American Audio PXW-18P 18in Powered Subwoofer *
#123
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
$699.99
from 2 stores
More Images
Pros
  • Attractive design (1)
  • Built in amp (1)
  • Great sound quality (1)
  • Powerful bass (1)
See less See more
Cons
  • Heavy / bulky (1)
Best Uses
  • Nightclub (1)
  • Outdoors (1)
  • Pro audio / dj / mixing (1)
Provided by PSSL.com - ProSound and Stage Lighting
This 18" powered subwoofer will provide plenty of boom without to shake the room. It gives you balanced in and out XLR jacks, as well as a thru full range output, gain control, LED indicators, a phase switch for switching polarity and a protect mode that will prevent the subwoofer from getting too hot by stopping all output. Features 18" powered subwoofer Limit Indicator lets you know when built-in limiter is active Signal Indicator glows when when there a signal is received to the Full Range input Subwoofer gain control knob regulates the output level of the subwoofer, and set balance between the speakers and subwoofers. Protect Indicator glows when the subwoofer goes into protect mode which prevents the subwoofer amplifiers from getting too hot and stops all output Power LED indicates power is on Phase switch for reversing polarity of subwoofer Full range XLR input High Pass XLR output Thru full range output Specs Dimensions: 35.4" x 28.7" x 29.1" Weight: 187.3 lbs. Environmental conditions: Operational temperature: 5° to 35°C (41° to 95°F) Operational humidity: 25 to 85% RH (non-condensation) Storage temperature: -20° to 60°C (4° to 140°F) Frequency response: (-3db): 35Hz ~ 120Hz Frequency range: (-10db): 25Hz ~ 120Hz Maximum SPL at 1m: 128db Peak output at 1m: 134db Crossover frequency: 120Hz (12db/octave) Input type: balanced differential Input impedence: 50k Input protection: Level protected Thermal protection: Input stage muting, auto-reset Low-Frequency transducer diameter: 18" Voice coil diameter: 4.0" Low-Frequency power amplifier: Rated Power* 800 Watts Continuous, 1000W Peak Rated THD: Cooling: Passive-Heatsink with speed sensitive electric fan
American Audio PXW-18P 18in Powered Subwoofer * Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 8, 2009
American Audio PXW-18P 18in Powered Subwoofer * Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
Big Bass Value
5.0
    Pros
  • Attractive Design
  • Built in Amp
  • Great Sound Quality
  • Powerful Bass
    Cons
  • Heavy
    Best Uses
  • Mobile DJ
  • NightClub
  • Outdoors
"I've done a lot of shopping for a powered 18" subwoofer and was not disappointed by this unit. Delivers big low end in a relatively compact package (for an 18" powered sub). That being said, it does weigh about 170 lbs so you need the ability to transport it. "
Was this Speaker & Subwoofer review on the American Audio PXW-18P 18in Powered Subwoofer * helpful to you?
Oct 8 2009
Cynic Drums
Clearwater FL
I am:
  • Tech Savvy
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
