APC Smart-UPS 1500VA USB & Serial 120V
#337
4.2
based on 20 reviews
from $302.99 - $718.77
Ratings Distribution
5 star
14
4 star
1
3 star
0
2 star
4
1 star
1
Category Average
4.3
Low Price:
$302.99 at ClubMac
 Trusted:
$379.99 at TigerDirect
$302.99 at OnSale
see all stores
More Images
Provided by OnSale
Smart-UPS 1500VA USB & Serial 120V Gives higher application availability by correcting low and high voltage conditions without using the battery and protects connected loads from surges, spikes, lightning, and other power disturbances. Over 10 Million Currently Installed - The One You Can TrustAPC Smart-UPS protects critical data by supplying reliable, network-grade power in either traditional tower or rack-optimized form factors. Award-winning Smart-UPS is the perfect UPS for protecting business critical servers, voice and data networks, point of sale, retail/bank back office and ATM's. High real power output (watts), generous runtime, sine wave output, 16-segment LED visual display, and intelligent battery management make Smart-UPS the leading server class UPS.Included PowerChute management software provides IT administrators the comfort of safe system shutdown and advanced UPS management. Additional manageability is available through the SmartSlot, an internal accessory slot that allows installation of optional accessories to enhance the performance of your UPS. Designed and manufactured by APC and fully backed with free 24x7 technical support, Smart-UPS remains the industry standard for all network UPSs. With over 10 million units installed worldwide and over 15 years of proven performance, Smart-UPS is a UPS businesses trust for their critical applications.Smart-UPS Features:• Availability
• Gives higher application availability by correcting low and high voltage conditions without using the battery.• Maximizes battery performance, life, and reliability through intelligent, precision charging.• Protects connected loads from surges, spikes, lightning, and other power disturbances.• Prolongs battery life by regulating the charge voltage according to battery temperature.• Automatically starts up the connected equipment upon the return of utility power.• Periodic battery self-test ensures early detection of a battery that needs to be replaced.• Provides temporary battery power when the utility power is out.• Ensures clean, uninterrupted power to protected equipment when generator power is used.
• Manageability
• Monitor and control the UPS remotely via included PowerChute software or APC Network Management Card (included in all models above 3kVA).• Customize UPS capabilities with management cards.• Actively let you know if the unit is on battery, if the battery is low or if there is an overload condition.• Enables quick understanding and response to visual indicators showing UPS status.• Provides management of the UPS via a serial port.• Warns when a battery is not available to provide backup power.• Enables centralized management via the APC InfraStruXure Manager.
• Serviceability
• Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)• Ensures clean, uninterrupted power to protected equipment while batteries are being replaced• Provides early-warning fault analysis ensuring proactive component replacement.• Enables quick recovery from UPS overload events.
• Adaptability
• Saves battery power and helps extend battery life.• Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications.
• Safety
• Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment. UL, FCC, CE, C-Tick approvals.
APC Smart-UPS 1500VA USB & Serial 120V Questions
Questions and Answers
Where to Buy
$379.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$302.99
$302.99
Show all 16 stores
_
Product Reviews
Last update: Oct 23, 2009
APC Smart-UPS 1500VA USB & Serial 120V Reviews
Most helpful positive review
Most helpful negative review
5.0
Just recently build a new ...
"Just recently build a new PC with a Quad 6600 and GeForce 8800 Ultra. 2 Raptors and a 1000W power supply. My old APC XS 1000 was loaded at about 80% when my PC is full load so it was time for me to get a new APC since I got the older for about 5 years. This Smart-UPS 1500 (DLA1500) is the same unit as the SUA1500. This UPS is doing everything I wanted AVR (TRIM) AVR (BOOST) so full AVR will prevent most of the..." Read Full Review »
Feb 16, 2008 by Anonymous
See more positive APC Smart-UPS 1500VA USB & Serial 120V reviews
1.0
This UPS is so bad... ...
"This UPS is so bad... First of all It came in a recycled box with tape on it. I opened it up it included the following things: The UPS power supply. NO MANUAL NOTHING JUST THIS BIG BEAST... I plugged it in and plugged all of my cables into it. I turned it on and every light in every room in my house FLICKERED... I though everything was going to explode. I ended up having electricity only in my room and every oth..." Read Full Review »
Feb 27, 2009 by Anonymous
See more negative APC Smart-UPS 1500VA USB & Serial 120V reviews
Displaying 1 - 5 of 20 Reviews
Show
Sort by
1.0
"This UPS is so bad... First of all It came in a recycled box with tape on it. I opened it up it included the following things: The UPS power supply. NO MANUAL NOTHING JUST THIS BIG BEAST... I plugged it in and plugged all of my cables into it. I turned it on and every light in every room in my house …"  Read Full Review »
Was this Surge Protector review on the APC Smart-UPS 1500VA USB & Serial 120V helpful to you?
Feb 27 2009
Undisclosed
Reviewed at:
Price: $379.99
5.0
This Smart-UPS 1500 (DLA1500) is the same uni …"  Read Full Review »
Feb 16 2008
Undisclosed
Reviewed at:
Price: $379.99
With the recent severe ...
5.0
"With the recent severe weather and power related problems (that caused damage to my computer eqquipment) - I knew it was time to look at how to guard my power supply. After the first weather related problem, I went out and got 2 units to protect my essential computer equipment and my Internet conne …"  Read Full Review »
Sep 4 2009
McV
Undisclosed
Reviewed at:
Price: $379.99
If you need a true sign ...
5.0
"If you need a true sign wave battery backup (required for servers), this is it. I tried the basic APC 1500va backup on several servers and they would fail when the power was cut. Talked to APC tech. and they indicated that I need a smart ups with a true sign wave. I ordered this here because of th …"  Read Full Review »
Aug 26 2009
user
Undisclosed
Reviewed at:
Price: $379.99
The UPS has 1 File ...
5.0
"The UPS has 1 File Server, and 1 Webserver along with a 24 port router on it, and it only shows a load level of 2 bars! The only bad thing about this is the inablitity of the unit to shut down more then 1 unit when the UPS goes dead..... Keep that in mind if you are looking. Although I did not try …"  Read Full Review »
Jul 29 2009
KellyCPU
Undisclosed
Reviewed at:
Price: $379.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
