based on 17 reviews
Ratings Distribution
| 5 star |
10 |
| 4 star |
4 |
| 3 star |
2 |
| 2 star |
0 |
| 1 star |
1 |
Category Average
$6.95 - $7.95
from 2 storesPros
Cons
Best Uses
Where to Buy
BizRate Rating
Outstanding 9.6
$6.95 |
No Tax Outside NY | |||
BizRate Rating
Outstanding 9.1
$7.95 |
at
Adorama
Product Reviews
"I have a 77mm Circular Polarizer that fits on my largest lenses, and I needed one for my Canon 70-200mm f/4 as well. Instead of spending big bucks for a new filter, this adapter works perfectly. My only complaint is that it is not made to the best of standards, and the threads do not look like they will hold up forever. But so far, it's worked great...." Read Full Review »
Jul 31, 2008 by dpollitt
See more positive Adorama Step-Up Adapter Ring 67mm Lens to 77mm Filter Size reviews
"I use it on my 70-200f4 IS Canon lens.Works well if you have the time to thread it on and saves some money if you don't want to buy a dedicated 67mm polarizer or filter. I gave it a 3 star because if stepped on by a boot with a heavy person on concrete It would probably bend. If properly used it would get a 4 star and not a 5 because it isn't stainless steel...." Read Full Review »
Jul 03, 2008 by Spookonthe8ball
See more negative Adorama Step-Up Adapter Ring 67mm Lens to 77mm Filter Size reviews
Displaying 1 - 5 of 17 Reviews
Adorama Step-Up Adapter Ring 67mm Lens to 77mm Filter Size Review
Pros
Cons
Best Uses
Read Full Review »
Pros
Cons
Best Uses
"I have a 77mm Circular Polarizer that fits on my largest lenses, and I needed one for my Canon 70-200mm f/4 as well. Instead of spending big bucks for a new filter, this adapter works perfectly. My only complaint is that it is not made to the best of standards, and the threads do not look like the …" Read Full Review »
Pros
Cons
Best Uses
"This inexpensive accessory allows me to use one filter size for many different lenses. I can afford to by better filters by not having to use multiple sizes. Well worth the price! "
[1 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"This step up adapter does exactly what it is supposed to do. The threads are a little difficult to work with and require you to make sure you get your filters perfectly set before you start to screw them in. Overall it is a good adapter. "
Pros
Cons
Best Uses
"General Brand step up ring works perfectly. Mounts tightly and securely. Only slightly less solid feel than much more expensive counterparts. The only difference you'll notice is the lack of branding and more dollars in your pocket! "
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.6
$6.95 |
BizRate Rating
Outstanding 9.1
$7.95 |
at
Adorama
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
