AcoustiClear® Desktop CD Shelf System
2.4
based on 7 reviews
Ratings Distribution
5 star
1
4 star
2
3 star
0
2 star
0
1 star
4
Category Average
4.1
Pros
  • Attractive design (7)
  • Great sound quality (6)
  • Compact (5)
  • Easy setup (5)
  • Amazing (1)
  • Durable (1)
  • Nice design (1)
See less See more
Cons
  • Not durable (3)
  • Build terrible (1)
  • Cd player unstable (1)
  • Not read cd's correctly (1)
  • Shaky reception (1)
Best Uses
  • Smaller rooms / apartments (5)
  • Basic systems (3)
  • Entertainment (2)
  • Large rooms (1)
  • Production quality (1)
Provided by Brookstone
Brookstone AcoustiClear® shelf CD stereo…Sound as we see it.™
Now you can listen to music from a shelf CD stereo that doesn’t clutter your desk – or your mind. The slim-line elegance of the AcoustiClear® shelf stereo system belies its raw power and exceptional sonic definition. Our coolest shelf stereo is the purest reflection of our design vision—great speakers should be heard, not seen.
Hear the difference flat, transparent speakers make on our coolest shelf stereo system.
Transparent, flat-panel speakers use leading-edge technology to deliver truly superior sound:
  • NXT Flat Panel Technology creates a broad “sweet spot” traditional cone speakers cannot match
  • Their flat, transparent design creates a rich, three-dimensional soundstage of room-filling music
  • Add a 3” integrated subwoofer with dual-ported sound enclosures, and you have a concert hall on your desktop!
    Enjoy more options with the AcoustiClear® shelf stereo system–and more space.
    Every function on the AcoustiClear® shelf cd stereo can be controlled with the wafer-thin, ergonomically weighted remote control. Our coolest shelf stereo system mounts easily to a wall leaving surface space neat and clutter-free.
    Our shelf CD stereo makes the perfect gift.
    The most discerning audio enthusiast will love the AcoustiClear® shelf CD stereo. Buy one today!
  • AcoustiClear® Desktop CD Shelf System Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: AcoustiClear® Desktop CD Shelf System
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Nov 3, 2007
    AcoustiClear® Desktop CD Shelf System Reviews
    Displaying 1 - 5 of 7 Reviews
    Show
    Sort by
    [2 of 2 customers found this review helpful]
    Nice to look at
    1.0
      Pros
    • Attractive Design
    • Compact
    • Great Sound
    • Nice Design
      Cons
    • Build Terrible
    • Not Durable
    • Not Read CD's Correctly
      Best Uses
    • Smaller Rooms
    "The CD player is the worst part of this product. I am in the process of sending my old unit back for a new unit. Hopefully the CD player on the new unit will work better.
    From the reviews I have read on the various websites, many people have had problems with the CD player of this product. "
    Was this Shelf System review on the AcoustiClear® Desktop CD Shelf System helpful to you?
     Report Abuse  (2)  (0)  0 comments
    Jul 18 2007
    Jake
    San Jose, CA
    I am:
    • Practical
    Reviewed at:
    [1 of 1 customers found this review helpful]
    Nice Product
    4.0
      Pros
    • Attractive Design
    • Clear sound
    • Compact
    • Easy To Set Up
      Cons
    • None
      Best Uses
    • Basic Systems
    • Entertainment
    • Smaller Rooms
    "I use the system in my bedroom. It's great for my purposes. It beats the standard cd player/radio, however it's not the most amazing sound that I have ever heard. But overall it works well and the price is right. I like the fact that it doesn't take up much room. It is wall mountable, which I p …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Oct 22 2007
    Sparkling Sarah
    SC
    I am:
    • Audiophile
    • Musically Inclined
    • Practical
    • Tech Savvy
    Reviewed at:
    Garbage
    1.0
      Pros
    • Attractive Design
    • Clear sound
      Cons
    • Not Durable
      Best Uses
    • None
    "aside from the eye pleasing design theres not much else about this product has going for it. the radio tuner would work according to its own little whimsy. the cd player, when it decided to work, would at most play the cd once through then completely cease to play any more. the only solution was to …"  Read Full Review »
    Oct 22 2007
    review
    ohio
    I am:
    • Audiophile
    Reviewed at:
    [...] not willing to exchange
    1.0
      Pros
    • Attractive Design
    • Compact
    • Easy To Set Up
      Cons
    • CD Player unstable
    • Not Durable
      Best Uses
    • Smaller Rooms
    "CD portion of item has had problems since receiving. The CD would go in and would display "no disc" - after a few attempts and a few taps the disc would play - would happen periodically so thought not much of it but now (a year later) it always says "no disc" when a disc is in so item is basically …"  Read Full Review »
    Nov 3 2007
    Chrissy
    NY
    Reviewed at:
    Very nice
    4.0
      Pros
    • Attractive Design
    • Easy To Set Up
      Cons
    • Shaky reception
      Best Uses
    • Basic Systems
    • Smaller Rooms
    "I bought this as a gift. The recipient was very pleased, although the radio stations do not come in crystal clear. They used the wire "antenna" to improve this. Otherwise, very nice looking, space-saver unit. "
    Oct 29 2007
    MM
    Chicago
    I am:
    • Practical
    • Technically Challenged
    Reviewed at:
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
