A-Data Technology Retractable 16GB USB 2.0 Flash Drive with ReadyBoost (120X) - C702 16GB
5.0
based on 3 reviews
Ratings Distribution
5 star
3
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.3
Pros
  • Easy to use (2)
  • Large capacity / good size (2)
  • Portable (2)
  • Reliable (2)
  • Durable (1)
  • Fast (1)
  • Fast connectivity (1)
  • Quiet (1)
  • Versatile (1)
See less See more
Best Uses
  • File transfer (2)
  • Additional storage (1)
  • Back-up (1)
  • Laptops (1)
  • Large projects (1)
  • Multimedia (1)
  • Music (1)
  • Travel (1)
Provided by NothingButSoftware
Eliminate the inconvenience of carrying notebooks all around for important data storage!
120x Speed - Read 12MBs / Write 8MBs
The C702 enhanced for Windows ReadyBoost™ function, it can improve efficiency in Windows Vista™. Equipped with all those basic features, the C702 takes especially advantage of Windows Vista™. Users can fit the cap on the end of USB flash drive; therefore you won’t lose caps anymore. For accessing your data, music, video, and photos, C702 is the right drive for you!
Elegantly designed for easy use!
When consumer electronic intimately connecting to our daily life, the product design certainly does matter. Catching the latest design trend, the new A-DATA C702 flash drive makes a stylish impression in a subtle way. Inspired by minimalism, C702's retractable USB connector eliminates the need for caps and perfectly protects the connector. A simple clean-cut casing gives it a truly fashionable appearance and makes C702 the classic statement for your digital lifestyle. In addition, A-DATA adds a hook and neck strap for convenience and to prevent loss.
The A-DATA C702 is a removable flash disk with USB 2.0 High Speed standard connection. It can support 4 NAND flash memory and up to 16GB disk space for mass data storage application. C702 has a plug-n-play function. As a result of its small and convenient size, users can carry it easily anywhere for data storage.
C702 has various storage capacities of 16GB. C702 also is also highly compatible with PC operation system (OS), so users will not have to load the driver to most of PC OS. C702 dramatically eliminates the inconvenience of carrying notebooks all around for important data storage!
Balance between performance and style!
With transfer speeds 120X, 8 to 10 times faster than traditional USB 1.1 Flash Drives, C702 has max read/write speeds of 12MB/8MB per second. Available in 1GB to 16GB, C702 provides superior performance and capacity in data transfer and saving. For those who care about performance and style, A-DATA C702 is what you've been waiting for!
It's affordable, it's compact, it's sturdy, and it has plenty of storage space!
This  FlashDrive is an extremely compact and provides a quick and easy solution for storage. It's Plug & Play capability provides easy installation in a snap. It allows you to back up your important files with speed and reliability.   Combining the best of Zip, CD-RW and floppy drives, The Flash Drive stores all types of data in a highly portable package -- you can take your files anywhere you need to go. From business documents and presentations to personal files, music and e-mail, you'll be thrilled with the flexible storage and convenience this drive provides.
  • Pen like Retractable USB Flash Drive!
  • Enhanced for Windows® ReadyBoost
  • Support Toshiba, Samsung and Hynix NAND flash memory of 1Gbit, 2Gbit, 4Gbit and 8Gbit
  • Capacity: 16GB
  • Support USB specification version 2.0.
  • Transferring rate up to 480Mbit per second at High Speed
  • Support power saving mode to reduce power consumption
  • Support Windows ME, 2000 and XP without device driver
  • Support Driver for Windows 98/98 SE
  • Driverless solution for Linux Kernel version 2.4 or later version
  • Driverless for Mac OS 9.X or above
  • LED indicator when device is in use
  • Hot Plug & Play
  • Durable solid-state storage
  • No external power is required ?DC 4.5V ~ 5.5V from USB port
  • It also supports software application for Disk Security and Disk Partition
  • Color: Pearl white
  • Dimensions:  69.6x17x10 mm  (LxWxH)
  • Weight:  10g
  • USB 2.0 Flash Disk
  • Desktop or notebook computer with USB port
  • One of the following operating systems:
    • Windows 98, 98SE, Me, 2000, XP, Vista
    • Linux kernel 2.4 or later
    • Mac OS 9.0 or later
Due to the type of product packaging, once this product has been opened it is non-returnable. If the product is defective, it will be exchanged for the same product. No cash refunds.
A-Data Technology Retractable 16GB USB 2.0 Flash Drive with ReadyBoost (120X) - C702 16GB Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: Retractable 16GB USB 2.0 Flash Drive with ReadyBoost (120X) - C702 16GB
See all eBay results
  at eBay.com
Product Reviews
Last update: Dec 17, 2008
A-Data Technology Retractable 16GB USB 2.0 Flash Drive with ReadyBoost (120X) - C702 16GB Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
Perfect!
5.0
    Pros
  • Durable
  • Fast Connectivity
  • Quiet
  • Reliable
  • Versatile
    Cons
  • None
    Best Uses
  • Laptops
  • Large Projects
  • Multimedia
  • Travel
"No problems whatsoever, and exactly as advertised. Can't beat the price. "
Was this Flash Stick review on the A-Data Technology Retractable 16GB USB 2.0 Flash Drive with ReadyBoost (120X) - C702 16GB helpful to you?
Nov 23 2008
Ron Dugan
Albany, NY
I am:
  • Tech Savvy
Reviewed at:
I like A-Data flash drives.
5.0
    Pros
  • Easy To Use
  • Fast
  • High Capacity
  • Portable
  • Reliable
    Cons
  • None
    Best Uses
  • Additional Storage
  • Backup
  • File Transfer
  • Music
"I use flash drives to work with the same files on different machines. "
Dec 17 2008
tux power
wenatchee washington
I am:
  • Power user
Reviewed at:
Works great!
5.0
    Pros
  • Easy To Use
  • High Capacity
  • Portable
    Cons
  • None i can think of
    Best Uses
  • File Transfer
"Great thumb drive - does what it should. "
Dec 8 2008
Bassman
Yorktown, VA
I am:
  • Power user
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
