7-Port USB 2.0 HUB, Indicator Lights, AC Power Adapter Included
3.6
based on 17 reviews
Ratings Distribution
5 star
4
4 star
8
3 star
1
2 star
3
1 star
1
Category Average
4.1
Pros
  • Consistent performance (8)
  • Easy to configure (6)
  • Easy setup (5)
  • Durable (4)
  • Versatile (4)
  • Reliable (3)
  • Fast (2)
  • Small (2)
  • Acceptable with caveats (1)
  • Easily expanded (1)
See less See more
Cons
  • 1con usb cable too short (1)
  • Bright leds (1)
  • Distracting (1)
  • Flashing led's (1)
  • Flashing light (1)
  • Flashing lights (1)
  • Flimsy (1)
  • Quality issues see text (1)
  • The lights are annoying. (1)
Best Uses
  • Desktop (4)
  • Home (4)
  • Portable devices (2)
  • Home computer (1)
  • Laptop (1)
  • My old mac (1)
  • Pet toy (1)
  • Powered 7 port hub (1)
  • Self-hypnosis (1)
  • Small networks (1)
Provided by Super Media Store
USB 2.0 Hub 7 Port provides you with the ability to easily connect and operate up to seven USB devices instantly. The newUSB 2.0 Hub 7 port with Flash Drive Port features a compact space saving design freeing up valuable space on your desktop. In addition you will have quick access to your USB devices.
7-Port USB 2.0 HUB, Indicator Lights, AC Power Adapter Included Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: 7-Port USB 2.0 HUB, Indicator Lights, AC Power Adapter Included
See all eBay results
  at eBay.com
Product Reviews
Last update: Nov 20, 2008
7-Port USB 2.0 HUB, Indicator Lights, AC Power Adapter Included Reviews
Most helpful positive review
Most helpful negative review
4.0
Close Encounter of the USB HUB Kind
"USB 2.0 hub comes with power supply and USB cord (about 4')This unit works basically as advertised, but you should be aware of a couple of specific details.1. Don't press too hard on the power connector when inserting it. I did, and it pryed the case apart and the jack on the circuit board bent. I was able to bend it back, and super glue the case together without much trouble, but I still remember the "bendy" fe..." Read Full Review »
Jul 26, 2007 by Chefboy
See more positive 7-Port USB 2.0 HUB, Indicator Lights, AC Power Adapter Included reviews
3.0
Flashing Lights
"This is a great product for the money, BUT, the flashing multi-colored lights would drive you insane. I have mine on the floor and the lights are so bright I had to cover the unit with aluminum foil. Beware. If you can place it out of site, I would recomend it. If you are getting it for a young child's computer that might work out fine as is then...." Read Full Review »
Sep 17, 2007 by riodealer
See more negative 7-Port USB 2.0 HUB, Indicator Lights, AC Power Adapter Included reviews
Displaying 1 - 5 of 17 Reviews
Show
Sort by
4.0
LOL Funny
LOL Funny
    Pros
  • Good Value
  • Works as advertised
    Cons
  • Distracting
  • Flashing LED's
    Best Uses
  • Pet Toy
  • Powered 7 Port Hub
  • Self-hypnosis
  • UFO Simulator
"USB 2.0 hub comes with power supply and USB cord (about 4')This unit works basically as advertised, but you should be aware of a couple of specific details.1. Don't press too hard on the power connector when inserting it. I did, and it pryed the case apart and the jack on the circuit board bent. I w …"  Read Full Review »
Was this Networking Hub & Switch review on the 7-Port USB 2.0 HUB, Indicator Lights, AC Power Adapter Included helpful to you?
Jul 26 2007
Chefboy
Dobbins, California
Reviewed at:
Flashing Lights
3.0
    Pros
  • Consistent Performance
    Cons
  • Flashing Lights
    Best Uses
  • None
"This is a great product for the money, BUT, the flashing multi-colored lights would drive you insane. I have mine on the floor and the lights are so bright I had to cover the unit with aluminum foil. Beware. If you can place it out of site, I would recomend it. If you are getting it for a young chil …"  Read Full Review »
Sep 17 2007
riodealer
Las Vegas, NV
I am:
  • Gearhead
  • Tech Savvy
Reviewed at:
No problems thus far
4.0
    Pros
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • Bright LEDs
    Best Uses
  • Desktop
  • Home
"Works great! No complaints other than I wish I could turn the LEDs off. Each port has its own LED, and there is a central LED that constantly changes patterns. Be warned: the LEDs are bright.
Would buy again, despite the LEDs. "
Jul 29 2008
OuterSpaceGuy
Litchfield Park, AZ
I am:
  • Low bandwidth user
Reviewed at:
Annoying lights!
4.0
    Pros
  • Easy To Configure
    Cons
  • flashing light
    Best Uses
  • None
"Just got this and it works well at a great price, but it didn't mention this annoying light in the center that flashes all the time! I put it on my desktop upside down to avoid it. But I would not recommend it if you spend a lot of time at the computer. "
Aug 20 2007
Teamzappa
Reading PA
I am:
  • Tech Savvy
Reviewed at:
Broke after a few months
2.0
    Pros
  • Easy To Set Up
    Cons
  • Flimsy Construction
  • Unreliable
    Best Uses
  • Desktop
  • Home
"Was easy to install, and the flashing lights really impress small children. And (I admit) I got to like the flashing lights, too.
But it's not well made. It broke after a few months. "
Nov 20 2008
Smitty
Houston, TX
I am:
  • High bandwidth user
Reviewed at:
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
