Acu-Rite 00613 Indoor Humidity Monitor
#25
4.0
based on 26 reviews
from $16.99
Ratings Distribution
5 star
15
4 star
5
3 star
1
2 star
0
1 star
5
Category Average
3.7
Low Price:
$16.99 at iaqsource.com
$16.99 at prothermostats.com
Find it at Amazon
More Images
Pros
  • Consistent performance (17)
  • Easy to configure (11)
  • Durable (8)
  • Versatile (8)
  • Easy to use (3)
  • Accurate (1)
  • Easy to read (1)
  • Easy to understand (1)
  • Portability (1)
  • Small (1)
See less See more
Cons
  • Unreliable (5)
  • Poor design (1)
Best Uses
  • Home (9)
  • Portable devices (6)
  • Around the house (1)
  • Damp basement (1)
  • Garage (1)
  • Home humiditytemperature (1)
  • In the wine cellar (1)
  • Wine cellar (1)
  • Works great for home humi (1)
Provided by iaqsource.com
Features: Displays indoor humidity and temperature Displays Lo / OK / Hi comfort level icon Keeps track of daily high/low temperature and humidity Uses 1 AA (1.5V) alkaline battery (not included) Main unit dimensions: 3" X 2 1/2" X 1 1/4" inches Includes magnetic back for easy mounting to metal surfaces Includes tilt stand for easy display on tables and desks This product can help you monitor the effectiveness of your dehumidifier and/or humidifier.
Acu-Rite 00613 Indoor Humidity Monitor Questions
Questions and Answers
Where to Buy
$16.99
BizRate Rating Outstanding 9.1
$16.99
Product Reviews
Last update: Aug 6, 2009
Acu-Rite 00613 Indoor Humidity Monitor Reviews
Most helpful positive review
Most helpful negative review
5.0
Cool little device
"for the price, this thing works great. I moved it from room to room and let it stabilize overnight and its great. After a few days, you get the min/max readings and they are right on. I have anothe device for 3x the price, yes, it has larger numbers, but this one tracks right along with the expensive units...." Read Full Review »
Aug 06, 2009 by Phil in Volcanoland
See more positive Acu-Rite 00613 Indoor Humidity Monitor reviews
1.0
Poor accuracy
"I purchased this device to monitor room relative humidity where computer equipment operates, and noticed that it read about 35% initially, and I was happy the room was ok (meaning under 50%). When I borrowed a certified and calibrated instrument to check the humidity levels, I found it to be about 68%. This device has a 50% error reading relative humidity rendering it totally useless. Do not trust it for accurac..." Read Full Review »
May 27, 2009 by GaryDoug
See more negative Acu-Rite 00613 Indoor Humidity Monitor reviews
Displaying 1 - 5 of 26 Reviews
Show
Sort by
Cool little device
5.0
    Pros
  • accurate
  • Consistent Performance
  • Durable
  • Easy To Configure
  • Easy To Use
    Cons
  • None
    Best Uses
  • Damp basement
  • Garage
  • Home
  • Wine Cellar
"for the price, this thing works great. I moved it from room to room and let it stabilize overnight and its great. After a few days, you get the min/max readings and they are right on. I have anothe device for 3x the price, yes, it has larger numbers, but this one tracks right along with the expensiv …"  Read Full Review »
Was this Weather Station review on the Acu-Rite 00613 Indoor Humidity Monitor helpful to you?
Aug 6 2009
Phil in Volcanoland
Singapore NY
I am:
  • Casual User
Reviewed at:
Price: $16.99
Poor accuracy
1.0
    Pros
  • Easy To Use
    Cons
  • Poor Design
  • Unreliable
    Best Uses
  • Home
"I purchased this device to monitor room relative humidity where computer equipment operates, and noticed that it read about 35% initially, and I was happy the room was ok (meaning under 50%). When I borrowed a certified and calibrated instrument to check the humidity levels, I found it to be about 6 …"  Read Full Review »
May 27 2009
GaryDoug
Florida
I am:
  • Casual User
Reviewed at:
Price: $16.99
Very functional product
4.0
    Pros
  • Durable
  • Easy To Configure
  • Versatile
    Cons
  • None
    Best Uses
  • In the Home
"This unit enables me to verify that I am using my humidifier correctly during winter heat season. Great magnet to attach to refrigerator or back snaps open to sit on bureau in bedroom. Can't verify totally accurate, but so far results seem consistent enough to believe it is reliable. "
Jan 5 2009
hollrm
Tamaqua, PA
I am:
  • Casual User
Reviewed at:
Price: $16.99
All-around easy to use and read
4.0
    Pros
  • Easy To Configure
  • Versatile
    Cons
  • None
    Best Uses
  • In the Home
"I've been using this device to quickly ascertain temperature and humidity differences in my home at different times of year. It's not a particularly sophisticated device, but that's not what I'm after. I like its storage of 24-hr max/min temp and RH, which I haven't seen on other inexpensive units …"  Read Full Review »
Nov 13 2008
faithandreason
Ann Arbor, MI
I am:
  • Casual User
Reviewed at:
Price: $16.99
Sorry but it is not accurate!
1.0
    Pros
  • None
    Cons
  • Unreliable
    Best Uses
  • Home
"Bought 2 of these Monitors, and they don't read the same, in the same room, at the same time, next to one another. One or both is not accurate, I don't know which. It appears to me that the mfgr didn't calibrate one or both. Sorry, but I would not recommend this product. "
May 26 2009
Old Jer
Bloomfield Hills, MI
I am:
  • Casual User
Reviewed at:
Price: $16.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
