Arrow Cantilever Retractable Wall Mount for Flat Panel TVs
#503
4.5
based on 40 reviews
from $26.99 - $39.99
Ratings Distribution
5 star
26
4 star
8
3 star
4
2 star
2
1 star
0
Category Average
4.4
Low Price:
$26.99 at Bundlecity
 Trusted:
$39.99 at Overstock.com
Find it at Amazon
More Images
Provided by Overstock.com
*Enhance your home entertainment center with this Arrow cantilever retractable television wall mount *TV accessory has a rigid aluminum construction and anodized finish *It fits most flat panel screens up to 27 inches *VESA 75/100 mounting pattern *Swing/Rotation Angle: -90 degrees to +90 degrees *Tilt angle: -20 degrees up to 20 degrees down *Color: Silver *Material: Aluminum *Max Load (Kg/Lbs): 18kgs/40 lbs *Extension dimension from the *wall: 6.5 cm - 35.3 cm
Arrow Cantilever Retractable Wall Mount for Flat Panel TVs Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 31, 2009
Arrow Cantilever Retractable Wall Mount for Flat Panel TVs Reviews
Most helpful positive review
Most helpful negative review
5.0
Works Well
"Came fully assembled. Has its own level to make mounting easy. Provides a wide range of viewing positions for my 15" flat panel in the RV. That was why I purchased this model, and I am very happy with that aspect of its performance. It might not work as well for that if my TV was larger, but I can pull it around the corner to watch from the dinette, or push it toward the wall and watch from bed. Good product wit..." Read Full Review »
Oct 29, 2009 by pokerboss
See more positive Arrow Cantilever Retractable Wall Mount for Flat Panel TVs reviews
2.0
retractable wall mount
"this item is not sturdy enough to support the tv when extended fullly out to the side, it sags even though it says it will support up to 40 lbs. my tv was only 30 lbs. the knobs when torqued down still resulted in probably a 1" sag. the mount works fine when your tv is in the center position against the wall, but if that is what you want you wouldnt be ordering this with the swing arm. its not worth the headache..." Read Full Review »
Mar 03, 2008 by coloradobuyer100
See more negative Arrow Cantilever Retractable Wall Mount for Flat Panel TVs reviews
Displaying 1 - 5 of 40 Reviews
Show
Sort by
Works Well
5.0
"Came fully assembled. Has its own level to make mounting easy. Provides a wide range of viewing positions for my 15" flat panel in the RV. That was why I purchased this model, and I am very happy with that aspect of its performance. It might not work as well for that if my TV was larger, but I can p …"  Read Full Review »
Was this TV Wall Mount review on the Arrow Cantilever Retractable Wall Mount for Flat Panel TVs helpful to you?
Oct 29 2009
pokerboss
Southeast Texas
Reviewed at:
Price: $39.99
Great mount for the price.
5.0
"I purchased a 26" LCD/DVD combo for my bedroom and needed a wall mount. I purchased this one for the price point more than anything else. Prior to purchasing the mount, I weighed my TV and it came in at 32 pounds exactly. I didn't want to purchase a mount and find out my TV weighs too much for its r …"  Read Full Review »
Mar 12 2008
AB21
San Francisco, CA
Reviewed at:
Price: $39.99
2.0
"this item is not sturdy enough to support the tv when extended fullly out to the side, it sags even though it says it will support up to 40 lbs. my tv was only 30 lbs. the knobs when torqued down still resulted in probably a 1" sag. the mount works fine when your tv is in the center position against …"  Read Full Review »
Mar 3 2008
coloradobuyer100
arvada colorado
Reviewed at:
Price: $39.99
Best Bang for the Buck
4.0
"I had searched many stores online and actual stores. This is by far the best value for the money. It is solid aluminum. Mounting was very easy and it even came with a level to make sure you get it straight. I am very satisfied with my purchase, couldn't find it cheaper anywhere else. I used this for …"  Read Full Review »
Jan 28 2009
candyman1111
Atoka, TN
Reviewed at:
Price: $39.99
Great
5.0
"The wall mount bracket did just what I needed. It mounted quickly to a wall stud, and fit my new LCD TV. Because it is in 2 parts I could hook each piece up and then with a little help slid the Cantilever part into the wall bracket. It even included a built in level. It easily allows me to pull the …"  Read Full Review »
Mar 27 2008
Musicman2
Sacramento, CA
Reviewed at:
Price: $39.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
