American DJ American Audio SDJ1 Dual SD DJ MP3 Media Player
#20
4.2
based on 10 reviews
from $199.99
Ratings Distribution
5 star
6
4 star
2
3 star
1
2 star
0
1 star
1
Category Average
4.0
$199.99 at PSSL.com - ProSound and Stage Lighting
Find it at Amazon
Find it at Ebay
Pros
  • Doesn't skip (7)
  • Durable (7)
  • Easy setup (7)
  • Great sound quality (7)
  • Simple / intuitive controls (7)
  • Attractive design (6)
  • Easy to use (1)
  • Portable (1)
  • Professional functions (1)
See less See more
Cons
  • Not durable (1)
  • Poor sound quality (1)
  • There's nothing bad about (1)
Best Uses
  • Basic systems (6)
  • Large rooms (5)
  • Audiophiles (3)
  • Smaller rooms / apartments (3)
  • All types of parties (1)
  • Events (1)
  • Outdoors (1)
  • Performances (1)
Provided by PSSL.com - ProSound and Stage Lighting
Going Mobile Has Never Been Easier! Your whole nights music can fit on one SD card!• No external hard drives• No expensive laptops• No extra MP3 players• No complicated software to learn• Supports up to 4GB SD Card SPECIFICATIONS• Dual SD card slot for full functioning MP3 player (reads SD cards up to 4GB each / Does not accept SDHC cards)• Folder Search• Auto BMP• Seamless Loop• Easy to use• Full playback control similar to most Pro CD players• Tempo Lock• Fast, Simple & Reliable• Great for “Drops”• Fader “Q” Start• Pitch Control (+/-4%, +/-8% or +/-16%)• Pitch Bend• Advanced cueing with track search by frame• S/PDIF digital output for each player• Bright LCD display• Single/Continue, Time viewing and MP3 track listings• Up to 1000 MP3 songs on a 1G SD card (4GB SD card not included / MP3 recorded at 128 bit rate)• Dimensions (LxWxH): 19” x 3.5”x 4.25” / 482 x 88 x 108mm - 2 rack spaces• Weight: 4 lbs. / 1.8 kgs
American DJ American Audio SDJ1 Dual SD DJ MP3 Media Player Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 4, 2009
American DJ American Audio SDJ1 Dual SD DJ MP3 Media Player Reviews
Most helpful positive review
Most helpful negative review
4.0
Great media player
"Very simple yet practical unit that allows DJ's to work with the digital era without laptops and expensive software. The most inexpensive way to incorporate MP3s and have full manual mixing control. DJing is boring without being able to beatmatch and mix songs manually. This unit is perfect for me, I use it as a supplement media player in my rack without two CD turntable decks (Denon) with a denon mixer. I n..." Read Full Review »
Nov 04, 2009 by Smooth and Groove
See more positive American DJ American Audio SDJ1 Dual SD DJ MP3 Media Player reviews
3.0
Nice Unit- Poor Sound Quality
"Overall this unit is not bad for the price. I haven't had it for long, so I can not comment on how reliable it is. I will say this, the unit works well. You can beat mix with it & do loops. The one thing that I truly dislike is the poor sound quality. I am trying to see if I can over come this problem. For now, I will use it as a sampler for my DJ drops & for low paying gigs. Should you go out and buy one ? My a..." Read Full Review »
May 15, 2009 by DJ Orlando
See more negative American DJ American Audio SDJ1 Dual SD DJ MP3 Media Player reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
Great media player
4.0
    Pros
  • Attractive Design
  • Doesn't Skip
  • Durable
  • Easy Controls
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Basic Systems
"Very simple yet practical unit that allows DJ's to work with the digital era without laptops and expensive software. The most inexpensive way to incorporate MP3s and have full manual mixing control. DJing is boring without being able to beatmatch and mix songs manually. This unit is perfect for m …"  Read Full Review »
Was this CD Player review on the American DJ American Audio SDJ1 Dual SD DJ MP3 Media Player helpful to you?
Nov 4 2009
Smooth and Groove
Guam
I am:
  • Professional
My First Media Player Purchase
5.0
    Pros
  • Attractive Design
  • Doesn't Skip
  • Durable
  • Easy Controls
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • All Types of Parties
  • Audiophiles
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"This is my very first time out of 26 years of Dee Jaying I have used a media player for mixing at parties; and I am HOOKED! Very easy to use. Excellent portability. Compatiable with other equipment of it's brand. Love the music capacity it can hold for a good party. And most of all, no interuptions …"  Read Full Review »
Jul 7 2009
Curtis" HOTMIX" Heath
Oklahoma City, Oklahoma
I am:
  • Audiophile
  • Musically Inclined
  • Tech Savvy
Great piece of gear..
4.0
    Pros
  • Attractive Design
  • Doesn't Skip
  • Durable
  • Easy Controls
  • Easy To Set Up
  • More »
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"I have the SDJ-1 as my 3rd back up unit and its always on stand-by mode, I use it quite often on gigs, it is no different than having Cd's or a playlist. When I used to play CD's, it was all memorization, you knew exactly what CD to look for, the SDJ-1 is no different. Think of it as a big compilati …"  Read Full Review »
Mar 28 2009
Dj Mx one
Dallas, Texas
I am:
  • Professional
  • Tech Savvy
3.0
    Pros
  • Attractive Design
  • Doesn't Skip
  • Easy Controls
  • Easy To Set Up
    Cons
  • Poor Sound
    Best Uses
  • Basic Systems
"Overall this unit is not bad for the price. I haven't had it for long, so I can not comment on how reliable it is. I will say this, the unit works well. You can beat mix with it & do loops. The one thing that I truly dislike is the poor sound quality. I am trying to see if I can over come this probl …"  Read Full Review »
May 15 2009
DJ Orlando
Miami,FL.
I am:
  • Mobile DJ
This is very cool
5.0
    Pros
  • Clear Sound
  • Easy To Use
  • Professional Functions
    Cons
  • None
    Best Uses
  • Events
  • Performances
"I have used CD forever and was reluactant to go to laptop or have to carry around a hard drive. Also, those things are usually not meant for the professional use that I give my gear. With this I put all my music (that I play every weekend) on a few SD Cards (4 gig) and I am ready to go. Super quick …"  Read Full Review »
Jan 24 2008
DJ William Dee
Chicago IL
I am:
  • Experienced
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
