Allsop Ultra ProAudio Cleaner Replacement Pads
5.0
based on 3 reviews
Ratings Distribution
5 star
3
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
3.9
Pros
  • Easy to use (3)
  • Dries quickly (2)
  • Works great (2)
  • Good value (1)
See less See more
Best Uses
  • Cleaning cassette decks (1)
  • Delicate equipment (1)
  • Every once in a while (1)
  • Heavy-duty equipment (1)
  • Portable electronics (1)
  • Regular use (1)
Provided by Allsop
If you're here looking for repalcement pads for your [URL p='70000']Audiocassette cleaner[/URL], either you've been busy cleaning all of your cassette decks, or your cleaner has been in your glovebox since about 1990. Either way, we are glad you're here. You are to be commended for caring about your tapes and the quality of your sound. Cassette tapes are convenient, but fragile – portable but limited. Cassette players are exposed to dust and hair, and every time you play a tape, it leaves behind tiny pieces of metal called oxides. Build up of oxides and dust will dull the sound and even cause the tape to get caught in a sticky roller, stretch and break. In other words, your tape gets eaten. The Ultra Pro Audio Cleaner refill kit lets you make sure you are playing your tapes on clean equipment. But, you might also think about restocking your [URL p='79100']Ultreen solution[/URL]. Using this on a regular basis (once a month or so) will help save your tapes from getting eaten and keep the sound nice and clear.
Allsop Ultra ProAudio Cleaner Replacement Pads Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Ultra ProAudio Cleaner Replacement Pads
See all eBay results
  at eBay.com
Product Reviews
Last update: Feb 19, 2007
Allsop Ultra ProAudio Cleaner Replacement Pads Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
Cleaning Your Heads
5.0
    Pros
  • Dries Quickly
  • Easy To Use
  • Works Great
    Cons
  • None
    Best Uses
  • Delicate Equipment
  • Every Once In A While
  • Heavy-Duty Equipment
  • Portable Electronics
"I've been using an Allsop cassette cleaner like this one since around 1975. It is exactly as described in the product details. It's basically an empty cassette shell with three separate replaceable pads that move horizontally back and forth for 20 seconds over your capstons and your recording/playba …"  Read Full Review »
Was this Electronics Cleaning Kit review on the Allsop Ultra ProAudio Cleaner Replacement Pads helpful to you?
Feb 13 2007
MajorBuzz
Florida
Reviewed at:
A cassette deck must!
5.0
    Pros
  • Dries Quickly
  • Easy To Use
  • Good Value
  • Works Great
    Cons
  • None
    Best Uses
  • Regular Use
"If you are old fashioned like me and still play cassette tapes, never having been able to get into the whole ipod/MP3 thing, you need to get this product. It only takes a minute or so to use, you can readily see the results by the cleaning pads turning black, and replacing them with this kit is a s …"  Read Full Review »
Feb 19 2007
Too Tall
Hermosa Beach, CA
Reviewed at:
Glad I did
5.0
    Pros
  • Easy to use
    Cons
  • None
    Best Uses
"I like that I can just replace parts of the cleaning set I already have -- I like the money saving aspect, and the environmental impact. (And it's so satisfying seeing the pristine pads become filthy when it means my tapes are all the safer for it!) "
Jan 23 2006
Stacy
Minnesota
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
