Actiontec Electronics, Inc. 85 Mbps Powerline Eth. Adap. & 4Port Hub
#61
4.2
based on 5 reviews
Ratings Distribution
5 star
3
4 star
1
3 star
0
2 star
1
1 star
0
Category Average
3.8
Low Price:
$84.95 at B&H Photo Video
 Trusted:
$119.99 at MacMall
Find it at Amazon
$84.95 - $129.99
from 5 stores
More Images
Provided by Beach Audio
MODEL- HLE08509-01KE VENDOR- ACTIONTEC ELECTRONICS
FEATURES- MegaPlug 85 Mbps 4-port Hub/Ethernet Adapter Bundle
Actiontec's MegaPlug 85 Mbps 4-Port Hub expands your network without
breaking your bank. Perfect for use with DSL modems, gateways, or
broadband routers with just one Ethernet port, the 4-Port Hub works
seamlessly with the MegaPlug 85 Mbps Ethernet Adapter to provide
network coverage in every room of your home or small office with an
electrical outlet. There's no easier or more affordable way to
extend your home network than the Actiontec MegaPlug 85 Mbps 4-Port
Hub.
Ethernet ports are valuable. They are often the only way to connect
computers, printers, and other devices (scanners or networkable
hard drives), share Internet connections, or quickly transfer large
amounts of data. Unfortunately, many of the components at the heart
of a network, like DSL modems or gateways, feature only a single
Ethernet port, leaving you with no way to expand your network.
Enter the MegaPlug 4-Port Hub. By adding multiple Ethernet ports to
your network, suddenly, the possibilities are endless. Now you can
send data from a computer in the study to one in the family room or
use the printer in the bedroom from a computer in the kitchen.
You'll be amazed at what you can do!
To make things even easier, the MegaPlug 4-Port Hub can be used with
the MegaPlug Ethernet Adapter and Wireless Network Extender,
extending your network options even further. Instead of stringing
Ethernet cables all over your home or office, use the power lines
that already connect your rooms to complete your network. Set up is
a breeze; in no time, you'll be enjoying the endless benefits of
networking your devices. Step confidently into the networking age
with the MegaPlug 85 Mbps 4-Port Hub.
* No new cables required. Uses your existing power lines.
* Very Easy to Use -- Simply plug in
* Compatible with any Router or Gateway
* Supports HomePlug speeds up to 85 Mbps
* Integrated QoS
* Perfect for gaming! Use with any Gaming Console.
* Secure data encryption
-- HLE0850901 SPECs ----------------------------------
STANDARDs - IEEE 802.3, HomePlug Turbo Powerline Specification 1.0.1
PROTOCOLS - Forward Error Correction (FEC)
Automatic Channel Adaptation
DATA RATEs - Up to 85 Mbps over standard home power lines
RANGE - Up to 300 meters in wall power lines
Capable of passing through circuit breakers
SECURITY - 56-bit DES Data Encryption
FREQUENCY - 4.3 MHz ~ 20.9 MHz
MODULATION - OFDM Symbol Modulation
DQPSK
DBPSK
ROBO Carrier Modulation
QoS - Integrated
Prioritized Random Access
Contention-Free Access
Segment Bursting
INDICATORs - LEDs for Power, Link
APPROVALs - FCC Part 15 Class B
UL
REQUIREMENTS - Router, Gateway, or other device with HomePlug capability
Microsoft Windows 98SE,Me, 2000 or XP
TCP/IP Network Protocol Installed
Internet Explorer 4.0+ or Netscape 4.0+
POWER SOURCE - 100 to 240V @ 50/60 Hz internal
-- HLE0850001 SPECs ---------------------------------
DQPSK
DBPSK
QoS - Integrated
Segment Bursting
UL
www.actiontec.com
Specification Description
Model HLE08509-01KE, HLE0850901KE
UPC 789286806451
Accessory Indicator Yes
Benefits Uses your existing power lines so no extensive new cabling required othInstallation is a breeze, simply plug it inIdeal for
Cables Included Ethernet cables (2)
Capacity UOM mAh
Connections RJ-45 Ethernet ports Hub (4)RJ-45 Ethernet port 85Mbps adapter (1)
Country Of Origin China
Description Header Easy network expansion.
Display Catalog Number 55032147
Humidity Range Operating 10~85%
Included in the Box MegaPlug™ 85 Mbps 4-Port HubQuick Start Guide (2)Installation CD (2)UserManual on CD (2)Ethernet Cabl
Manufacturer Labor Warranty 12
Manufacturer Part Number HLE08509-01KE
Manufacturer Parts Warranty 12
MAP Price 0.0
Max Operating Temperature 104 Fahrenheit
Min Operating Temperature 32 Fahrenheit
Model HLE08509-01KE
Operating Temperature UOM ° F
Power Device AC
Product Type Hubs
Required to function Router, Gateway, or other device with HomePlug capabilityMicrosoft Windows 2000, XP or VistaTCP/IP Network Protocol Installe
Supported Languages English
Actiontec Electronics, Inc. 85 Mbps Powerline Eth. Adap. & 4Port Hub Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 10, 2009
Actiontec Electronics, Inc. 85 Mbps Powerline Eth. Adap. & 4Port Hub Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
[1 of 2 customers found this review helpful]
Provides the solid connection my wireless setup was failing to do.
4.0
"Having moved to a new apartment my only initial option was wireless. Although I'm able to connect at 54Mb/s the wireless connection in my office just wasn't cutting it with frequent disconnects and slow transfer speeds.
Now, I've heard of Ethernet over Power (EoP) before, but never had I thought …"  Read Full Review »
Was this Network Router & Bridge review on the Actiontec Electronics, Inc. 85 Mbps Powerline Eth. Adap. & 4Port Hub helpful to you?
 Report Abuse  (1)  (1)  0 comments
Jan 16 2008
Philip H. Zimmermann
Los Angeles, CA USA
Reviewed at:
Price: $129.99
Should have been advertised as "12Mbit/sec". That's 14% efficiency.
2.0
"I'm conflicted as to how many stars to give it because it does work, it's pretty cool, but performs WAY BELOW the stated speed, so then I'd have to say that it doesn't work as it should.
I'm getting 12Mbits/sec throughput (10 foot distance between wall plugs (upstairs/downstairs))
Let's calculate: …"  Read Full Review »
Jul 23 2008
N. Morris
Pennsylvania
Reviewed at:
Price: $129.99
Works as advertised
5.0
"This thing just works. I hooked up one to my Linksys router and plugged it in, and gave another one to my wife to use with her laptop. She loves it. She can plug in anywhere in the house and surf away. No setup or special software, just plug and play with XP and the Linksys. Then I got another adapt …"  Read Full Review »
Sep 11 2008
Mark Easley
Amazon
Reviewed at:
Price: $129.99
Perfect for Dish networking
5.0
"Got this set to hook up our new Dish Vip722 receiver so we didn't have to have a phone line in the room. Also needed to attach the new Samsung TV to the network to use it's internet features. Since the hub has 4 port, it allows us to attach other game machines or computers directly to our router d …"  Read Full Review »
May 10 2009
R. Davenport
San Jose
Reviewed at:
Price: $129.99
Does the work
5.0
"Excelent product, worked fine out of the box.
Very simple to use and connect.
I don't do heavy downloads or run high bandwidht applications, but browsing and normal internet traffic is perfect!
The relation between price, performance and quality is very good! "
May 1 2009
Sistelcom Wolfran Sorto Sanchez
Amazon
Reviewed at:
Price: $129.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
