Close Login Module
Join
Apevia Java 500-Watt Power Supply
4.7
based on 27 reviews
Ratings Distribution
5 star
19
4 star
7
3 star
1
2 star
0
1 star
0
Category Average
4.1
$39.99
from 2 stores
Where to Buy
Product Reviews
Last update: Oct 15, 2009
Apevia Java 500-Watt Power Supply Reviews
Most helpful positive review
Most helpful negative review
5.0
If you're seeking an ...
"If you're seeking an inexpensive but powerful power supply unit, with adequate cooling capabilities, and enough 12 volt rails to keep a mid to lower end high end system powered through all of your intensive tasks (multi-tasking, gaming, business productivity), then this is really a very good choice. Pros: Standard size, large (and I might add SILENT) fan, nice black finish, solid construction, reliability, slee..." Read Full Review »
Aug 29, 2009 by Str8Sh0t
See more positive Apevia Java 500-Watt Power Supply reviews
3.0
A very quiet PSU that ...
"A very quiet PSU that holds up very well under a full load. Has all the connections a person could want. It's not bad to look at either. Had it connected in less than ten minutes. If the price comes down I'll consider another one...." Read Full Review »
Aug 10, 2009 by only1okla
See more negative Apevia Java 500-Watt Power Supply reviews
Displaying 1 - 5 of 27 Reviews
Show
Sort by
5.0
"If you're seeking an inexpensive but powerful power supply unit, with adequate cooling capabilities, and enough 12 volt rails to keep a mid to lower end high end system powered through all of your intensive tasks (multi-tasking, gaming, business productivity), then this is really a very good choice. …"  Read Full Review »
Aug 29 2009
Str8Sh0t
Undisclosed
The first one died in ...
4.0
"The first one died in about 2 days while i was playing bioshock :(. the second one has been working for about a 3 months now and i have had no problems with it. im running a PNY Verto 9600 Gt 512 Mb, an intel pentium D 820 @ 3.00 Ghz and 2 gigs of 667 Mhz DDR2 with of course a DVD rom drive and two …"  Read Full Review »
Apr 6 2009
Xzurin
Undisclosed
Very nice. Lighter than I ...
5.0
"Very nice. Lighter than I expected, and the components inside seem very compact. Fan is silent but moves a decent amount of air.
4-pin molex connectors have a push mechanism on their sides to help you remove them from tight fitting components. The wires are of good quality and the cable sleeving is …"  Read Full Review »
Jul 24 2009
Jivix
Undisclosed
I bought this to upgrade ...
4.0
"I bought this to upgrade my 300 watt so i can use a Geforce 9800 GT. My 300 watt could stay on for months with the Geforce 8500 GT so i figured it would be ok to leave on. It died after two days as i was playing a game.(Black and White 2)
It worked wonderfully the days it was on. very quiet. It go …"  Read Full Review »
Feb 20 2009
Blackop2
Undisclosed
Any time I build a new ...
5.0
"Any time I build a new system (wich I do a lot it's my living) I use or try my hardest to use Aspire or now Apevia power supplies. This one is great for the price and works well with no complaints what so ever. Plenty of plugs on the rails one for sata and one regular rail so you have plenty to work …"  Read Full Review »
Jun 8 2009
Muppetassa
Undisclosed
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
