Apple VESA Mount Adapter Kit for 24-inch iMac and LED Cinema Display
#434
3.5
based on 2 reviews
from $28.88 - $28.95
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
1
1 star
0
Category Average
4.4
Low Price:
$28.88 at J&R Electronics
 Trusted:
$28.95 at B&H Photo Video
Find it at Amazon
More Images
Pros
  • Compatibility (1)
  • Sturdy (1)
See less See more
Best Uses
Provided by MacMall
VESA Mount Adapter Kit for 24-inch iMac and LED Cinema Display Use this kit to attach your 24-inch iMac (2.4GHz Intel Core 2 Duo or 2.8GHz Intel Core 2 Extreme) or 24-inch LED Cinema Display to a wall mount, articulating arm, or other VESA-compliant mounting solu VESA Mount Adapter Kit for 24-inch iMac and LED Cinema DisplayUse this kit to attach your 24-inch iMac (2.4GHz Intel Core 2 Duo or 2.8GHz Intel Core 2 Extreme) or 24-inch LED Cinema Display to a wall mount, articulating arm, or other VESA-compliant mounting solution. This VESA Mount Adapter Kit allows your 24-inch iMac computer or 24-inch LED Cinema Display to be used with a variety of alternate mounting solutions such as wall mounts and zero footprint articulating arms based on the VESA flat panel mounting interface (FPMI). With a tool in this kit, you can remove the iMac or display stand and attach the VESA Mount Adapter. Then connect any VESA-compliant mounting solution with a 100mm x 100mm attachment. With the VESA Mount Adapter attached, the 24-inch iMac and 24-inch LED Cinema Display complies with the VESA MIS-D, 100, C version specification. CompatibilityWorks with 2.4GHz Intel Core 2 Duo- or 2.8GHz Intel Core 2 Extreme-based 24-inch iMac systems and 24-inch LED Cinema Display. Note: Wall mount or articulating arm not included.
Specification Description
Model MB902ZM/A
UPC 885909283217
Mount Adjustability Flat
Mount Compatibility VESA
Mount designed for Computer Monitors
Mount Size Range (from) 24
Mount Size Range (up to) 24
Select Mounting Equipment
Apple VESA Mount Adapter Kit for 24-inch iMac and LED Cinema Display Questions
Questions and Answers
Where to Buy
$28.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$28.88
Product Reviews
Last update: Feb 19, 2009
Apple VESA Mount Adapter Kit for 24-inch iMac and LED Cinema Display Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
The right stuff
5.0
    Pros
  • Compatibility
  • Sturdy
    Cons
  • None
    Best Uses
  • None
"The only choice for mounting Apple displays. My only gripe is that it can be fairly tricky to get the screws in--but this is probably a good thing since the mount is ultimately very secure. "
Was this TV Wall Mount review on the Apple VESA Mount Adapter Kit for 24-inch iMac and LED Cinema Display helpful to you?
 Report Abuse  (1)  (0)  0 comments
Feb 19 2009
LL
New York, NY
Reviewed at:
Price: $28.95
Vesa Mount Adapter Kit for 24
2.0
"I received the adapter today and began installation. The wrenches supplied for removal of screws would not work. They were the wrong size. "
Dec 8 2008
Robert Kennedy
IN
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
