Acoustic Research AW822 900-MHz Indoor or Outdoor Wireless Speaker
4.0
based on 9 reviews
from
Ratings Distribution
5 star
2
4 star
6
3 star
0
2 star
1
1 star
0
Category Average
4.4
More Images
Pros
  • Great sound quality (10)
  • Easy to connect (7)
  • Powerful (4)
  • Attractive design (2)
  • Adjustable freq channels (1)
  • Can recharge lithium batt (1)
  • It eats batteries warn u (1)
  • Need battery charger (1)
  • Warn that it eats battery (1)
See less See more
Cons
  • Connections just ok (1)
  • Nothing negative to state (1)
  • Touchy volume control (1)
Best Uses
  • Outdoors (6)
  • Basic systems (4)
  • Smaller rooms / apartments (2)
  • Creative zen (1)
  • Home theater (1)
  • Ipod (1)
Provided by Beach Audio
Having your tunes with you outside on the deck or patio is pretty cool, but some wired solutions are too much work and inconvenient. Or enjoy listening to music in any location without sacrificing high quality sound. The AW822 uses AR's patented wireless technology and convenient push button, auto lock PLL tuning to guarantee a clear audio signal up to 250 feet away from the transmitter, through walls, floors, windows and ceilings. So go beyond the limits of wired connections.
Specification Description
Model AW-822, AW822, RCAAW822
UPC 044476042225
Battery Type Product
Benefits Up to 250' range through walls, windows and ceilings2-way 7.5 watts, 5" woofer, 2" tweeterAutomatic tuning and level control
Capacity 8
Capacity UOM mAh
Connectivity technology Wireless
Country Of Origin China
Description Header Plug-in and play anywhere!
Display Catalog Number 55029050
Enclosure Color Multi
Frequency response 40Hz-15kHz
Included in the Box Wireless indoor/outdoor speakerAC adapter
Manufacturer Labor Warranty 1
Manufacturer Part Number AW822
Manufacturer Parts Warranty 1
MAP Price 0.0
Model AW822
Operating Temperature UOM ° F
Power Device AC or "C" battery
Power range 7.5 watts
Product Dimensions UOM inches
Product Type Speakers
Product Weight UOM pounds
Size C
Speaker type Outdoor
Speakers included 2
Supported Languages English
Tweeter size 2 inches
Tweeter type Dome
Water resistant Yes
Woofer size 5 inches
Acoustic Research AW822 900-MHz Indoor or Outdoor Wireless Speaker Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: AW822 900-MHz Indoor or Outdoor Wireless Speaker
See all eBay results
  at eBay.com
Product Reviews
Last update: Sep 14, 2009
Acoustic Research AW822 900-MHz Indoor or Outdoor Wireless Speaker Reviews
Displaying 1 - 5 of 9 Reviews
Show
Sort by
[4 of 4 customers found this review helpful]
Well worth it!!!
4.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Great Sound Quality
    Cons
  • None
    Best Uses
  • Basic Systems
"My wife got this as a birthday gift from a friend, and I surprised by the sound. For a wireless speaker I was very impressed. I have taken this thing all over my house and outside and have not had any interference or cracking of the sound. Recommended! "
Was this Speaker & Subwoofer review on the Acoustic Research AW822 900-MHz Indoor or Outdoor Wireless Speaker helpful to you?
 Report Abuse  (4)  (0)  0 comments
Oct 27 2008
Joefbs
Tampa, FL
I am:
  • Practical
  • Tech Savvy
Reviewed at:
Excellent Product - What I Hoped For
5.0
    Pros
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
    Best Uses
  • Basic Systems
  • Outdoors
  • Smaller Rooms
"I bought two speakers for stereo use with my 19-year-old Kenwood amplifier and hoped I could make them work with this older system. I also wanted the backup transmitter buying two speakers provides. Transmitter connects to the headphone outlet and will transmit sound simultaneously with the system s …"  Read Full Review »
Feb 11 2009
Walkindude
Baltimore, MD
I am:
  • Tech Savvy
Reviewed at:
Economical Simple wireless speaker
4.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • More »
    Cons
    Best Uses
  • Basic Systems
  • Creative zen
  • Ipod
  • Outdoors
"Simple set up. Clear Sound. Large volume speaker output range. Very portable (if you use rechargeable batteries) which the unit will recharge for you using the AC plug in. Otherwise you will need two power sources one for the wireless speaker and one for the transmitter. Good outdoor/yard or garage …"  Read Full Review »
Jun 22 2009
Steve
Kamulea,HI
I am:
  • Engineer
  • Musically Inclined
  • Professional
  • Tech Savvy
Reviewed at:
Amazing Speaker For The Price!!!
4.0
    Pros
  • Easy To Connect
  • Powerful
    Cons
  • Touchy Volume Control
    Best Uses
  • Outdoor Patio
"Unit was very easy to install. Sound was good but the Volume control was very touchy. If you wanted background sound it was hard to get low volume only loud and then louder. Speaker being used on Outside Patio for use while BBQing and Hanging in the back yard. I would reccomend this product to anyon …"  Read Full Review »
Dec 3 2008
Jon Master BBQer
Dallas, Tx
I am:
  • Professional
Reviewed at:
Put the Party Anywhere!
4.0
    Pros
  • Easy To Connect
    Cons
  • None
    Best Uses
  • Outdoors
"We replaced an older model wireless speaker with this new one. Very happy with the range, clarity and the autotuning. This speaker works in places the other one didn't. Great price at JR! "
Jul 28 2009
ECYC
Cornelius, NC
I am:
  • Practical
Reviewed at:
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
