Accurian 9" Portable DVD Player
3.4
based on 18 reviews
Ratings Distribution
5 star
4
4 star
7
3 star
2
2 star
2
1 star
3
Category Average
3.7
Pros
  • Simple / intuitive controls (14)
  • Durable (11)
  • Great picture quality (10)
  • Easy to install (6)
  • Battery last great (1)
  • Good battery life (1)
  • Great color (1)
  • Great for outdoors (1)
  • Huge screen (1)
  • I like it lots (1)
See less See more
Cons
  • Picture freezes/skips (3)
  • Poor picture (3)
  • Confusing / difficult controls (2)
  • Battery failed within 1yr (1)
  • Long recharge time (1)
  • Low volume speakers (1)
  • Short life span (1)
  • Volume a bit too low (1)
Best Uses
  • Back seat (4)
  • Smaller cars (3)
  • Larger cars (2)
  • And listen to music (1)
  • Grandma's living room (1)
  • I have a dvd player (1)
  • I use around the house (1)
  • In children's rooms (1)
  • In scrap rooms (1)
  • On child's lap in car (1)
Provided by RadioShack
This 9" portable DVD player lets you watch your DVDs in 16:9 widescreen format.
Specification Description
Model 16-680
Battery Type Product
Benefits 9" (diagonal) high-resolution screen provides a clear and crisp 16:9 picture from any angleversatile player offers playback on DVDs,
Cables Included A/V cable
Capacity 2300
Capacity UOM mAh
Chemistry Lithium Polymer
Connections Headphone 1/8" (1)A/V out (1)
Country Of Origin China
Description Header Widescreen on the go.
Display Catalog Number 16-680
DVD Media Type DVD, DVD-RW, DVD-R, DVD+RW, DVD+R, DVD+R, SD/SDHC Memory Card
DVD Repeat Modes Title, chapter, A-B repeat
DVD Type 1 disc
Dynamic Range 85 dB
Enclosure Color Black
End Product Indicator Yes
Included in the Box Accurian™ 9" Widescreen Portable DVD PlayerRemote controlAC adapterCar battery chargerA/V cable<
Manufacturer Labor Warranty 90
Manufacturer Parts Warranty 90
MAP Price 0.0
Model 16-680
MP3 Compatible Yes
Operating Temperature UOM ° F
Parental controls Yes
Parental Lock Yes
Picture Zoom Yes
Power Device Rechargeable lithium polymer battery, AC adapter, DC adapter
Product Depth 1.52
Product Dimensions UOM inches
Product Height 1.52
Product Type Portable players
Product Weight 1.95
Product Weight UOM pounds
Product Width 9.37
Rechargeable Yes
Size Pack
Sound Output Mode Stereo
Supported Languages English, Spanish, French
Technology IR
TV Screen Saver Yes
Accurian 9" Portable DVD Player Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 9" Portable DVD Player
See all eBay results
  at eBay.com
Product Reviews
Last update: Jul 19, 2009
Accurian 9" Portable DVD Player Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
4.0
Works well, so far
"I bought this product for my children (ages 4 & 7 years) to use during a long car. They used it independently and was probably a bit more rough with it than an adult would be. The DVD player did not skip when moved around or bumped. The volume was too low for them to hear it when there was lots of wind resistance. They held it in their hands so they could hear it. I did not try headphones, which may have solved ..." Read Full Review »
Feb 18, 2009 by KT
See more positive Accurian 9" Portable DVD Player reviews
2.0
HAPPY @ 1ST BUT NOW VERY DISAPPOINTED
"I was extremely satisfied when I first bought this bc it solved my non-dvd player issues. It was especially gr8 4 my 5yr old 2b able 2 watch her movies while playing in her room. A yr later something is wrong w/it. 1 nite it was working fine & LITERALLY the next morning it doesn't read DVD's. It says "loading" 4 about 1 1/2 mins & then says "no disc" however when I put a music cd inside it plays the music just..." Read Full Review »
Jul 19, 2009 by A Very Unhappy Consumer!
See more negative Accurian 9" Portable DVD Player reviews
Displaying 1 - 5 of 18 Reviews
Show
Sort by
Works well, so far
4.0
    Pros
  • Kid friendly
    Cons
    Best Uses
"I bought this product for my children (ages 4 & 7 years) to use during a long car. They used it independently and was probably a bit more rough with it than an adult would be. The DVD player did not skip when moved around or bumped. The volume was too low for them to hear it when there was lots of w …"  Read Full Review »
Was this Car Video System review on the Accurian 9" Portable DVD Player helpful to you?
 Report Abuse  (2)  (0)  0 comments
Feb 18 2009
KT
Western New York
Reviewed at:
2.0
    Pros
  • Easy Controls
  • Easy To Install
    Cons
  • Low Volume Speakers
  • Short Life Span
    Best Uses
  • In Children's Rooms
  • In Scrap Rooms
A yr later something is wrong w/it. 1 nite it was working fine & LITERALLY the next morning it doesn't read DVD's. It …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jul 19 2009
Doesn't really matter, USA
I am:
  • Practical
Reviewed at:
Complete JUNK
1.0
    Pros
  • NONE
    Cons
  • Picture Freezes/Skips
  • Poor Picture
    Best Uses
  • Trash Can
"Well it only took 1 use and this thing to sit on a shelf for several months before taking another trip and finding out it would only hold 20-30 mins worth of a charge. BY THE WAY THE BATTERY IS INSIDE THE UNIT. That is the stupidest thing I have ever seen on a portable DVD player. By the way, NO I d …"  Read Full Review »
Oct 13 2008
Your Mom
Brunswick, ME
I am:
  • Electronics Guru
Reviewed at:
DVD PLAYER BY ACCURIAN
5.0
    Pros
  • BATTERY LAST GREAT
  • Durable
  • Easy Controls
  • Easy To Install
  • GREAT COLOR
  • More »
    Cons
  • None
    Best Uses
  • AND LISTEN TO MUSIC
  • I HAVE A DVD PLAYER
  • I USE AROUND THE HOUSE
  • TO USE TO WATCH MOVIES
  • WHEN THE POWER GOES OUT
"I USE THIS ALL THE TIME. I REALLY AM GLAD I BOUGHT THIS DVD PLAYER .I AM REALLY ENJOYING THE WIDE SCREEN IT IS NICE THE COLOR IS GREAT AND THE BATTERY LAST QUITE A LONG TIME BEFORE IT NEEDS CHARGING WHEN THE POWER GOES OUT I HAVE A DVD PLAYER TO WATCH MOVIES AND LISTEN TO MUSIC CD'S. CD'S WORK IN T …"  Read Full Review »
Feb 19 2009
CS
FRESNO, CALIFORNIA.
I am:
  • CD LOVER
  • Music lover
  • Practical
Reviewed at:
[2 of 4 customers found this review helpful]
PIECE OF JUNK
1.0
    Pros
  • Easy Controls
    Cons
  • Poor Picture
    Best Uses
  • Larger Cars
"This is really a worthless PIECE OF JUNK.
I just got it, because it was on sale on thanksgiving. The only good thing about it is
it comes with an integrated SD slot.But these days most DVD players are supporting it.
The picture and audio quality is very very poor. It does not play different for …"  Read Full Review »
 Report Abuse  (2)  (2)  0 comments
Feb 13 2009
sk
RENO NV
I am:
  • Practical
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
