Adorama Electronic Slave Unit
#382
3.5
based on 24 reviews
from $16.95
Ratings Distribution
5 star
3
4 star
14
3 star
2
2 star
1
1 star
4
Category Average
4.3
$16.95 at Adorama
Find it at Amazon
Find it at Ebay
Pros
  • Lightweight (15)
  • Reliable (10)
  • Convenient interface (7)
  • Easy to use (6)
  • Easy to pack (3)
  • Well built / quality construction (3)
  • Has not missed a shot (1)
  • Hasn't failed to fire yet (1)
  • High quality (1)
  • Light weight but reliabl (1)
See less See more
Cons
  • Weak construction (8)
  • Unreliable (4)
  • Difficult to use (2)
  • Poor interface (2)
  • Adequate construction (1)
  • Fires on ttl pre-flash (1)
  • Hot shoe foot too fragile (1)
  • Lighter construction (1)
  • Line of sight (1)
  • Maybe needs tighter base (1)
Best Uses
  • Lighting (10)
  • Fill flash (8)
  • Photography (7)
  • Night photography (2)
  • Close -ups (1)
  • Flash sync (1)
  • Multi-point lighting (1)
  • Nighttime (1)
  • Off-camera flash (1)
  • Still life (1)
Provided by Adorama
Specification Description
Model PSL15 1315
Select Hotshoe,PC
Adorama Electronic Slave Unit Questions
Questions and Answers
Where to Buy
$16.95
BizRate Rating Outstanding 9.2
Product Reviews
Last update: Oct 29, 2009
Adorama Electronic Slave Unit Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
4.0
Works great, but very loose fitting
"This worked great to wirelessly control my SB-600 from my Nikon D50. I definitely had to have both the camera and flash in Full Manual mode, and no TTL! My only big complaint is how loose my flash fits in the device, and also how very loose the device fits in my flash stand. The device does have the option to attach a tripod screw, so that is a plus, but very careful handling is required...." Read Full Review »
Mar 18, 2008 by Raterus
See more positive Adorama Electronic Slave Unit reviews
1.0
works very poorly
"this flash trigger fits horribly on my sb-600 it will only work if the flash is lying on the ground, i tryed mounting it to my manfroto light stand and was impossible to get to work. i had to shove a piece of foil near the lock switch just to get it to work 1 in 10 times. i wouldnt reccoment this unit its worth the money to get a more solid one...." Read Full Review »
Oct 29, 2009 by [@]
See more negative Adorama Electronic Slave Unit reviews
Displaying 1 - 5 of 24 Reviews
Show
Sort by
4.0
    Pros
  • Lightweight
  • Reliable
    Cons
  • Weak Construction
    Best Uses
  • Fill Flash
  • Lighting
  • Photography
My only big complaint is how loose my flash fits in the device, and also how very loose the device fits in my flash stand. The device does hav …"  Read Full Review »
Was this Camera Flash Accessory review on the Adorama Electronic Slave Unit helpful to you?
 Report Abuse  (2)  (0)  0 comments
Mar 18 2008
Raterus
Rocky Mount, NC
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $16.95
works very poorly
1.0
    Pros
  • Easy To Pack
    Cons
  • Difficult to Use
  • Unreliable
  • Weak Construction
    Best Uses
  • Nighttime
"this flash trigger fits horribly on my sb-600 it will only work if the flash is lying on the ground, i tryed mounting it to my manfroto light stand and was impossible to get to work. i had to shove a piece of foil near the lock switch just to get it to work 1 in 10 times. i wouldnt reccoment this un …"  Read Full Review »
Oct 29 2009
truckee, ca
I am:
  • Semi-pro Photographer
Reviewed at:
Price: $16.95
Good and affordable
4.0
    Pros
  • Convenient Interface
  • Easy to Use
  • Lightweight
  • Reliable
  • Strong Construction
    Cons
  • Fires on TTL Pre-Flash
    Best Uses
  • Flash Sync
"Very good device for a great price. I have two of them. They work well and reliably. They are plastic and solid. I've had no issues.
The expected things to be aware of is that they will fire on TTL Pre-Flashes; but you shouldn't be using these for TTL. If they happen to be sitting in a bri …"  Read Full Review »
Jan 21 2009
Mike
Virginia
I am:
  • Photo Enthusiast
Reviewed at:
Price: $16.95
Use on SB-600 and SB-800 - too loose
3.0
    Pros
  • Lightweight
    Cons
  • Poor Interface
    Best Uses
  • Fill Flash
  • Lighting
  • Night Photography
"I purchased three to use with the SB-800 & SB-600 when I wanted them to work as fill and highlight strobes with wired studio grade flashes.
The three shoes all had different tolerances with different levels of fit. None worked firmly with the shoe-lock on the SB-800/600. Modifications to the s …"  Read Full Review »
Aug 24 2008
Luminos
Baltimore
I am:
  • Professional
Reviewed at:
Price: $16.95
Reliable no-nonsense photographic tool
4.0
    Pros
  • Easy To Pack
  • Easy to Use
  • Lightweight
  • Reliable
  • Self-contained
  • More »
    Cons
  • Line of sight
    Best Uses
  • Close -ups
  • Still life
"Slave unit is reliable and easy to use on flash units, especially for supplemental lighting. I use them in still life and close-up photography. The fact that they are one-piece units is helpful, unlike remote triggers and receivers. The only downside is the need for a relatively clear view of trigge …"  Read Full Review »
Dec 29 2008
philoctetes
Severna Park, MD
I am:
  • Photo Enthusiast
Reviewed at:
Price: $16.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
