Antennacraft HDX1000 Amplified HDTV Antenna
#138
3.6
based on 8 reviews
Ratings Distribution
5 star
3
4 star
3
3 star
0
2 star
0
1 star
2
Category Average
3.6
$79.99 at RadioShack
Find it at Amazon
Find it at Ebay
$79.99
from 1 store
Pros
  • Easy setup (5)
  • Durable (4)
  • Strong signal (3)
  • Fine-tuning (2)
  • If outdoor (1)
  • My wife likes it (1)
See less See more
Cons
  • Poor reception (2)
  • Bulky (1)
Best Uses
  • Attic antenna (1)
  • Living room (1)
  • Outside wall (1)
  • Side of house (1)
Provided by RadioShack
Get great HDTV reception with this amplified indoor/outdoor antenna from Antennacraft.
Specification Description
Model HDX1000
Benefits Ideal for urban areas, suburbs or fringe areasUp to 50 mile VHF range; up to 40 mile UHF rangeBuilt-in modulator amplifier p
Capacity UOM mAh
Country Of Origin United States
Description Header Give your signal a boost
Display Catalog Number 15-287
Enclosure Color Gray
End Product Indicator Yes
Features Channel: 2~69Gain (dB): VHF low: -20.0; VHF high: -6.6; UHF: 6.4VHF frequency (channels 2-6) receives DTV signal up to 20 mi
Included in the Box Antennacraft® HDX1000Signal amplifierAC adapterRight-angle "F" connector adapterMounting mast
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model HDX1000
Operating Temperature UOM ° F
Power Device AC adapter
Product Disclaimer *Mileage based on optimum conditions over flat, open terrain. Transmitting antenna height and power and receiving antenna height and placement, will a
Product Type HDTV
Supported Languages English
Antennacraft HDX1000 Amplified HDTV Antenna Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 10, 2009
Antennacraft HDX1000 Amplified HDTV Antenna Reviews
Displaying 1 - 5 of 8 Reviews
Show
Sort by
Works well in an urban area. Solid unit.
4.0
    Pros
  • Durable
  • Strong Signal
    Cons
  • None
    Best Uses
  • None
"Works fantastically for me, I'm getting more than 20 channels, and the High-Def channels are incredible. I'm only 7 miles from the main broadcasting cluster in my area (Cleveland) so it's likely most quality antennas would work. The quality of the signal is probably more related to being close to t …"  Read Full Review »
Was this Antenna review on the Antennacraft HDX1000 Amplified HDTV Antenna helpful to you?
Nov 10 2009
Tom
Cleveland, Ohio
I am:
  • Casual User
[1 of 1 customers found this review helpful]
Taking it back
1.0
    Pros
  • Easy To Set Up
    Cons
  • Poor Reception
    Best Uses
  • None
"This might be a fine piece of equipment, I just can't tell, not based on what I've gone through. [...] I'll grant that the unit is lightweight, sturdy and easy to assemble and mount. That's pretty much the end of the pluses.Despite being saucer shaped, the antenna is not omnidirectional (that's my …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Aug 25 2009
klystron
No. Virginia
I am:
  • Enthusiast
[1 of 2 customers found this review helpful]
9 out of 10
5.0
    Pros
  • Easy To Set Up
  • My wife likes it
    Cons
  • None
    Best Uses
  • Attic antenna
"I picked this product from the online Radio Shack site, but I went to the local store to buy it. [...] Regarding installation, I had a splitter in my wiring closet that I had forgotten about. I installed the Power Injector next to the TV. It didn't work. Fortunately I consulted the documentation …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Aug 22 2009
Beaverton Cougar
Beaverton, OR
I am:
  • Enthusiast
MAKING THE SWITCH TO FREE H.D. TV
5.0
    Pros
  • Durable
  • Easy To Set Up
  • Fine-Tuning
    Cons
  • none
    Best Uses
  • SIDE OF HOUSE
"FOR US THIS IS A GREAT PRODUCT. WE LIVE ABOUT 20 MILES FROM THE H.D.TOWERS IN OREGON. VERY EASY TO INSTALL EASY TO PICK UP SIGNAL. AS LONG AS YOU HAVE A BUILT IN HD TUNNER IN YOUR TV SET YOU ARE GOOD TO GO. THE BEST PART IS THE ANTENNA PAYS FOR ITS SELF AFTER ONE OR TWO CABLE BILLS. DO THE MATH WE A …"  Read Full Review »
Sep 16 2009
ZUBBA
HILLSBORO, OREGON
I am:
  • Casual User
[2 of 2 customers found this review helpful]
Working well after 1 year...
4.0
    Pros
  • Durable
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • None
"We purchased this antenna well over a year ago when I got sick of the cable companies constant rising costs and lousy service. We are about 50 miles from the digital signal source in our area; never the less this antenna has worked well, and provided us with free digital HD TV. Best of all I no lo …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Oct 14 2009
TBM
Greeley, CO
I am:
  • Casual User
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
