Allsop CPU Stand - Pewter Metal Art
4.2
based on 15 reviews
Ratings Distribution
5 star
17
4 star
17
3 star
4
2 star
1
1 star
1
Category Average
4.0
$19.99 - $28.30
from 5 stores
More Images
Pros
  • Easy to use (22)
  • Durable (21)
  • Reliable (11)
  • Easy assembly (6)
  • Fast (6)
  • Supports weight (6)
  • Attractive design (5)
  • Compact (5)
  • Good design (4)
  • Sturdy (4)
See less See more
Cons
  • Bulky/heavy (1)
  • Color not stainless steel (1)
  • Could be a bit longer (1)
  • Could use more padding (1)
  • Difficult to set up (1)
  • Each kit had 2 nuts missing for set up (1)
  • Foam pads don't stick (1)
  • Had to go out and buy my own bolts (1)
  • Height not adjustable (1)
  • Nuts fell apart when tighting (1)
Best Uses
  • Home or business (11)
  • Convenience (5)
  • Home office (4)
  • Office (4)
  • Home (3)
  • Dorm room (2)
  • Anywhere (1)
  • Business offices (1)
  • Computer desk (1)
  • Everyday (1)
Provided by Allsop
- Looking at computer organization products - you know, printer stands, keyboard drawers, etc. - they’re classics ... circa 1989. You can almost see Michael J. Fox standing next to them. Sadly, there hasn’t been much progress in this area. Boring beige plastic and unidentifiable simulated wood grain are sometimes the bet you can find. That is ... until now. The Metal Art CPU Caddy uses modern design and innovation to help your computer fit into your life. Both in function and in form. Forged from steel, it puts your CPU up on wheels so you can roll it around a little without any lifting. The more digital our lifestyle gets, the more we need to plug and unplug things from the computer. The CPU Caddy makes interaction between your computer, digital camera, MP3 player, joystick, PDA and printer a little easier. Pewter powder-coated finish is not meant to match your computer. They help create a balance between the comfortable feel of your home or office and the technical convenience of your computer. In a nutshell, the Metal Art CPU Caddy gives your CPU a lift and looks good doing it.
Allsop CPU Stand - Pewter Metal Art Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 27, 2009
Allsop CPU Stand - Pewter Metal Art Reviews
Most helpful positive review
Most helpful negative review
4.0
Works Great
"Easy to assemble. Works fine on low nap carpet. The color is more of a gun metal grey. It is not chrome shiny or neutral grey. So if you have to have something that will match your Mac Pro work horse, this is not for you. If you want something that works well - this works great...." Read Full Review »
Aug 12, 2009 by George
See more positive Allsop CPU Stand - Pewter Metal Art reviews
1.0
bad product
"There were 8 wing nuts included. 4 of them worked fine. 4 were too small. I had to return to the store where we opened another box and it had the same problem--some just right and some too small. Between the 2 boxes we were able to come up with 8 that were the right size. Except for that it's a good product...." Read Full Review »
Aug 11, 2009 by Ginger
See more negative Allsop CPU Stand - Pewter Metal Art reviews
Displaying 1 - 5 of 15 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
help keep the fuzz bunny's out
5.0
    Pros
  • Adjustable
  • Easy set-up
  • Looks good
    Cons
  • None
    Best Uses
  • Home
  • Home Office
  • Mobile Office
  • Office
"Keeps the CPU case off the floor less
carpet fuzz being sucked into case.
Easy to roll around computer case for easy access to rear of case.
Make sure you check inside the wheel
housing if you can not find all wing nuts to put the caddy together_comes
with 8 wing nuts. "
Was this Computer Accessory review on the Allsop CPU Stand - Pewter Metal Art helpful to you?
 Report Abuse  (1)  (0)  0 comments
Apr 28 2006
BZ
Portland,Oregon
Reviewed at:
Have looked for this for years.
5.0
    Pros
  • Compact
  • Durable
  • Easy to assemble
  • Easy to Use
    Cons
  • None
    Best Uses
  • Home or Business
"The caddy allows me to slide my Mac back under my desk, out of the way, and forward again to access cables/connections as needed. "
Oct 16 2009
beth
MN
I am:
  • Quality Oriented
Reviewed at:
Price: $19.99
Finish not what I expected
3.0
    Pros
  • Easy to Assemble/Wire
  • Sturdy
  • Supports Weight
    Cons
  • None
    Best Uses
  • None
"This item was easy to assemble and seems sturdy. However, the finish was not what I was expecting. In the photos on this website and on the box, it looks like metal but the item itself is just painted gray. It does not look like pewter. I was disappointed in that. It is not as attractive as I t …"  Read Full Review »
Dec 2 2007
Reba
New York
Reviewed at:
Price: $26.99
Good Quality But Usless - Desn't Fit CPU
2.0
    Pros
  • Attractive Design
  • Sturdy
  • Supports Weight
    Cons
  • Insufficient Capacity
    Best Uses
  • Convenience
  • Space Saver
"my tower case which is not nearly 9.5" wide, as the the maximum size/width this will support. It is closer to 7" so many computers won't fit.
The quality is good for the price. "
Jul 17 2007
Colby
New York
I am:
  • High-End Shopper
Reviewed at:
Price: $26.99
just the thing...
4.0
    Pros
  • Durable
  • Easy to Use
  • Fast
  • Reliable
    Cons
  • could be a bit longer
    Best Uses
  • Dorm Room
  • Home
  • Office
"Brainless to assemble and set up and very adjustable. Looks good on my Dell workstation or my Mac G5. I would have made it a few inches wider for this big CPU cases, but it seems very stable. "
Sep 5 2006
eric
boston
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
