Close Login Module
Join
Accurian DVD Recorder/VCR Combo Unit
3.5
based on 11 reviews
Ratings Distribution
5 star
0
4 star
6
3 star
4
2 star
1
1 star
0
Category Average
3.8
Pros
  • Fast setup (6)
  • Simple controls (4)
  • Attractive design (2)
  • Fast recording (2)
  • Copies vhs tape to dvd-rs (1)
  • Easy to use (1)
See less See more
Cons
  • Discs load slowly (2)
  • Poor chapter publishing (1)
  • Remote is complicated (1)
Best Uses
  • Home (6)
  • Movies (2)
  • Archiving tv shows (1)
  • Professional (1)
  • Recording home movies (1)
  • Storage (1)
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: DVD Recorder/VCR Combo Unit
See all eBay results
  at eBay.com
Product Reviews
Last update: Jan 19, 2008
Accurian DVD Recorder/VCR Combo Unit Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
4.0
buy it.
"When a local vendor wanted 40 bucks to transfer my personal family events from vhs to dvd-he wanted 40 bucks PER one VHS tape. I bought this--and transferred a thousand dollars worth for the cost of a few DVD-r's... WARNING!!!!!!!!!! this unit only works with JVC dvd-r's. The manual also recommends MAXELL. This unit did not work with Sony, or many other dvd's i tried-- i almost brought it back until the JVC's wo..." Read Full Review »
Jul 27, 2007 by senny
See more positive Accurian DVD Recorder/VCR Combo Unit reviews
2.0
What this unit will do; ...
"What this unit will do; *Dub a VHS to a DVD-R or -RW (or vice versa), provided your source is not using a current copy protection, roughly anything prior to 2000. *Record to VHS or DVD from another player, camcorder, or TV, again provided the source is not copy protected. This protection can include satellite or cable broadcasts. What this unit will not do; *You cannot save most movies to DVD to consolidate you..." Read Full Review »
Jan 22, 2007 by Alexander S
See more negative Accurian DVD Recorder/VCR Combo Unit reviews
Displaying 1 - 5 of 11 Reviews
Show
Sort by
buy it.
4.0
    Pros
  • Fast Recording
  • Fast Setup
  • Simple Controls
    Cons
  • None
    Best Uses
  • Home
The manual also recomme …"  Read Full Review »
Was this DVD Recorder review on the Accurian helpful to you?
 Report Abuse  (2)  (0)  0 comments
Jul 27 2007
senny
cliffside park,nj
I am:
  • Practical
Reviewed at:
2.0
    Pros
  • Easy to use
    Cons
  • None
    Best Uses
  • None
"What this unit will do; *Dub a VHS to a DVD-R or -RW (or vice versa), provided your source is not using a current copy protection, roughly anything prior to 2000. *Record to VHS or DVD from another player, camcorder, or TV, again provided the source is not copy protected. This protection can include …"  Read Full Review »
Jan 22 2007
Alexander S
Michigan
Reviewed at:
Pretty good
3.0
    Pros
  • Fast Setup
  • Simple Controls
    Cons
  • Discs Load Slowly
    Best Uses
  • Home
"It's pretty simple to hook up and get set up..Timers, Clock, and etc very simple set up. The most unclear part is the correct way to format so you can watch your Tv recorded shows on different players. Still trying to figure that out. Others have said that only Maxell and Jvc disc work on this unit …"  Read Full Review »
Oct 15 2007
Cedar4life
Riverdale,GA
I am:
  • Tech Savvy
Reviewed at:
CSS protection can block legit recording
3.0
    Pros
  • Fast Recording
  • Fast Setup
    Cons
  • Discs Load Slowly
    Best Uses
  • Home
"It's an okay device. I use it to record home movies onto dvd from my camcorder. I bought it when it was going for a lot more than it is now. The dvd loading is extremely slow and the remote control buttons are very tiny; you'll have to look at it to find buttons that you should be able to "feel," e …"  Read Full Review »
Oct 23 2007
gmaster
goleta, ca
I am:
  • Tech Savvy
Reviewed at:
[1 of 1 customers found this review helpful]
As frustrating as sorting coat-hangers
3.0
    Pros
  • Fast Setup
    Cons
  • Poor Chapter Publishing
    Best Uses
  • None
"I have VHS tapes of old television shows from the 1980s, and one would think I would not get a recording error. I've also received the same error when attempting to copy old VHS tapes made from a videocamera. I'm just about ready to return this product, which I believe has been reduced so sharply in …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Dec 29 2007
Big Dad
Huntington, Ind.
I am:
  • Practical
Reviewed at:
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Out Of Stock
$29.97
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
