Antennacraft MXU59 UHF Antenna
#42
4.0
based on 1 review
Ratings Distribution
5 star
0
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
3.6
$54.99 at RadioShack
Find it at Amazon
Find it at Ebay
$54.99
from 1 store
Pros
  • Attractive design (1)
  • Easy setup (1)
  • Strong signal (1)
See less See more
Best Uses
  • Attic/roof mount (1)
Provided by RadioShack
Get that extra range you need to pick up a good UHF signal, even in rural and outlying areas.
Specification Description
Model MXU59
Benefits Up to 60+ mile UHF range*Easy "snap-open" assemblyIncludes "no-tilt" U-bolt clamp and 300/75 ohm matching transformer
Body Material Metal
Capacity UOM mAh
Country Of Origin United States
Description Header Pull in those hard-to-get signals.
Display Catalog Number 15-281
Enclosure Color Gray
End Product Indicator Yes
Features Channel: 14~69Electronic elements: 59Gain (dB): 10.7Half-power beamwidth: 32.4°Front-to-back radio (dB
Included in the Box Antennacraft® MXU59U-bolt300/75 ohm matching transformerUser's guide
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model MXU59
New Date Wed Oct 14 00:00:00 CDT 2009
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Disclaimer *Mileage based on optimum conditions over flat, open terrain. Transmitting antenna height and power and receiving antenna height and placement, will a
Product Height 38
Product Length 100
Product Type UHF only
Product Weight 6.9
Product Weight UOM pounds
Product Width 20
Supported Languages English
Antennacraft MXU59 UHF Antenna Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 4, 2009
Antennacraft MXU59 UHF Antenna Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
[3 of 3 customers found this review helpful]
Works well for the price
4.0
    Pros
  • Attractive Design
  • Easy To Set Up
  • Strong Signal
    Cons
  • None
    Best Uses
  • Attic/Roof Mount
"Pulls in Seattle UHF DTV stations from 100 miles away using inline pre-amp, works quite well for the price. "
Was this Antenna review on the Antennacraft MXU59 UHF Antenna helpful to you?
 Report Abuse  (3)  (0)  0 comments
Oct 4 2009
jaybyrd
Bellingham, WA
I am:
  • Power User
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
