Close Login Module
Join
Aluratek 10.5" Digital Photo Frame with 256MB Memory and Remote Control Included
#28
4.1
based on 10 reviews
Ratings Distribution
5 star
4
4 star
5
3 star
0
2 star
0
1 star
1
Category Average
3.7
$125.99 - $137.76
from 2 stores
More Images
Pros
  • Easy to use (5)
  • Attractive design (4)
  • Clear image (3)
  • Easy photo upload (2)
  • Quality construction (2)
  • Looks great (1)
  • Nice picture (1)
  • Superior color rendition (1)
See less See more
Cons
  • Difficult to use (1)
  • How to sequence photos (1)
  • Need more internal memory (1)
  • Poor design (1)
  • Standard features not doc (1)
  • Unreliable (1)
Best Uses
  • Home (2)
  • Home decor (2)
  • Photography display (2)
  • Portraits (2)
  • Digital photos (1)
  • Everyday (1)
  • Gift (1)
  • Landscapes (1)
  • Macro (1)
Where to Buy
$125.99
BizRate Rating Outstanding 9.0
$137.76
Product Reviews
Last update: Sep 16, 2009
Aluratek 10.5" Digital Photo Frame with 256MB Memory and Remote Control Included Reviews
Most helpful positive review
[5 of 5 customers found this review helpful]
Most helpful negative review
5.0
Works as advertised
"Good resolution, easy to use, and it stores alot of pictures on the built in memory. Most frames don't come with onboard memory so if you have to spend extra $10-$20 for this frame over cheaper frames, it's definitely worth buying this. I highly recommend it. Pictures come out clear and it plays my AVI video clips from my Cannon SD1000. Expertise: Mid-Advance..." Read Full Review »
Oct 20, 2007 by Estapho
See more positive Aluratek 10.5" Digital Photo Frame with 256MB Memory and Remote Control Included reviews
1.0
CAUTION!!!
"I bought a slightly different model# (Aluratek ADMPF311F) for Christmas from B&H and it's a complete piece of garbage! Use great caution before buying from this manufacturer. Look carefully at other brands first. I will not buy any Aluratek product in the future...." Read Full Review »
Jan 01, 2009 by Alan Melle
See more negative Aluratek 10.5" Digital Photo Frame with 256MB Memory and Remote Control Included reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
Works as advertised
5.0
"Good resolution, easy to use, and it stores alot of pictures on the built in memory. Most frames don't come with onboard memory so if you have to spend extra $10-$20 for this frame over cheaper frames, it's definitely worth buying this. I highly recommend it. Pictures come out clear and it plays m …"  Read Full Review »
Oct 20 2007
Estapho
AZ
Reviewed at:
Really excellent photoframe
5.0
    Pros
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home
  • Portraits
"We ended up with 2 photoframes this Xmas The Aluratek and one made by one of those huge Japanese conglomerates. Although they have different screen sizes they have identical resolution. They are both used to show similar family photos.
The Aluratek was easie to set up and gives far more pleasant …"  Read Full Review »
Jan 5 2009
Allan
Trumbull, Connecticut
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Quite Satisfied
4.0
    Pros
  • Attractive Design
  • Clear Image
  • Easy Photo Upload
  • Easy To Use
  • Quality Construction
    Cons
    Best Uses
  • Photography Display
"It is a good looking frame. The color photos are terrific. Resolution good. Some of the Black and White photos have a somewhat lower resolution and load a bit slower.
All in all, I am very satisfied. "
Aug 28 2009
Doc
Jerusalem, Israel
I am:
  • Quality Oriented
Reviewed at:
It fit our needs perfectly
4.0
    Pros
  • Attractive Design
  • Easy Photo Upload
    Cons
  • None
    Best Uses
"I found the digital photo frame easy to use. A key to use is becoming well versed with the features of the remote pad. This was the first time I purchased a product of this type and am well satisfied.
Shopping for the product became confusing, but I took the advise of a B&H telephone represetant …"  Read Full Review »
Mar 27 2009
OP's Best
Orchard Park, NY
I am:
  • Quality Oriented
Reviewed at:
CAUTION!!!
1.0
    Pros
  • None
    Cons
  • Poor Design
    Best Uses
  • none
"I bought a slightly different model# (Aluratek ADMPF311F) for Christmas from B&H and it's a complete piece of garbage! Use great caution before buying from this manufacturer. Look carefully at other brands first. I will not buy any Aluratek product in the future. "
Jan 1 2009
Alan Melle
Arizona
I am:
  • Semi-Professional
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$125.99
$137.76
Out Of Stock
BizRate Rating Outstanding 9.6
$104.99
No Tax Outside NY
$119.99
$149.99
$149.99
$173.24
Overstock.com Club O Deals!
$173.99
$173.99
BizRate Rating Outstanding 9.1
$179.95
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
