Acer AL2216WBD 22 Widescreen LCD Monitor
4.3
based on 41 reviews
from
Ratings Distribution
5 star
48
4 star
32
3 star
7
2 star
1
1 star
3
Category Average
4.4
More Images
Pros
  • Great picture quality (51)
  • Vivid colors (45)
  • Lightweight (34)
  • Versatile (24)
  • Adjustable (23)
  • Large viewing area (5)
  • Pricey (3)
  • Reliable (3)
  • Hdcp (2)
  • Adjustable viewing angles (1)
See less See more
Cons
  • Lacks adjustability (2)
  • Bad shadows in photos (1)
  • Can't adjust height (1)
  • Colors not vivid (1)
  • Dead pixels (1)
  • Doesn't look good closeup (1)
  • Images not sharp (1)
  • Inaccurate colors (1)
  • It didn't work (1)
Best Uses
  • Multimedia (24)
  • Gaming (10)
  • Dorm room (7)
  • Hooked to a laptop (6)
  • Movies (3)
  • Spreadsheets (3)
  • Home office (2)
  • Office (2)
  • Ps3 (2)
  • Business (1)
Provided by Buzzillions.com
The Acer AL2216WBD offers the best visibility, performance and unprecedented value. The high level of brightness 300cd/m2 together with the optimal contrast ratio of 700:1 renders crisp images and enhances legibility. With its fast response time of 5ms, the Acer AL2216WBD brings remarkable display quality to your desktop.
The essence of versatile productivity, the Acer AL2216Wbd brings you the right combination of high-definition performance, slim design and cost effectiveness.
  • Screen Size: 22"
  • Input Signal: Analog, Digital
  • Viewing Angle: 170 Horizontal / 160 Vertical
  • Maximum Resolution: 1680 x 1050
  • Aspect Ratio: 16:9
  • Contrast Ratio: 700:1
  • Brightness: 300 Nit
  • Interfaces: 1 x 15-pin D-Sub, 1 x DVI-D (Digital)
  • Color: Black
  • Specification Description
    Model 1188161, AL2216WBD, ET.2216B.0D0, ET2216B0D0
    UPC 099802554439
    Aspect Ratio 16:10
    color Black
    Connector - Analog Yes
    Connector - Digital Yes
    Contrast Ratio 700:1
    Integrated Speakers Yes
    Macintosh Compatible Yes
    Manufacturer’s Warranty - Hardware 3 Years
    Resolution 1680 x 1050
    Response Time (Milliseconds) 5
    Screen Resolution - Maximum 1680x1050
    Screen Size 22"
    Screen Size (Inches/Diagonal) 22
    size null
    sku 107233 Black
    skuprice 261.9900
    style ET2216B0D0
    Table Stand Yes
    taxable Y
    Wall Mountable Yes - Optional Mount Required
    Windows PC Compatible Yes
    Acer AL2216WBD 22 Widescreen LCD Monitor Questions
    Questions and Answers
    Where to Buy
    Amazon   at Amazon.com
    ebay
    eBay listings for: AL2216WBD 22 Widescreen LCD Monitor
    See all eBay results
      at eBay.com
    Product Reviews
    Last update: Apr 10, 2009
    Acer AL2216WBD 22 Widescreen LCD Monitor Reviews
    Most helpful positive review
    [4 of 4 customers found this review helpful]
    Most helpful negative review
    [9 of 10 customers found this review helpful]
    5.0
    Great for PS3, Linux and even Windows
    "I hoooked this up to my son's PS3 and Linux and Windows computers. He's been using it for gaming on the PS3 and linux, and for his school work and general activities on linux. It does also work for windows, but he rarely has need to use that. It is an excellent buy, particularly since it supports HDCP, which allows it to be used with the PS3...." Read Full Review »
    Dec 29, 2007 by Dave (the geek dad)
    See more positive Acer AL2216WBD 22 Widescreen LCD Monitor reviews
    1.0
    Cheap price, bad quality and unreliable
    "It shown a black block region in the right bottom corner after using for 6 months. Shipped it to Acer for repair because it stated 3 years warranty. However, Acer declared that it's leaking internally and it's not covered by warranty! Had another Acer 24" LCD. The color was not correct and hurt eyes. The whole screen became totally black and could not be turn on again after using for only 10 mins. Return ..." Read Full Review »
    Feb 24, 2008 by none
    See more negative Acer AL2216WBD 22 Widescreen LCD Monitor reviews
    Displaying 1 - 5 of 41 Reviews
    Show
    Sort by
    [2 of 2 customers found this review helpful]
    Decent for its price
    4.0
      Pros
    • Durable
    • Good Value
      Cons
    • None
      Best Uses
    • None
    "Before I bought this LCD, I had 2 Viewsonic 15" CRT's. I decided it was time to get something better, and this was the cheapest LCD I could find over 20". Even though it's made by Acer, it's still pretty good. Just expect a lot of color adjusting and tuning. I've used my Spyder every day, every 2 ho …"  Read Full Review »
    Was this LCD Monitor review on the Acer AL2216WBD 22 Widescreen LCD Monitor helpful to you?
     Report Abuse  (2)  (0)  0 comments
    Jan 22 2008
    Eric Tam
    Woodside, NY
    Reviewed at:
    [1 of 1 customers found this review helpful]
    Good value, not for graphics folks
    3.0
      Pros
    • Large Viewing Area
      Cons
    • Poor picture quality
      Best Uses
    • Spreadsheets
    "I use this monitor primarily for editing code, so it works well for me. Lots of screen real estate and the resolution is pretty good.
    However, the color reproduction is awful. I had to configure a new color profile after connecting this to my Mac. Also, when viewed out of the corner of my eye, I …"  Read Full Review »
     Report Abuse  (1)  (0)  0 comments
    Jun 19 2008
    Jason the Coder
    Marlton, NJ
    I am:
    • Business User
    Reviewed at:
    Acer is amazing.
    5.0
      Pros
    • Adjustable
    • Lightweight
    • Sharp Image
      Cons
    • none so far
      Best Uses
    • Multimedia
    "Acer is just one of those brands that can't seem to be beat. Ever since they entered the computer scene, I've looked to them for quality products at a price that is just too good to be true. I purchased these for the office, was well within budget and everyone was surpised because the budget was f …"  Read Full Review »
    Jun 9 2008
    Orson
    New York, NY
    I am:
    • Value Oriented
    Reviewed at:
    The glory of the real estate
    5.0
      Pros
    • nice picture, great size
    • Reliable Performance
    • Small Footprint
      Cons
    • Lacks Adjustability
      Best Uses
    • works well all around
    "Other than no up and down adjustment this has been an outstanding monitor, but a book takes care of that.
    I bought a second one for home, the jump from 17" to 22" is great, this is a cheap way to get there.
    Seems like it should profoundly suck at this low price but it's non-suckiness is startl …"  Read Full Review »
    Jun 19 2008
    powhack
    las vegas, nv
    I am:
    • Business User
    • Casual User
    Reviewed at:
    Truly a best buy at $169.99, a great monitor
    5.0
    "I bought this monitor when it was on sale for for $169.99 before taxes. I have had it now for about 3 weeks and I have had no problems with this monitior. To buy a 22 inch monitor at a 19 inch price, you can beat it. It you are looking for a cheap monitor or an upgrade this is the one. The screen is …"  Read Full Review »
    Dec 30 2008
    Cedrickw2
    Janesville, Wisconsin
    Reviewed at:
    pages: 1 2 3 4 5 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    ebay
      at eBay.com
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
