Aleratec DVD/CD RoboRacer LS Publishing System
#24
2.0
based on 4 reviews
from $719.95 - $833.29
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
3
Category Average
3.8
More Images
Pros
  • Easy to use (1)
  • Its easy to use (1)
  • Professional functions (1)
  • Simple controls (1)
  • Versatile (1)
See less See more
Cons
  • Difficult to use (1)
  • It does not work properly (1)
  • Never got it to work (1)
  • Poor performance (1)
  • Unreliable (1)
Best Uses
  • Duplicate my own project (1)
  • Home (1)
  • Performances (1)
Provided by Overstock.com
Click here for Rebate Form*RoboRacer LS CD/DVD duplicator has fewer moving parts for maximum reliability and ease of use *Capable of multiple unattended direct to disc LightScribe labeling or unattended disc duplication *Just load it with 100 blank LightScribe discs and use your PC to select the disc image or label you desire with the powerful Aleratec Disc Publishing Suite *Make one test copy then enter the number of copies or labels you need and it will automatically produce up to 100 DVD/CD copies or clearly labeled discs with no operator intervention *Manufacturer: Aleratec, Inc *Manufacturer Part Number: 280110 *Manufacturer Website Address: www.aleratec.com *Product Name: RoboRacer LS CD/DVD Duplicator *Product Type: PC Connect CD/DVD Duplicator *Optical Drive: 1 x DVD-Writer *Simultaneous Copies: Not Applicable *Write Speed: 48x CD-R *Interfaces/Ports: USB 2.0 USB *Dimensions: 16.3 inches high x 7.25 inches wide x 14.5 inches deep
Specification Description
Model 280110, 280110-
UPC 808068004035
Computer Compatibility PC
Connection External
Port Compatibility USB
Product Type PC Connect CD/DVD Duplicator
Type of Drive CD / DVD Duplicator
Aleratec DVD/CD RoboRacer LS Publishing System Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Dec 5, 2008
Aleratec DVD/CD RoboRacer LS Publishing System Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
[2 of 2 customers found this review helpful]
I am delighted with this product
5.0
    Pros
  • Easy To Use
  • Professional Functions
  • Versatile
    Cons
  • None
    Best Uses
  • Performances
"Installation clear and easy to follow.
Very efficient product that has cut my time of duplicating school performance on DVD more than half. "
Was this DVD Recorder review on the Aleratec DVD/CD RoboRacer LS Publishing System helpful to you?
 Report Abuse  (2)  (0)  0 comments
Jun 26 2008
Lu
Secaucus, NJ
I am:
  • Experienced
Reviewed at:
Price: $719.95
[1 of 3 customers found this review helpful]
the idea is good, the product is awful
1.0
    Pros
  • None
    Cons
  • Poor Performance
    Best Uses
  • None
"I bought this product and it did not work at all. I called tech support and after about a week of working with them, they told me it was defective and to exchange it. I did. The second one crashed my computer. Buyer Beware. "
 Report Abuse  (1)  (2)  0 comments
Dec 5 2008
durga
charlottesville, VA
I am:
  • Tech Savvy
Reviewed at:
Price: $739.99
[0 of 2 customers found this review helpful]
Unreliable. it randomly stop copying
1.0
    Pros
  • Its easy to use
  • Simple Controls
    Cons
    Best Uses
  • Home
"I installed to my first computer, it makes only one copy at a time regardless how many numbers of copy I requested. I installed to second computer, it partially works. It stops at any number of copy but never get to copy pass over 20 copies. "
 Report Abuse  (0)  (2)  0 comments
Nov 5 2008
Miaboryu
Sacramento, CA
I am:
  • Casual User
Reviewed at:
Price: $719.95
[0 of 4 customers found this review helpful]
No Performance
1.0
    Pros
  • None
    Cons
  • Difficult To Use
  • Unreliable
    Best Uses
  • None
"I wish I could say something good about this unit, but I can't. I received it in mid-May 2008 and here it is in mid-July and I've never gotten it to work. Aleratec emailed a few downloads and upgrades to the firmware, but with no change. I've installed it on 3 different computers using Win XP and Vi …"  Read Full Review »
 Report Abuse  (0)  (4)  0 comments
Jul 15 2008
TonyB
Eclectic, AL
I am:
  • Experienced
Reviewed at:
Price: $719.95
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
