Aluratek Internet Radio Alarm Clock with Built in WIFI
#12
4.5
based on 38 reviews
from $99.99 - $148.55
Ratings Distribution
5 star
22
4 star
8
3 star
2
2 star
2
1 star
0
Category Average
3.8
More Images
Pros
  • Easy setup (13)
  • Clear signal (12)
  • Great reception (12)
  • Compact (11)
  • Accurate controls (10)
  • Nice sound (9)
  • Great sound quality (8)
  • Lightweight (8)
  • Durable (5)
  • Attractive design (1)
See less See more
Cons
  • Confusing / difficult controls (2)
  • Heavy / bulky (2)
  • Poor sound quality (2)
  • Alarm settings (1)
  • Best plugged into stereo (1)
  • Ok sound use speakers (1)
Best Uses
  • Smaller rooms / apartments (11)
  • Home use (10)
  • Everyday (6)
  • Basic systems (5)
  • Large rooms (3)
  • Audiophiles (2)
  • Entertainment (1)
  • Travel (1)
Provided by Dell
Aluratek's new Internet Radio Alarm Clock with Built in Wifi allows you to easily access more than 11,000 radio stations in over 150 countries around the world with no monthly fees. Yes, with no monthly fees! Simply turn the unit on and it will automatically connect to a wireless network and you have a world of entertainment available. You may also connect to a local Ethernet cable network if you prefer. You can search for music geographically by continent/country/state or by the more than 30 different available genres including a wealth of news and sports radio stations broadcast throughout the world. Once you find a favorite station whether is from your local country or while visiting other countries around the world simply add it to your favorites list for future easy access. This is the perfect solution for the home, office environment, college dorm or anywhere you want to listen to thousands of radio stations. Don't be limited to what you can tune in from your old AM/FM analog radio anymore! Free yourself to travel the world musically and have fun while doing it. You can also stream your music library from your local PC/media server if the 11,000+ radio station weren't enough. Welcome to the world of internet radio from Aluratek and let the fun begin.
Specification Description
Model AIRMM01F, AIRMMO1
UPC 890989001866
Alarm 2 Alarm
Tuning Broadband Internet Radio Access
Aluratek Internet Radio Alarm Clock with Built in WIFI Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 9, 2009
Aluratek Internet Radio Alarm Clock with Built in WIFI Reviews
Most helpful positive review
[7 of 7 customers found this review helpful]
Most helpful negative review
4.0
Great alternative to AM/FM
"Since most commercial radio today is a vast wasteland, the ability to receive internet radio this conveniently is a blessing. I am an avid listener to NPR and this radio allows me to access NPR stations from all over the country. The only negative I have found is the inability to play podcasts, even though the web site that you use to program your stations does have an option for podcasts. I am hoping that this ..." Read Full Review »
Feb 20, 2009 by VIP
See more positive Aluratek Internet Radio Alarm Clock with Built in WIFI reviews
3.0
Nice Little Unit
"This unit is pretty much what I expected it to be. The manufacturer really needs to add some direct access buttons so you can quickly go to preset radio stations. Using the remote and navigating the menus just to get to your station is very time consuming. The remote seems to be a little intermittent as well. Many times I need to push the button two or three times to get it to work. Yes, the batteries are f..." Read Full Review »
Oct 02, 2009 by Brads123
See more negative Aluratek Internet Radio Alarm Clock with Built in WIFI reviews
Displaying 1 - 5 of 38 Reviews
Show
Sort by
4.0
    Pros
  • Clear Signal
  • Compact
  • Easy To Set Up
  • Good Sound
    Cons
  • None
    Best Uses
  • Smaller Rooms
"Since most commercial radio today is a vast wasteland, the ability to receive internet radio this conveniently is a blessing. I am an avid listener to NPR and this radio allows me to access NPR stations from all over the country. The only negative I have found is the inability to play podcasts, even …"  Read Full Review »
Was this Portable Radio review on the Aluratek Internet Radio Alarm Clock with Built in WIFI helpful to you?
 Report Abuse  (7)  (0)  0 comments
Feb 20 2009
VIP
NY
I am:
  • Tech Savvy
Reviewed at:
Price: $102.95
Need to wake up to classical music
4.0
    Pros
  • Great Reception
    Cons
  • Alarm Settings
    Best Uses
  • Home Use
"WQXR FM classical can not be heard on Long Island anymore because it changed frequency after 60 years so I had to get the station on the Internet Radio. My alarm has always been set to WQXR so this radio allows me to continue using that station for the alarm. Only complaint I have is if you turn the …"  Read Full Review »
Nov 9 2009
Classical Music Geek
Hicksville, New York
I am:
  • Practical
Reviewed at:
Price: $99.99
[4 of 4 customers found this review helpful]
Love it!
5.0
    Pros
  • Accurate Controls
  • Clear Signal
  • Compact
  • Easy To Set Up
  • Good Sound
    Cons
  • None
    Best Uses
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"This is my 1st internet radio, I purchased at [...] for much more so I wish I would have taken advantage of the special at J&R. This is so easy to use that I didn't need the manual. No monthly fees like satellite or some of the premium sites. Searching by country is really cool and fun to listen …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Aug 26 2008
VballerNoCA
San Bruno, CA
I am:
  • Tech Savvy
Reviewed at:
Price: $99.99
[3 of 3 customers found this review helpful]
simply amazing radio
5.0
    Pros
  • Good Sound Quality
  • Great Reception
  • Lightweight
    Cons
  • None
    Best Uses
  • Daily Use
  • Home Use
"I have used this internet radio in my garage and kitchen for over 5 months now and I love it. My wife and I bought a second unit for our bedroom and we wake up each morning to Beethoven only station. The LCD screen can be dimmed so you control the brightness. 11K stations is alot of stations so o …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Jun 6 2009
Divad
Los Angeles, CA
I am:
  • Frequent Traveler
  • Gearhead
  • Practical
Reviewed at:
Price: $102.95
So easy a caveman can set this up!
5.0
    Pros
  • Accurate Controls
  • Clear Signal
  • Easy To Set Up
  • Good Sound
    Cons
  • None
    Best Uses
  • None
"I originally purchasedthis unit to listen to Internet Radio in the Bedroom while going to sleep. From the time I plugged the unit in to the wall to the time I began listening to the radio was less than 5 minutes. I then read the instructions and discovered I can listen to the music from my compute …"  Read Full Review »
Oct 9 2008
Gi
Alameda, Ca
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Price: $99.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
