018
    taxable Y
    Atlantic Satellite Speaker Stands (Model #77305018) Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 14, 2009
    Atlantic Satellite Speaker Stands (Model #77305018) Reviews
    Most helpful positive review
    [6 of 6 customers found this review helpful]
    Most helpful negative review
    5.0
    "Just what I needed!!"
    "Upright rear support clips needed trimmed slightly to accommadate my shallow depth SONY speakers. Very easy alteration with wire cutters. Nice that you have this much allowance for different size speakers! Hardware is great! Can't imagine not being able to mount just about any speaker on these!..." Read Full Review »
    Apr 15, 2008 by Joe A/V
    See more positive Atlantic Satellite Speaker Stands (Model #77305018) reviews
    3.0
    Good entry level stand for small speaker
    "Great speaker stands for the price. Exactly what I was looking for. I installed Polk Audio satellites that were a little bigger than designed for but work great when screwed to the bases. Adjusters are a bit weak, plastic. One cracked almost immediately but the height at minimum is where I set them anyway. Solid attractive heavy bases. Great bargain...." Read Full Review »
    Aug 08, 2007 by Merman66
    See more negative Atlantic Satellite Speaker Stands (Model #77305018) reviews
    Displaying 1 - 5 of 57 Reviews
    Show
    Sort by
    5.0
      Pros
    • Attractive Design
    • Easy Setup
    • Quality Mounting Hardware
    • Sturdy
      Cons
      Best Uses
    • Surround Sound Speakers
    "Upright rear support clips needed trimmed slightly to accommadate my shallow depth SONY speakers. Very easy alteration with wire cutters. Nice that you have this much allowance for different size speakers! Hardware is great! Can't imagine not being able to mount just about any speaker on these! "
    Back of speaker and upright clip
    • Picture of Product
    Trim ends of clip for thinner speakers
    Was this Home Theater review on the Atlantic Satellite Speaker Stands (Model #77305018) helpful to you?
     Report Abuse  (6)  (0)  0 comments
    Apr 15 2008
    Joe A/V
    ACME, PA
    I am:
    • Practical
    • Tech Savvy
    Reviewed at:
    Price: $39.99
    Exactly what I was looking for - value
    4.0
      Pros
    • Attractive Design
    • Built To Last
    • Easy To Assemble
    • Easy To Move
    • Very Affordable
      Cons
    • None
      Best Uses
    • For My 4 Rear Speakers
    "I rate these speaker stands 4 out of 5.0. If they would have supported my bulky Onkyo speakers without having to drill a hole, I would have immediately given a 5.
    These are well designed, high-quality speaker stands at a very low price. The speaker height can be adjusted with the stands' telescop …"  Read Full Review »
    May 16 2009
    Austrian
    Atlanta, GA
    I am:
    • Bargain Hunter
    • Practical
    Recommended
    4.0
      Pros
    • Attractive Design
    • Easy Setup
    • Sturdy
      Cons
    • None
      Best Uses
    "Happy with the stands after using them for the past 3 weeks.
    They're study, fairly attractive, and were a great price. Definitely recommended for someone who's looking for something aesthetically pleasing who doesn't want to spend several hundred dollars on stands; you can order 2 sets of these …"  Read Full Review »
    Mar 5 2008
    Ben
    Nashville, TN
    I am:
    • Tech Savvy
    Reviewed at:
    Price: $39.99
    3.0
      Pros
    • Attractive Design
    • Easy Setup
    • Sturdy
      Cons
      Best Uses
    • Improving Sound
    • Saving Space
    "Great speaker stands for the price. Exactly what I was looking for. I installed Polk Audio satellites that were a little bigger than designed for but work great when screwed to the bases. Adjusters are a bit weak, plastic. One cracked almost immediately but the height at minimum is where I set t …"  Read Full Review »
    Aug 8 2007
    Merman66
    OKC, OK
    I am:
    • Tech Savvy
    Reviewed at:
    Price: $39.99
    Good stands, Great price
    4.0
      Pros
    • Attractive Design
    • Easy Setup
      Cons
    • None
      Best Uses
    • Improving Sound
    "I use these stands for my two surround sound speakers for my Onkyo 5.1-Channel system. The stands are sturdy and a great buy for the price. The only downside is I was hoping to use the mounting screw to attach the speaker to the stand. My speakers were slightly too large to use the mounting screws …"  Read Full Review »
    Aug 22 2007
    Brendan
    Pittsburgh, PA
    I am:
    • Tech Savvy
    Reviewed at:
    Price: $39.99
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
