Aleratec 1:5 HDD Cruiser Hard Disk Drive Sanitizer and Duplicator (Model #350104)
#13
3.0
based on 1 review
Ratings Distribution
5 star
0
4 star
0
3 star
1
2 star
0
1 star
0
Category Average
4.3
$899.00 - $999.99
from 11 stores
More Images
Pros
  • Good quality duplicates (1)
See less See more
Best Uses
  • High volume duplication (1)
Provided by WolfCamera.com
The Aleratec 1:5 HDD Cruiser simultaneously duplicates up to 5 Hard Disk Drives simultaneously without a computer; an essential tool for installing new or upgrading multiple computer systems. It can also sanitize up to 6 HDDs at once to assure that all confidential data left on old drives is unreadable. The sanitizing capability is particularly important with the rapid advancement of hard drives; upgrading existing drives is commonplace and it is important that confidential data be removed from the old drives before they are recycled or discarded.
The 1:5 HDD Cruiser is a stand alone unit so there is no need to tie up a computer for hours running complex software to duplicate or sanitize hard disk drives.
The 1:5 HDD Cruiser's drive bays are equipped with quick and easy loading doors. Simply open the drive bay door to load or unload a drive. Slide the drive in the drive bay and close the drive bay door and high integrity electrical and data connections are made automatically. Each drive bay has Non Scratch SATA connectors designed for greater than 50,000 swap cycles minimizing worries about drive connection issues.
The Aleratec 1:5 HDD Cruiser duplicates 3.5" HDD at 40MB/s
3.5", 160GB, 7200RPM, SATA 3.0Gb/s
  • To Copy 1GB, takes 25 seconds
  • To Copy 160GB takes 70 minutes
    The Aleratec 1:5 HDD Cruiser duplicates 2.5" HDD at 35MB/s (optional 2.5" Adapter required)
    2.5", 80GB, 5400RPM, SATA 1.5Gb/s
  • To copy 1GB, takes 29 seconds
  • To copy 80GB takes 38 minutes
  • Specification Description
    Model 350104
    UPC 808068004202
    Select Drive Accessories
    Aleratec 1:5 HDD Cruiser Hard Disk Drive Sanitizer and Duplicator (Model #350104) Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Oct 24, 2009
    Aleratec 1:5 HDD Cruiser Hard Disk Drive Sanitizer and Duplicator (Model #350104) Reviews
    Displaying 1 - 1 of 1 Reviews
    Show
    Sort by
    Disappointment
    3.0
      Pros
    • Good Quality Duplicates
      Cons
    • None
      Best Uses
    • High Volume Duplication
    "Item arrived with 2 bays not working. Tech support suggested I disassemble the unit and check the cables. One cable was disconnected. Reconnecting that fixed one bay, but the last bay never worked. [...]! Too bad because the bays that did work seemed to make perfect copies very quickly. "
    Was this CD Recorder review on the Aleratec 1:5 HDD Cruiser Hard Disk Drive Sanitizer and Duplicator (Model #350104) helpful to you?
    Oct 24 2009
    Dave S
    Boston
    I am:
    • Professional
    Reviewed at:
    Price: $899.99
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
