Close Login Module
Join
Alpine 45W x 4 Apple iPod /Satellite Radio/HD Radio-Ready Deck
3.8
based on 18 reviews
Ratings Distribution
5 star
6
4 star
6
3 star
3
2 star
3
1 star
0
Category Average
4.1
$167.00
from 1 store
Where to Buy
Product Reviews
Last update: Jul 4, 2009
Alpine 45W x 4 Apple iPod /Satellite Radio/HD Radio-Ready Deck Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
5.0
Very Pleased; Exactly What I Expected
"I've had this unit for a week now and I love the iDAx200. I researched and shopped around for 3 weeks before deciding on this HU and I couldn't be happier. It's easy to configure and easier to use. Navigation is simple and follows common nav conventions. If you're familiar with iTunes, you'll hit the ground running. I can play and control USB drives and all my mp3 players from the USB port; I can also run digit..." Read Full Review »
May 04, 2009 by one19
See more positive Alpine 45W x 4 Apple iPod /Satellite Radio/HD Radio-Ready Deck reviews
3.0
s'ok
"This stereo works wonderfully when used with your iPod...assuming your iPod works on this system. My 2nd gen nano works great, my girlfriends old mini doesn't work at all. Check to make sure yours will work before purchasing. Assuming your iPod is compatible, this Alpine works great: the interface works just like your iPod (center button with rotating dial around outside) and it cycles through songs/artists/albu..." Read Full Review »
Mar 14, 2008 by Jamesons
See more negative Alpine 45W x 4 Apple iPod /Satellite Radio/HD Radio-Ready Deck reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
5.0
"I've had this unit for a week now and I love the iDAx200. I researched and shopped around for 3 weeks before deciding on this HU and I couldn't be happier. It's easy to configure and easier to use. Navigation is simple and follows common nav conventions. If you're familiar with iTunes, you'll hit th …"  Read Full Review »
May 4 2009
one19
Greeley, CO
Reviewed at:
s'ok
3.0
"This stereo works wonderfully when used with your iPod...assuming your iPod works on this system. My 2nd gen nano works great, my girlfriends old mini doesn't work at all. Check to make sure yours will work before purchasing. Assuming your iPod is compatible, this Alpine works great: the interface w …"  Read Full Review »
Mar 14 2008
Jamesons
San Francisco, CA
Reviewed at:
Excellent Sound, Poor Features
2.0
"WOW The Alpine Sound Is Unreal, However The Supplied USB iPod Cable Can not keep Up With The Alpine So YOU MUST BUY THE $30 High Speed Cable...but after you buy that cable you will be mad that your iPod WILL NOT CHARGE FROM THAT CABLE, so i had to leave the usb cable hooked up just so i could charge …"  Read Full Review »
Oct 22 2008
Theemustangman
Rochester, MN
Reviewed at:
Very Good Product, but it does have some problems
4.0
"Pros: Great Sound. Ipod control is fairly intuitive. Decent price and Ipod cable is supplied.
Cons: Display is too small and the text is too large.
Selecting preset radio stations could be easier.
Some songs occasionally skip. This doesn't happen a lot so it's not a huge problem, but it is annoying …"  Read Full Review »
May 20 2009
Jello212348e
Raleigh, NC
Reviewed at:
Poor quality from alpine, very disapointed
2.0
"I bought this product becuse of its price which was not bad, and for its ipod functionallity. I only use my ipod to play music anyway so i though this would be a good deck to buy, i went home installed it myself. it has a bug in it that when you go back a song it will only play 30 sec of it then res …"  Read Full Review »
Jul 4 2009
SpennyM
Shreveport, LA
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$167.00
Out Of Stock
$149.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
