Antec MX-1 Actively Cooled Hard Drive Enclosure
#471
4.2
based on 13 reviews
Ratings Distribution
5 star
31
4 star
15
3 star
3
2 star
2
1 star
5
Category Average
4.1
Low Price:
$50.00 at www.sayera.com
$50.99 at Super Warehouse
Find it at Amazon
$50.00 - $69.99
from 8 stores
More Images
Pros
  • Quiet (31)
  • Easy to use (19)
  • Easy setup (18)
  • Reliable (14)
  • Attractive design (12)
  • Easy to install (12)
  • Large capacity / good size (12)
  • Fast (10)
  • Portable (7)
  • Compact (6)
See less See more
Cons
  • Pricey (4)
  • Hard to install (3)
  • Unreliable (3)
  • Slow (2)
  • Ditch the esata cable (1)
  • Don't buy if this is 1st (1)
  • Get a better one (1)
  • Ide drive won't work (1)
  • Poor instructions (1)
  • Power jack bad (1)
Best Uses
  • Back-up (21)
  • Additional storage (18)
  • File transfer (13)
  • Photo storage (11)
  • Video (11)
  • Multimedia (6)
  • Replacement (4)
  • Upgrade (4)
  • Music (2)
  • Adding storage to my dvr (1)
Provided by Beach Audio
MODEL- MX-1 VENDOR- ANTEC INC.
FEATURES- MX-1 Actively Cooled Hard Drive Enclosure- Black finish
Keep your data safe and cool in Antec's MX-1 portable Hard Drive
enclosure. Features a blower fan to keep your drive running cool,
and allowing you to operate the enclosure continuously. Simply
install your drive, connect it to your computer and start
transferring your data at blazing speeds over USB2.0 or eSATA.
There's not even any need to install drivers. The MX-1 is made with
a special dual-layer design that reduces noise and is lightweight
for easy transporting.
Includes Drive Enclosure, USB cable, eSATA cable, and eSATA bracket to
convert internal SATA to eSATA; Stand.
* Dual output interface - USB2.0 and eSATA (external Serial ATA) allows you
to transfer data up to 480Mbps or 3Gbps respectively.
* Support up to 750G SATA hard disk drive
* Unique HDD cooler brings fresh air in and around the HDD for maximum
cooling to protect your valuable asset.
* Two layer (plastic with aluminum) structure upper and lower covers to
absorb HDD and fan noise.
* Carbon-glass filled frame to reinforce the strength of the whole
enclosure.
* Built-in silicone pad to absorb HDD noise
* Very quiet fan operation - under 22 dBA
* Noise Level: 20 dbA with the blower on inside the enclosure
* Supports Windows 2000/XP/ME/VISTA
* RoHS compliant
www.antec.com
Antec MX-1 Actively Cooled Hard Drive Enclosure Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 3, 2009
Antec MX-1 Actively Cooled Hard Drive Enclosure Reviews
Most helpful positive review
[7 of 7 customers found this review helpful]
Most helpful negative review
5.0
A superior enclosure IMHO
"Replaced a Thermaltake Rio (no fan) enclosure which I had for just over one year before the light went out in it. On the Rio, when the light goes, there is a real risk of little ones in the house fogetting to turn it off and burning up the drive. The drive is a Seagate Baracuda 320Gb SATA. I use the USB connection but plan on going SATA when my system upgrades. I simply wanted a unit that I could depend on w..." Read Full Review »
Jan 10, 2008 by Jim
See more positive Antec MX-1 Actively Cooled Hard Drive Enclosure reviews
2.0
Power problems!
"A huge problem is the power connector: The end of the lead from the transformer brick has a round connector (similar to S-video) that plugs into the drive enclosure. This is VERY unsecure and works lose or falls out at the slightest movement. I tryed to tape it to the case using electrical tape and when that didn't hold up I resorted to mashing the male plug end with pliers to make it grip & stay in better! It i..." Read Full Review »
Oct 05, 2007 by Baldrick
See more negative Antec MX-1 Actively Cooled Hard Drive Enclosure reviews
Displaying 1 - 5 of 13 Reviews
Show
Sort by
[3 of 4 customers found this review helpful]
Very complete eSATA enclosure
5.0
"This enclosure is intelligently constructed and impressively full-featured.
It came with every cable/adapter you could need to use an SATA drive outside of an SATA capable PC. It even comes with an eSATA PCI slot backplane if your PC has no eSATA ports but does have a free SATA port on the motherboa …"  Read Full Review »
Was this External Computer Hard Drive review on the Antec MX-1 Actively Cooled Hard Drive Enclosure helpful to you?
 Report Abuse  (3)  (1)  0 comments
Sep 2 2007
rb216
Ohio
Reviewed at:
Price: $69.99
[1 of 1 customers found this review helpful]
One word: Simplicity
5.0
"I picked this up to facilitate copying and backup jobs, along with hard drive diagnostics. The beauty of SATA is that the hookups for a 2.5" hard drive (such as from a laptop) are the same as those of a 3.5" desktop drive.
This chassis is well built. Materials are solid, and of good design. The coo …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Feb 19 2008
SirKronan
Idaho
Reviewed at:
Price: $69.99
Power problems!
2.0
This is VERY unsecure and works lose or falls out at the slightest movement. I tryed to tape it to the case using electrical tape and …"  Read Full Review »
Oct 5 2007
Baldrick
Columbus OH
Reviewed at:
Price: $69.99
Great purchase
5.0
"the Veris MX-1 is a great enclosure. Installing my Western Digital WD5000AAKS was a breeze, but you ave to watch out for the LED cable, it could possibly get snagged on the drive sled rails. The LED is a bit dim for normal use, but otherwise the enclosure functions fine. Haven't gotten to use it on …"  Read Full Review »
Jan 3 2008
VPR5703
Burkeville VA
Reviewed at:
Price: $69.99
Perfect
5.0
"I bought this product because I already had 2 external drives that I wasn't using, and needed an external drive for my laptop.
The installation instructions are all but wrothless; luckily you don't need them. You will need a Phillips head screwdriver, but that is it. Once installed, the enclosure do …"  Read Full Review »
Feb 13 2008
Goldeneye007
Leesburg, VA
Reviewed at:
Price: $69.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
