Allsop Orbitrac 2, Replacement Pads
5.0
based on 3 reviews
from
Ratings Distribution
5 star
3
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
3.9
Pros
  • Easy to use (3)
  • Good value (3)
  • Works great (3)
  • Dries quickly (2)
See less See more
Best Uses
  • Regular use (2)
  • Delicate equipment (1)
  • Heavy-duty equipment (1)
Provided by Allsop
So, if you're looking for replacement pads, you know the Orbitrac 2 Record Cleaning System is a simple but effective “all-in-one” approach to vinyl records cleaning. You are to be commended for recognizing that the pads that came with the kits are dirty. It is for people like you that Allsop offers these replacement pads. They are identical to the ones that came with the kit and, frankly, will clean your records much better than the dirty ones you have been using for the last few months. Just in case it's been a while since you've used your kit, you just place the dirty record on the system’s non-skid pads, squirt some cleaning fluid on one of the cleaning pads, put the cleaning pad down on the record and spin it three to five times around the record. This will get rid of years of dust, dirt, even mold in some really gross situations.
Allsop Orbitrac 2, Replacement Pads Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Orbitrac 2, Replacement Pads
See all eBay results
  at eBay.com
Product Reviews
Last update: Dec 27, 2006
Allsop Orbitrac 2, Replacement Pads Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
Finest record cleaner I've used
5.0
    Pros
  • Dries Quickly
  • Easy To Use
  • Good Value
  • Works Great
    Cons
  • None
    Best Uses
  • Delicate Equipment
  • Heavy-Duty Equipment
  • Regular Use
"I've used a lot of record cleaning products through the years, but this is far and away the best I have ever come across. Used with the Allsop Orbitrac Record Cleaning Solution, you won't find a more effective cleaning system anywhere. Thank you, Allsop, for making my listening pleasure complete. …"  Read Full Review »
Was this Electronics Cleaning Kit review on the Allsop Orbitrac 2, Replacement Pads helpful to you?
Dec 11 2006
metalking61
Owings Mills, MD
Reviewed at:
The proof is in the pads
5.0
    Pros
  • Easy To Use
  • Good Value
  • Works Great
    Cons
  • None
    Best Uses
  • Regular Use
"If you always thought the only really effective record cleaner was one of the vacuum types (at $300+ apiece), save your money and buy this. Even on records that look clean, this product offers noticeable improvement. Note: the pads get dirty fast - which means they're doing a good job - but it's a g …"  Read Full Review »
Dec 27 2006
Cancon
Pickering ON
Reviewed at:
This REALLY works;old vinyl sounds new !
5.0
    Pros
  • Dries Quickly
  • Easy To Use
  • Good Value
  • Works Great
    Cons
  • None
    Best Uses
  • None
"This REALLY works ; old vinyl sounds new! As I pull what I thought were pristine vinyl from my stacks (some of which go back 50 years ! !), I give their surfaces THE cleaning of their life ; you will NOT believe the crud that WAS buried in them there grooves ! And playback is an audiophile experie …"  Read Full Review »
Oct 20 2006
Mark
Seattle
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
