Asus Xonar DX PCIE 24BIT 7.1 Channel Sound Card
#25
4.8
based on 17 reviews
from $79.88 - $89.99
Ratings Distribution
5 star
14
4 star
2
3 star
1
2 star
0
1 star
0
Category Average
4.0
Low Price:
$79.88 at J&R Electronics
 Trusted:
$84.95 at B&H Photo Video
Find it at Amazon
More Images
Provided by Super Warehouse
ASUS Xonar DX audio card is designed for fine-tuned audio quality with 116dB SNR (Signal-to-Noise Ratio). It is equipped with innovative technologies like Dolby Home Theater Technologies and DS3D GX to provide crisp and clear audio quality and rich gaming sound effects. The Xonar DX is capable of delivering 35 times cleaner audio quality with 116dB SNR in comparison to most motherboard onboard audio with only 85dB SNR. While noise is unavoidable- the Xonar DX dramatically reduces the amount of background noise- and it is this distinction that allows the Xonar DX to produce as little as 1/32 (-105dB) of the total harmonics distortion versus traditional motherboard audio (-75dB). As most onboard audio only provide 80~86 dB SNR audio quality- background noises are easily heard while listening to music or playing games. The Xonar DX provides at least 30% better quality sounds than the average onboard audio. With audio architecture in Vista- users will sometimes be unable to achieve multi-channel sounds- DirectSound; and EAX 5.0 sound effects in EAX 5.0 Titled PC games. With the ASUS Xonar DX- all these problems will be solved. With support for the innovative DS3D GX 2.0 technology- the Xonar DX automatically supports the latest EAX and DirectSound HW after installation without the need to search for additional drivers or OpenAL- as most games are DS3D/DirectX compatible. Xonar DX card utilizes VocalFX- an innovative voice processing technology for users' voices to enter into the realistic gaming landscape (VoiceEX)- or to emulate the background scenes in online chats (ChatEX). It also allows them to disguise their voice pitches (Magic Voice). With all these features- users will have boundless entertainment while utilizing voice communications on the PC. Besides delivering impressive audio quality- the Xonar DX is also packed with multiple sound technologies from Dolby to deliver outstanding entertainment experiences. These include Dolby Digital Live- which converts PC or game audio content into Dolby Digital in real-time; Dolby Headphone- which creates a surround sound listening experience when using any set of headphones; Dolby Virtual Speaker- which delivers a vibrant surround sound listening experience from stereo speakers and Dolby Pro Logic IIx- which creates up to 7.1-channel surround sounds from stereo or 5.1 sources.
  • Product Description: ASUS Xonar DX- sound card
  • Device Type: Sound card
  • Enclosure Type: Plug-in card
  • Interface Type: PCI Express x1
  • Signal Processor: ASUS AV100
  • Sound Output Mode: 7.1 channel surround
  • DAC Data Width: 24-bit
  • Sample Rate: 44.1 kHz (min)- 192 kHz (max)
  • Signal-To-Noise Ratio: 116 dB
  • System Requirements: Microsoft Windows XP- Microsoft Windows XP 64-bit Edition- Microsoft Windows XP Media Center Edition 2005- Microsoft Windows Vista- Microsoft Windows Vista (64-bit versions)
Specification Description
Model XONAR DX, XONAR-DX, XONARDX, XonarDX
UPC 610839034253
Channel Support 7.1
Form Factor Internal
Platform Support PC
Asus Xonar DX PCIE 24BIT 7.1 Channel Sound Card Questions
Questions and Answers
Where to Buy
$89.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$84.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$79.88
Show all 6 stores
_
Product Reviews
Last update: Oct 17, 2009
Asus Xonar DX PCIE 24BIT 7.1 Channel Sound Card Reviews
Most helpful positive review
Most helpful negative review
4.0
First off, the quality ...
"First off, the quality and massive features that come with this card are second to none when it comes to on-board vs this. However if you don't have some good knowledge in DIY tweaking, this product could drive you to return it and get a more hands off simple plug and play. Remember to turn off on-board audio or else you could get problems. Unlike Graphic cards, this sound card does not auto prioritize upon inst..." Read Full Review »
Aug 12, 2009 by Calintz
See more positive Asus Xonar DX PCIE 24BIT 7.1 Channel Sound Card reviews
3.0
Not as easy to configure ...
"Not as easy to configure speaker system with this audio card. Some speakers have sound and some do not. Did not experience this with the sound blasters...." Read Full Review »
Jun 05, 2009 by Del
See more negative Asus Xonar DX PCIE 24BIT 7.1 Channel Sound Card reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
Value - While a bit ...
5.0
"Value - While a bit pricey, this card sounds comparable to cards I've purchased in the past costing upwards of $200. Good deal for the level of quality.
Features - definitely a different approach to sound mixing, but in a good way. Allows for multiple uses from gaming to entertainment, to computer …"  Read Full Review »
Was this Computer Speaker & Headphones review on the Asus Xonar DX PCIE 24BIT 7.1 Channel Sound Card helpful to you?
Sep 30 2009
Verchiel
Undisclosed
Reviewed at:
Price: $89.99
4.0
"First off, the quality and massive features that come with this card are second to none when it comes to on-board vs this. However if you don't have some good knowledge in DIY tweaking, this product could drive you to return it and get a more hands off simple plug and play. Remember to turn off on-b …"  Read Full Review »
Aug 12 2009
Calintz
Undisclosed
Reviewed at:
Price: $89.99
First off, read all the ...
5.0
"First off, read all the requirements for using this card. Last on the list, and probably most important, is that you need really good speakers to use this card properly. The reason is very simple: High-end speakers require less electricity to make a lot of sound, and this efficiency lets ASUS use …"  Read Full Review »
Aug 18 2009
Guardian_O
Undisclosed
Reviewed at:
Price: $89.99
One word-Wow!In the ...
5.0
"One word-Wow!In the continuing saga of trying to get the biostar780g to cooperate with all our other stuff in vista, it was decided to go to vista 64. so an audio change was required.We have always been and will be thanks to this, a Cmedia audio facility-they have the ONLY audio system i know of tha …"  Read Full Review »
Aug 30 2008
Madman Joh
Undisclosed
Reviewed at:
Price: $89.99
Pros: Nice of them to ...
4.0
"Pros: Nice of them to make a PCI Express card as my other regular PCI slots are maxxed out. It comes with a high qualilty mounting plate & terminal plugs. Be sure to read instructions on installing carefully as you need to ignore Windows disire to install on bootup, cancel it & install driver from c …"  Read Full Review »
Jul 5 2008
billbuddy
Undisclosed
Reviewed at:
Price: $89.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
