APC Back-UPS RS 1500VA (Model #BR1500)
#323
4.3
based on 7 reviews
Ratings Distribution
5 star
3
4 star
3
3 star
1
2 star
0
1 star
0
Category Average
4.3
$199.95 - $260.63
from 16 stores
More Images
Provided by Shoppers Choice
MODEL- BR1500 VENDOR- AMERICAN POWER CONVERSION FEATURES- Back-UPS RS 1500VA- Beige color High Performance Power Protection for Business Computers. The Back-UPS RS features advanced protection for business workstations and high-end desktops. Automatic Voltage Regulation (AVR) Technology keeps the utility voltage within safe levels without using the battery thereby extending battery life and maximizing runtime. Built-in data line protection prevents damage due to surges traveling over data lines. File-saving, auto-shutdown software with sophisticated power management is included. The Back- UPS RS is the ideal choice for applications requiring extended battery runtime. Includes Back-UPS RS unit, CD with software, Free trial of anti-virus, firewall, email privacy, system recovery and online backup software, User Manual, USB cable, Velcro Cord Management Straps. Unattended Safe & Graceful Shutdown Prevents possible data corruption by performing graceful, unattended operating system shutdown in the event of an extended power outage. Internet FAX - modem - DSL surge protection Provides protection from surges and spikes traveling on the phone line. Lightning and Surge Protection To prevent damage to your equipment from power surges and spikes. Software Use APC s software and accessories to prevent possible data corruption by performing graceful, unattended operating system shutdown and file saving in the event of an extended power outage. Customer can also quickly pinpoint power problems by tracking power data such as min/max utility voltage, line frequency and load capacity. Resettable circuit breaker Easy recovery from overloads; no need to replace a fuse. Auto Diagnostic Testing Biweekly testing of all internal components, including the battery, ensures your unit is ready when you need it. Intelligent Battery Management Actively increases battery life and system reliability using FastCharge technology, automatic battery and circuitry self-tests, and advanced diagnostics. Audible Alarms Proactively notifies you of changing UPS and utility power conditions. User Replaceable batteries With normal use, a UPS battery will last three to six years. APC s renewable UPS system eliminates the need for factory service and loss of protection by letting you replace batteries for a fraction of the cost of a new UPS. Easy Overload Recovery Push-button circuit breaker instead of a standard fuse, eliminates the need to return the unit to the factory for service. Status Indicator LED s Proactively notifies you of changing UPS and utility power conditions. Faster Recharge Time Battery can be recharged to at least 90 capacity within 2-4 hours so the unit can be prepared for the next outage. Cold-start You can power on the unit without any input power. This provides temporary emergency battery power when the utility power is out. User Replaceable batteries Save time and money by swapping the battery yourself. There is no need to send the unit to a factory service center. Hot Swap Batteries You can change the battery without powering down your equipment. Replace Battery Indicator Proactively warns the user that the battery needs to be charged or replaced soon. Overload Indicator Offers proactive notification that the UPS has too much equipment connected to it for its rated load. 150,000 Lifetime Connected Equipment Protection -- SPECIFICATIONs -------------- OUTPUT SPECs- Output power capacity: 1500 VA Output power capacity: 865 Watts Nominal output voltage: 120 V Output Connections: (6) NEMA 5-15R (2) NEMA 5-15R (Surge) INPUT SPECs - Nominal input voltage: 120 V Input frequency: 47 63 Hz Input Connection Type: NEMA 5-15P Cord Length: 6 feet Input voltage range for main operations: 88 148 V Input voltage adjustable range for main operations: 78 152 V RUNTIME - Typical backup time at half load: 12. 4 minutes (433 Watts) Typical backup time at full load: 3. 7 minutes (865 Watts) COMMUNICATIONS & MANAGEMENT- Interface port: USB Control panel: LED status display with On Line, On Battery, Replace Battery and Overload indicators. Audible alarm: Alarm when on battery, distinctive low battery alarm, configurable delays. Software: Includes APC PowerChute Personal EditionSURGE PROTECTION & FILTERING- Surge energy rating: 420 joules Filtering: Full time multi-pole noise filtering, 5 IEEE surge let-through, zero clamping response time, meets UL 1449. Dataline protection: RJ-11 Modem/Fax/DSL protection (four wire dual line) RJ-45 10/100BaseT Ethernet protection. BATTERY - Battery type: Maintenance-free sealed Lead-Acid battery with suspended electrolyte, leakproof. Typical recharge time: 6 hour(s) Replacement battery Cart: (1) RBC33APPROVALS- CSA, FCC Part 15 Class B, FCC Part 68, UL 1778 NOISE- 45 dBA at 1 meter from surface of unitSIZE - 3. 40 inchw x 14. 6 inchh x 13. 1 inchd WT. - 25. 0 lbs. Www. Apcc. Com
Specification Description
Model 10273676, BR1500
UPC 731304193128
Input Voltage 110V AC
Load Capacity 1500VA / 865W
Output Voltage 120V AC
Plug/Connector Type NEMA 5-15P
Receptacles 6 x NEMA 5-15R
Standard Warranty 2 Year(s) Limited
UPS Type Line-interactive UPS
APC Back-UPS RS 1500VA (Model #BR1500) Questions
Questions and Answers
Where to Buy
$219.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$199.95
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$209.41
Show all 16 stores
Product Reviews
Last update: Oct 15, 2009
APC Back-UPS RS 1500VA (Model #BR1500) Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
I needed a larger unit to ...
5.0
"I needed a larger unit to protect my game machine at home. Since I have been using APC for over 15 years at work and at home without ever having a problem with any unit, there was never a question of which brand I was going to buy. Over the years I have tried less expensive brands at work and have …"  Read Full Review »
Was this Surge Protector review on the APC Back-UPS RS 1500VA (Model #BR1500) helpful to you?
Oct 15 2009
John
Undisclosed
Reviewed at:
Price: $219.99
I had mine for no longer ...
3.0
"I had mine for no longer than 6 months before it died on me, i would expect longer duration of this UPS, being that its from such big name brand, tho this isn't the case. it worked alright while it was functional, but i simply don't think that paying as high as $200 + shipping is worth 6 months of u …"  Read Full Review »
Mar 25 2008
Undisclosed
Reviewed at:
Price: $219.99
Got the supply and it ...
4.0
"Got the supply and it fits under the cabinet. However it only has one communication port so that only one computer can be protected even though the UPS has the capacity to protect and shut down two computers. I have been unable to find a splitter cable to connect two computers. Therefory you can g …"  Read Full Review »
May 22 2006
Vern
Undisclosed
Reviewed at:
Price: $219.99
Very good UPS. APC has ...
5.0
"Very good UPS. APC has been around for a long time and makes a very good product. I had a pre-Y2K version of this UPS and it was made of metal instead of plastic, I liked the metal better. The other UPS died after 9.5 years for service. "
May 5 2007
Ben
Undisclosed
Reviewed at:
Price: $219.99
Nice attractive unit, ...
4.0
"Nice attractive unit, fits well with my CPU towers. Accompanying software for the unit is a plus. It monitors the power supply and battery charged level. Excellent and fast delivery by TigerDirect was superb! "
Feb 6 2006
CanyacCanjar
Undisclosed
Reviewed at:
Price: $219.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
