Antennas Direct DB4 Multi Directional HDTV Antenna
#11
4.3
based on 35 reviews
Ratings Distribution
5 star
22
4 star
6
3 star
4
2 star
2
1 star
1
Category Average
3.6
$47.00 - $74.99
from 7 stores
More Images
Pros
  • Durable (5)
  • Easy setup (5)
  • Strong signal (4)
  • Fine-tuning (3)
  • Good value (2)
  • High quality (2)
  • 5 stars but no mast so 4 (1)
  • Easy to order (1)
  • Reasonably priced (1)
See less See more
Cons
  • Doesn't come with mast (1)
  • Instructions for assembly (1)
Best Uses
  • Attic/roof mount (2)
  • Bedroom (2)
  • Anywhere (1)
  • Attic mounted antenna (1)
  • Living room (1)
  • Pole mount (1)
  • Small rooms (1)
  • Two tvs (1)
Provided by Beach Audio
FEATURES- DB4 HDTV Antenna
The DB4 has become our most popular model because it is simply the
best Mid Range HDTV antenna on the market. With an approximate
13.7 dB gain, it is one of the strongest multi-directional antennas
available and performs consistently across the entire UHF spectrum.
It even works well in areas where HD transmitters are in multiple
directions.
The bow tie design of the DB4 uses triangular elements instead of
rods to greatly increase the bandwidth allowing it to cover the
entire UHF band. Additionally, the mesh reflector of the bowtie
is more efficient than a rod reflector, is lower in weight, and
provides less wind resistance for greater performance and
durability.
If you are looking for an antenna that is practically guaranteed to
perform, the DB4 is one of your safest choices. It will pull in
all UHF frequencies and most higher level VHF frequencies with a
range of about 55 miles.
* Range: Up to 55 miles
* Strong performance across UHF spectrum (Channels 14-69)
* Versatile high gain multi - bay antenna
* Efficient design allows tremendous gain in a compact size
* 13.7 dB gain
* Versatile HD antenna, succeeds in difficult areas where other antennas
fail.
* All weather Balun included
* Designed to resist extreme wind loading
* Works great in attics. Fits easily & high gain can help overcome loss
from roofing materials.
* Dimensions: 29" H x 19" W x 4" Deep
* Weight: 4.5 pounds
www.antennasdirect.com
Antennas Direct DB4 Multi Directional HDTV Antenna Questions
Questions and Answers
Where to Buy
$59.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$74.99
$47.00
Show all 7 stores
Product Reviews
Last update: Oct 4, 2009
Antennas Direct DB4 Multi Directional HDTV Antenna Reviews
Most helpful positive review
[3 of 3 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Best product ever!!!
"We live in Maryland in the middle of the Baltimore, Annapolis, Washington, DC triangle. This antenna picks up all of the HD channels for the Baltimore, Washington DC, and local area. GREAT RECEPTION!!! I can't stress that enough. Where our house is located is kind of down behind some hills. So, I wasn't expecting much. But, I was pleasantly surprised!! With this antenna, we pick up 23 HD channels and 17 analog c..." Read Full Review »
Nov 03, 2007 by deweyb1203
See more positive Antennas Direct DB4 Multi Directional HDTV Antenna reviews
3.0
NOT VHF
"This antenna is not for VHF. If you go to AntennasDirect website it lists that this antenna is UHF only. With the digital transition on 2-17 stations that were broadcasting thier Digital signal on UHF bands have reverted back to VHF. This antenna does not pick them up because it is a UHF ANTENNA! The website here states that it is a VHF/UHF antenna. IT IS NOT! IT IS UHF ONLY! I recommend this only if you are try..." Read Full Review »
Feb 18, 2009 by FredF
See more negative Antennas Direct DB4 Multi Directional HDTV Antenna reviews
Displaying 1 - 5 of 35 Reviews
Show
Sort by
5.0
"We live in Maryland in the middle of the Baltimore, Annapolis, Washington, DC triangle. This antenna picks up all of the HD channels for the Baltimore, Washington DC, and local area. GREAT RECEPTION!!! I can't stress that enough. Where our house is located is kind of down behind some hills. So, I wa …"  Read Full Review »
Was this Antenna review on the Antennas Direct DB4 Multi Directional HDTV Antenna helpful to you?
 Report Abuse  (3)  (0)  0 comments
Nov 3 2007
deweyb1203
Maryland
Reviewed at:
Price: $74.99
[4 of 4 customers found this review helpful]
wow!
5.0
"when i purchased this antenna it was a shot in the dark. i went to 'antennaweb.com' and they suggested a much larger antenna w/preamp. i did not even get the db4 antenna mounted before i was getting all the stations in my area. i live about 20 miles south of tallahassee florida surrounded by pine tr …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Feb 12 2008
gargoyle8
crawfordville florida
Reviewed at:
Price: $74.99
[6 of 6 customers found this review helpful]
Quality antenna
4.0
    Pros
  • Good Value
  • High Quality
    Cons
    Best Uses
"Needed to use a mount to set it up in attic, but gets great reception and all the channels I had hoped for. "
 Report Abuse  (6)  (0)  0 comments
Oct 13 2008
Eye doc
Lehi, UT
Reviewed at:
A very very good antenna I bought two
5.0
    Pros
  • Durable
  • Easy to order
  • Easy To Set Up
  • Fine-Tuning
  • Strong Signal
    Cons
  • None
    Best Uses
  • Attic/Roof Mount
  • Pole mount
"I have my antennas mounted on a pole and they work great, I live in the country probably 30 to 40 miles from my television towers.My television come in as great as they did on satellite like Dish,Direct TV.The only problem I have with it is the weather or some unknown in the air waves other than tha …"  Read Full Review »
Oct 4 2009
Wineo909
Henderson,Texas
I am:
  • Power User
Reviewed at:
[2 of 2 customers found this review helpful]
Very Effective
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Reasonably priced
  • Strong Signal
    Cons
  • None
    Best Uses
  • Two TVs
"I live in Orange County and put the antenna on the roof facing Mount Wilson direction.I was quite pleased to find that the antenna provided excellent signal strength even though I split the signal to two coax lines (to 2 converters)I intend to install one at my daughters house.[...] "
 Report Abuse  (2)  (0)  0 comments
May 2 2008
Phil_OP
Tustin CA
I am:
  • Tech Savvy
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
