Arrow Tilt Wall Mount for 32- to 50-inch Flat Panel TVs
#505
3.5
based on 15 reviews
from $43.99 - $47.99
Ratings Distribution
5 star
6
4 star
2
3 star
3
2 star
2
1 star
2
Category Average
4.4
Low Price:
$43.99 at Overstock.com
 Trusted:
$47.99 at Bundlecity
Find it at Amazon
Provided by Overstock.com
*Arrow universal mounting system engineered from solid heavy-gauge steel *AWM4 tilt mount designed for 32-inch to 50-inch flat panel TV sets *Television accessory fits most popular flat panel plasma and LCD brands *Tilts from 15 degrees down to 15 degrees up *Fingertip viewing angle adjustments *Durable powder-coated finish *Low-profile design keeps display only 2 inches from wall *Angle position can be locked without any tools *Kit includes mounting hardware and accessories *Fits televisions up to 150 pounds
Arrow Tilt Wall Mount for 32- to 50-inch Flat Panel TVs Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 5, 2009
Arrow Tilt Wall Mount for 32- to 50-inch Flat Panel TVs Reviews
Most helpful positive review
Most helpful negative review
4.0
Nice unit
"I like this mount, works nice, easy install. Only problem was the directions make mention of some tilt adjustment knobs that do not exist. Scratched my head and moved on. The unit is easy to mount, hang, etc. Tilts by simply grabbing your tv and tilting up or down, no knobs to loosen. Spring tension holds tilt angle. Will probably buy another...." Read Full Review »
Feb 01, 2008 by Sidehatch
See more positive Arrow Tilt Wall Mount for 32- to 50-inch Flat Panel TVs reviews
3.0
Very hard to set up
"I read the other reviews before buying this product, but had no idea how hard the set-up would be. As others, I had to drill holes in the bracket to make it fit my Toshiba TV. But I had to drill them so close to another part of the bracket that the screw wouldn't go in straight. So I had to actually grind down the heads of the screws to get them to fit! Then, to my shock, I found that the holes in the wall plate..." Read Full Review »
Jun 08, 2008 by Magicbilly
See more negative Arrow Tilt Wall Mount for 32- to 50-inch Flat Panel TVs reviews
Displaying 1 - 5 of 15 Reviews
Show
Sort by
Very hard to set up
3.0
"I read the other reviews before buying this product, but had no idea how hard the set-up would be. As others, I had to drill holes in the bracket to make it fit my Toshiba TV. But I had to drill them so close to another part of the bracket that the screw wouldn't go in straight. So I had to actually …"  Read Full Review »
Was this TV Wall Mount review on the Arrow Tilt Wall Mount for 32- to 50-inch Flat Panel TVs helpful to you?
Jun 8 2008
Magicbilly
Austin, TX
Reviewed at:
Price: $43.99
holds just fine.. but what a pain..
3.0
"We looked up this model of TV mount to make sure that it would fit our TV and according to the manufacturers of both the TV and the mount, and at first glance when we laid it all out it would fit as we where told....... SO WRONG!!! the brackets where ONE INCH TO SHORT! we had to purchase pieces to e …"  Read Full Review »
May 5 2009
neojupiter
Peoria, IL
Reviewed at:
Price: $43.99
painful to install
2.0
"this was so painful to install. not one hole lined up with either my tv or any studs. also one of the rivets on the arm was broken. by the time this was discovered, my husband (who is very handy) had already spent 45 mins drilling new holes into the frame. THIS IS NOT UNIVERSAL. universally disappoi …"  Read Full Review »
Jul 25 2008
humbug1969
wyoming
Reviewed at:
Price: $43.99
Nice unit
4.0
"I like this mount, works nice, easy install. Only problem was the directions make mention of some tilt adjustment knobs that do not exist. Scratched my head and moved on. The unit is easy to mount, hang, etc. Tilts by simply grabbing your tv and tilting up or down, no knobs to loosen. Spring tension …"  Read Full Review »
Feb 1 2008
Sidehatch
Des Moines, IA
Reviewed at:
Price: $43.99
Great product
5.0
"The instructions were not written by a technical writter and that was such a blessing. The told me and showed me what I needed to know and unlike some instruction these days didn't give me a complete rundown on how they made the product. I will surely purchase this product again, when and if I need …"  Read Full Review »
Apr 14 2008
george797
oklahoma
Reviewed at:
Price: $43.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
